We have a custom board for use with the AGX Xavier. Only UART3 is broken out and we are unable to get any console output on the UART. Is there a dtb change that is required when only UART3 is used?
hello blokeandsally,
are you still access to the board, for example, ssh though ethernet?
Hi JerryChang
Yes we can still access the board via other means.
Given the question, is it safe to assume that there should be no change required to the console in the dtb and we are looking for another issue?
I’m closing this topic due to there is no update from you for a period, assuming this issue was resolved.
If still need the support, please open a new topic. Thanks
did you meant is it UART3 hardware defects?
in addition, what’s your expectation about… when only UART3 is used? are you asking for switching debug UART to other ports?
