I’m building a server/client program that allocates GPUs to remote clients, using the runtime API. The parent server process accepts network connections from clients and creates a child process to service the request. The child calls cudaSetDevice() for the appropriate device and runs the CUDA kernels.
All devices are in compute mode 0 (non-exclusive mode).
Problem is, in the children, cudaMalloc() is returning the error “all CUDA-capable devices are busy or unavailable”. My guess is that the parent/server process is creating a CUDA context when it starts up, well before it forks to create a child. The child is then unable to access the device because the CUDA context exists in the parent.
Do I need to do something like calling cudaThreadExit() in the parent before I fork() to create any children?
Thanks for any help.
I am using a GTX480 cards on
x86_64 Red Hat Enterprise Linux Client release 5.4 (Tikanga)
Nvidia driver version 256.40
The Cuda toolkit I downloaded was cudatoolkit_3.1_linux_64_rhel5.4.run
I added cudaThreadExit() to the parent, and the children are still returning the error “all CUDA-capable devices are busy or unavailable”. Can you think of anything else I could try?
Hm, can you try with an r260 driver? At one point in time fork() didn’t really work with the CUDA driver, and I don’t remember in what version I fixed it.
Thanks, I’ll try the new 260.19.14 driver. Just one dumb question – the driver install script devdriver_3.2_linux_64_260.19.14.run has a “3.2” in the name. Does that mean that the CUDA Toolkit v. 3.2 is required? If so, I will have to upgrade my O/S. RHEL 5.4 isn’t supported by that version of the Toolkit, according to its Release Notes.
I installed the new driver (260.19.14, steps taken are below), and I’m still getting the “busy or unavailable” error message after the fork(). Is there anything else I could try?
ctrl-alt-F1, then log into account
/sbin/init 3
stop nvidia-smi, which is running in daemon mode
remove the Nvidia driver: rmmod nvida
uninstall the old Nvidia driver: nvidia-installer –uninstall
install the new driver – go to where it is downloaded and type: sh devdriver_3.2_linux_64_260.19.14.run
/sbin/init 3
I created a test program that just forks to create a child, and then the child runs a CUDA kernel. The kernel ran fine, no “busy or unavailable” error. So the Nvidia driver handles fork() correctly; it must be something I’m doing in my real program, but that is too big to post.
Any further guesses on your part would be welcome. Would the use of Linux shared memory (shm_open(), librt.a, etc.) cause any sort of problem?
OK, I found the cause but I don’t understand why it is a problem. The parent calls cudaGetDeviceCount(), cudaGetDeviceProperties() and uses “new” to create several cudaDeviceProp structures before the fork. In my little test program, adding these calls to the parent causes the “busy or unavailable” error in the children. Can you explain?
cudaError_t err;
int n_devices_total_;
struct cudaDeviceProp *device_props_[N_DEVICES_MAX_];
// get device count
err = cudaGetDeviceCount(&n_devices_total_);
if (err != cudaSuccess)
// throw exception
} else if (n_devices_total_ == 0)
// throw exception
} else if (n_devices_total_ > N_DEVICES_MAX_)
// throw exception
// store the device properties
for (int i = 0; i < n_devices_total_; i++)
device_props_[i] = new cudaDeviceProp();
err = cudaGetDeviceProperties(device_props_[i], i);
// throw exception
cudaError_t err;
// get device count
// throw exception
// throw exception
// throw exception
// throw exception
