Can the Nano do AI upscaling? If not are there plans to incorporate this feature into the Nano and when. Thanks.
Tom
Tom
There is at least one example in jetson-inference, that I can recall, but Nvidia may have other examples elsewhere.
Can this be used for realtime video stream upscaling from 720p to 1080p? Thanks.
Tom
I don’t know whether the Nano is capable. I haven’t run the example, much less a modified example on a sequence of images, so I couldn’t even give you a rough estimate. Somebody from Nvidia will have to answre the question or you can benchmark yourself.
Anybody know if the AI up-scaling has or will be able to be implemented on the Nano?
I was assuming it would be some type of Nvidia library function added to an existing library Nvidia provides.
Tom
nvvidconv can do upscaling. Please try
$ gst-launch-1.0 videotestsrc ! video/x-raw,width=1280,height=720 ! nvvidconv ! 'video/x-raw(memory:NVMM),width=1280,height=720' ! nvvidconv ! 'video/x-raw(memory:NVMM),width=1920,height=1080' ! nvoverlaysink
