xavier serial console problem
Hi,all:
We use the xavier designed a board. I connect the uart3(reg address is 0x0c280000) to my picture through usb to ttl module), the baud rate is 115200. But no log output.
I set the device tress : stdout-path = “/serial@c280000”, but still no log output.
Can you help me?
Thank you very much.
hello cxl824158933,
could you please also check similar discussion thread for using UART,
for example, Topic 1053941, and Topic 1058946.
thanks
