I’m trying to use AGX Xavier (JetPack4.6.1 & devkit) to capture mipi csi video steam, it’s a 4lane 1080p yuv422 signal connected to AGX CSI0_D0 CSI0_D1 CSI1_D0 CSI1_D1 CSI0_CLK.
I got error trace log as follows:
kworker/0:4-2280 [000] .... 639.660230: rtcpu_string: tstamp:20506088078 id:0x04010000 str:"Configuring VI GoS.
kworker/0:4-2280 [000] .... 639.660291: rtcpu_string: tstamp:20506088517 id:0x04010000 str:"VM GOS[#0] addr=0xc2100000
kworker/0:4-2280 [000] .... 639.660305: rtcpu_string: tstamp:20506088939 id:0x04010000 str:"VM GOS[#1] addr=0xc2101000
kworker/0:4-2280 [000] .... 639.660317: rtcpu_string: tstamp:20506089352 id:0x04010000 str:"VM GOS[#2] addr=0xc2102000
kworker/0:4-2280 [000] .... 639.660328: rtcpu_string: tstamp:20506089756 id:0x04010000 str:"VM GOS[#3] addr=0xc2103000
kworker/0:4-2280 [000] .... 639.660338: rtcpu_string: tstamp:20506090215 id:0x04010000 str:"VM GOS[#4] addr=0xc2104000
kworker/0:4-2280 [000] .... 639.660349: rtcpu_string: tstamp:20506090620 id:0x04010000 str:"VM GOS[#5] addr=0xc2105000
kworker/0:4-2280 [000] .... 639.660360: rtcpu_string: tstamp:20506101913 id:0x04010000 str:"vi5_hwinit: firmware CL2018101701 protocol vers"
kworker/0:4-2280 [000] .... 639.660362: rtcpu_string: tstamp:20506102181 id:0x04010000 str:"on 2.2
kworker/0:4-2280 [000] .... 639.660373: rtos_queue_send_from_isr_failed: tstamp:20506143339 queue:0x0bcb2e38
kworker/0:4-2280 [000] .... 639.660375: rtos_queue_send_from_isr_failed: tstamp:20506143694 queue:0x0bcb76a0
kworker/0:4-2280 [000] .... 639.660376: rtos_queue_send_from_isr_failed: tstamp:20506144001 queue:0x0bcb9220
kworker/0:4-2280 [000] .... 639.660377: rtos_queue_send_from_isr_failed: tstamp:20506144297 queue:0x0bcb9fe0
kworker/0:4-2280 [000] .... 639.660378: rtos_queue_send_from_isr_failed: tstamp:20506144593 queue:0x0bcbada0
kworker/0:4-2280 [000] .... 639.660379: rtcpu_string: tstamp:20506146249 id:0x04010000 str:"VI GOS[#0] set to VM GOS[4] base 0xc2104000
kworker/0:4-2280 [000] .... 639.716135: rtos_queue_send_from_isr_failed: tstamp:20506452492 queue:0x0bcb2e38
kworker/0:4-2280 [000] .... 639.716140: rtos_queue_send_from_isr_failed: tstamp:20506452631 queue:0x0bcb76a0
kworker/0:4-2280 [000] .... 639.716141: rtos_queue_send_from_isr_failed: tstamp:20506452771 queue:0x0bcb9220
kworker/0:4-2280 [000] .... 639.716142: rtos_queue_send_from_isr_failed: tstamp:20506452905 queue:0x0bcb9fe0
kworker/0:4-2280 [000] .... 639.716144: rtos_queue_send_from_isr_failed: tstamp:20506453039 queue:0x0bcbada0
kworker/0:4-2280 [000] .... 639.716146: rtcpu_nvcsi_intr: tstamp:20506455735 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000081
kworker/0:4-2280 [000] .... 639.716148: rtcpu_nvcsi_intr: tstamp:20506455735 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000088
kworker/0:4-2280 [000] .... 639.716181: rtcpu_nvcsi_intr: tstamp:20506455735 class:GLOBAL type:PHY_INTR1 phy:0 cil:0 st:0 vc:0 status:0x00000400
kworker/0:4-2280 [000] .... 639.716182: rtcpu_nvcsi_intr: tstamp:20506460102 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716183: rtcpu_nvcsi_intr: tstamp:20506460102 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716184: rtcpu_nvcsi_intr: tstamp:20506461031 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716186: rtcpu_nvcsi_intr: tstamp:20506461031 class:GLOBAL type:PHY_INTR1 phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/0:4-2280 [000] .... 639.716187: rtcpu_nvcsi_intr: tstamp:20506461031 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716188: rtcpu_nvcsi_intr: tstamp:20506461752 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716189: rtcpu_nvcsi_intr: tstamp:20506461752 class:GLOBAL type:PHY_INTR1 phy:0 cil:0 st:0 vc:0 status:0x0000000c
kworker/0:4-2280 [000] .... 639.716190: rtcpu_nvcsi_intr: tstamp:20506461752 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716191: rtcpu_nvcsi_intr: tstamp:20506462460 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716193: rtcpu_nvcsi_intr: tstamp:20506462460 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716194: rtcpu_nvcsi_intr: tstamp:20506463006 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716218: rtcpu_nvcsi_intr: tstamp:20506463006 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716219: rtcpu_nvcsi_intr: tstamp:20506463807 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716220: rtcpu_nvcsi_intr: tstamp:20506463807 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716222: rtcpu_nvcsi_intr: tstamp:20506464354 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716223: rtcpu_nvcsi_intr: tstamp:20506465604 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716224: rtcpu_nvcsi_intr: tstamp:20506465604 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716225: rtcpu_nvcsi_intr: tstamp:20506466644 class:GLOBAL type:PHY_INTR1 phy:0 cil:0 st:0 vc:0 status:0x00000008
kworker/0:4-2280 [000] .... 639.716226: rtcpu_nvcsi_intr: tstamp:20506466644 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716227: rtcpu_nvcsi_intr: tstamp:20506467191 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716228: rtcpu_nvcsi_intr: tstamp:20506467567 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716230: rtcpu_nvcsi_intr: tstamp:20506467567 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716231: rtcpu_nvcsi_intr: tstamp:20506468112 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716232: rtcpu_nvcsi_intr: tstamp:20506468729 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716233: rtcpu_nvcsi_intr: tstamp:20506468729 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716234: rtcpu_nvcsi_intr: tstamp:20506469656 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716235: rtcpu_nvcsi_intr: tstamp:20506469656 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716237: rtcpu_nvcsi_intr: tstamp:20506470377 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716238: rtcpu_nvcsi_intr: tstamp:20506470377 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716239: rtcpu_nvcsi_intr: tstamp:20506470927 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716240: rtcpu_nvcsi_intr: tstamp:20506471495 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716241: rtcpu_nvcsi_intr: tstamp:20506471495 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716242: rtcpu_nvcsi_intr: tstamp:20506472060 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716243: rtcpu_nvcsi_intr: tstamp:20506472060 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716245: rtcpu_nvcsi_intr: tstamp:20506473017 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716246: rtcpu_nvcsi_intr: tstamp:20506473017 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716247: rtcpu_nvcsi_intr: tstamp:20506474651 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716248: rtcpu_nvcsi_intr: tstamp:20506474651 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716249: rtcpu_nvcsi_intr: tstamp:20506475196 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716250: rtcpu_nvcsi_intr: tstamp:20506475196 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716252: rtcpu_nvcsi_intr: tstamp:20506475914 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716253: rtcpu_nvcsi_intr: tstamp:20506475914 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716254: rtcpu_nvcsi_intr: tstamp:20506476468 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716256: rtcpu_nvcsi_intr: tstamp:20506476468 class:GLOBAL type:PHY_INTR1 phy:0 cil:0 st:0 vc:0 status:0x00000008
kworker/0:4-2280 [000] .... 639.716257: rtcpu_nvcsi_intr: tstamp:20506476468 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716259: rtcpu_nvcsi_intr: tstamp:20506477189 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716260: rtcpu_nvcsi_intr: tstamp:20506477189 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716261: rtcpu_nvcsi_intr: tstamp:20506477820 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716262: rtcpu_nvcsi_intr: tstamp:20506477820 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716263: rtcpu_nvcsi_intr: tstamp:20506478362 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000001
kworker/0:4-2280 [000] .... 639.716264: rtcpu_nvcsi_intr: tstamp:20506478362 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000001
kworker/0:4-2280 [000] .... 639.716266: rtcpu_nvcsi_intr: tstamp:20506478952 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716288: rtcpu_nvcsi_intr: tstamp:20506478952 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716289: rtcpu_nvcsi_intr: tstamp:20506479498 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716290: rtcpu_nvcsi_intr: tstamp:20506479498 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716291: rtcpu_nvcsi_intr: tstamp:20506480040 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716292: rtcpu_nvcsi_intr: tstamp:20506480040 class:GLOBAL type:PHY_INTR1 phy:0 cil:0 st:0 vc:0 status:0x00000008
kworker/0:4-2280 [000] .... 639.716293: rtcpu_nvcsi_intr: tstamp:20506480040 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716294: rtcpu_nvcsi_intr: tstamp:20506480748 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716296: rtcpu_nvcsi_intr: tstamp:20506480748 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716297: rtcpu_nvcsi_intr: tstamp:20506482512 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716298: rtcpu_nvcsi_intr: tstamp:20506482512 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716299: rtcpu_nvcsi_intr: tstamp:20506483440 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716300: rtcpu_nvcsi_intr: tstamp:20506483440 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716301: rtcpu_nvcsi_intr: tstamp:20506484306 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716303: rtcpu_nvcsi_intr: tstamp:20506484306 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716304: rtcpu_nvcsi_intr: tstamp:20506485289 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716305: rtcpu_nvcsi_intr: tstamp:20506485289 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716306: rtcpu_nvcsi_intr: tstamp:20506486216 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716307: rtcpu_nvcsi_intr: tstamp:20506486216 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716308: rtcpu_nvcsi_intr: tstamp:20506487850 class:GLOBAL type:PHY_INTR1 phy:0 cil:0 st:0 vc:0 status:0x0000000c
kworker/0:4-2280 [000] .... 639.716309: rtcpu_nvcsi_intr: tstamp:20506487850 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716311: rtcpu_nvcsi_intr: tstamp:20506488397 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716312: rtcpu_nvcsi_intr: tstamp:20506489000 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716313: rtcpu_nvcsi_intr: tstamp:20506489000 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716314: rtcpu_nvcsi_intr: tstamp:20506489695 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716315: rtcpu_nvcsi_intr: tstamp:20506489695 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716316: rtcpu_nvcsi_intr: tstamp:20506490240 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716318: rtcpu_nvcsi_intr: tstamp:20506490611 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716319: rtcpu_nvcsi_intr: tstamp:20506490611 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716320: rtcpu_nvcsi_intr: tstamp:20506491159 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716321: rtcpu_nvcsi_intr: tstamp:20506491539 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716322: rtcpu_nvcsi_intr: tstamp:20506491539 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716323: rtcpu_nvcsi_intr: tstamp:20506492084 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716324: rtcpu_nvcsi_intr: tstamp:20506492619 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716326: rtcpu_nvcsi_intr: tstamp:20506492619 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716327: rtcpu_nvcsi_intr: tstamp:20506493165 class:GLOBAL type:PHY_INTR1 phy:0 cil:0 st:0 vc:0 status:0x00000008
kworker/0:4-2280 [000] .... 639.716328: rtcpu_nvcsi_intr: tstamp:20506493537 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716329: rtcpu_nvcsi_intr: tstamp:20506493537 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716330: rtcpu_nvcsi_intr: tstamp:20506494083 class:GLOBAL type:PHY_INTR1 phy:0 cil:0 st:0 vc:0 status:0x00000008
kworker/0:4-2280 [000] .... 639.716331: rtcpu_nvcsi_intr: tstamp:20506494573 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716332: rtcpu_nvcsi_intr: tstamp:20506494573 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716334: rtcpu_nvcsi_intr: tstamp:20506496478 class:GLOBAL type:PHY_INTR1 phy:0 cil:0 st:0 vc:0 status:0x0000000c
kworker/0:4-2280 [000] .... 639.716335: rtcpu_nvcsi_intr: tstamp:20506496850 class:GLOBAL type:PHY_INTR1 phy:0 cil:0 st:0 vc:0 status:0x00000008
kworker/0:4-2280 [000] .... 639.716354: rtcpu_nvcsi_intr: tstamp:20506497225 class:GLOBAL type:PHY_INTR1 phy:0 cil:0 st:0 vc:0 status:0x00000008
kworker/0:4-2280 [000] .... 639.716355: rtcpu_nvcsi_intr: tstamp:20506499217 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716356: rtcpu_nvcsi_intr: tstamp:20506499217 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716357: rtcpu_nvcsi_intr: tstamp:20506500956 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00100000
kworker/0:4-2280 [000] .... 639.716358: rtcpu_nvcsi_intr: tstamp:20506500956 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00004000
kworker/0:4-2280 [000] .... 639.716359: rtcpu_nvcsi_intr: tstamp:20506501870 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716361: rtcpu_nvcsi_intr: tstamp:20506501870 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716362: rtcpu_nvcsi_intr: tstamp:20506502671 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716363: rtcpu_nvcsi_intr: tstamp:20506502671 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716364: rtcpu_nvcsi_intr: tstamp:20506503216 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716365: rtcpu_nvcsi_intr: tstamp:20506503588 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716366: rtcpu_nvcsi_intr: tstamp:20506503588 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716368: rtcpu_nvcsi_intr: tstamp:20506504671 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716369: rtcpu_nvcsi_intr: tstamp:20506504671 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716370: rtcpu_nvcsi_intr: tstamp:20506505595 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716371: rtcpu_nvcsi_intr: tstamp:20506505595 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716372: rtcpu_nvcsi_intr: tstamp:20506507453 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716373: rtcpu_nvcsi_intr: tstamp:20506507453 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716374: rtcpu_nvcsi_intr: tstamp:20506509306 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716376: rtcpu_nvcsi_intr: tstamp:20506509306 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716377: rtcpu_nvcsi_intr: tstamp:20506510971 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716378: rtcpu_nvcsi_intr: tstamp:20506510971 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716379: rtcpu_nvcsi_intr: tstamp:20506511521 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716380: rtcpu_nvcsi_intr: tstamp:20506511963 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716381: rtcpu_nvcsi_intr: tstamp:20506511963 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716382: rtcpu_nvcsi_intr: tstamp:20506512509 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716384: rtcpu_nvcsi_intr: tstamp:20506513017 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716385: rtcpu_nvcsi_intr: tstamp:20506513017 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [000] .... 639.716386: rtcpu_nvcsi_intr: tstamp:20506513762 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:4-2280 [0
