A clear and concise description of the bug or issue.
Environment
TensorRT Version: 8.2 GPU Type: T4 Nvidia Driver Version: 470 CUDA Version: 11.4
I have an error report when onnx model is converted to TRT.
model:This is a transformer model for language recognition
Error[4]: [graphShapeAnalyzer.cpp::processCheck::581] Error Code 4: Internal Error (IAssertionLayer (Unnamed Layer* 5) [Assertion]: condition[0] is false: 0. For input: 'speech' all named dimensions that share the same name must be equal. Note: Named dimensions were present on the following axes: 0 (name: 'B'), 0 (name: 'B'))
Request you to share the ONNX model and the script if not shared already so that we can assist you better.
Alongside you can try few things:
validating your model with the below snippet
check_model.py
import sys
import onnx
filename = yourONNXmodel
model = onnx.load(filename)
onnx.checker.check_model(model).
2) Try running your model with trtexec command.
In case you are still facing issue, request you to share the trtexec “”–verbose"" log for further debugging
How to upload files over 100MB?
I found that only when the batch size of minshapes is greater than 1, there will be an error, otherwise it will be normal. example: not work
Hello @549981178,
I have the same problem.
I have a model with 4 inputs and I’m getting the error for one of them and I don’t have any clue what is the root problem cause.
Can you clarify please, in your case, exactly what did you understand about the problem root cause and what did you change in order to solve it?
