Thank you so much for providing these convenient products. I can use the diffdock API successfully, however, I have difficulties in using alphafold2 model via API.
My test is exactly same with the python and bash example you provided in the webpage:
#!/usr/bin/env python3
import os
import requests
import time
from pathlib import Path
# Variables
key = os.getenv("NVCF_RUN_KEY") or input("Paste the Run Key: ")
url = os.getenv("URL", "https://health.api.nvidia.com/v1/biology/deepmind/alphafold2")
status_url = os.getenv("STATUS_URL", "https://health.api.nvidia.com/v1/status")
sequence = ("MVPSAGQLALFALGIVLAACQALENSTSPLSADPPVAAAVVSHFNDCPDSHTQFCFHGTCRFL"
"VQEDKPACVCHSGYVGARCEHADLLAVVAASQKKQAITALVVVSIVALAVLIITCVLIHCCQVRKHCEWCR"
"ALICRHEKPSALLKGRTACCHSETVV"
output_file = Path("output.json")
# Initial request
headers = {
"content-type": "application/json",
"Authorization": f"Bearer keykeykey",
"NVCF-POLL-SECONDS": "2",
data = {
"sequence": sequence,
"algorithm": "mmseqs2",
"e_value": 0.0001,
"iterations": 1,
"databases": ["uniref90", "small_bfd", "mgnify"],
"relax_prediction": True,
print("Making request...")
response = requests.post(url, headers=headers, json=data)
# Check the status code
if response.status_code == 200:
output_file.write_text(response.text)
print(f"Response output to file: {output_file}")
elif response.status_code == 202:
print("Request accepted...")
# Extract reqId header
req_id = response.headers.get("nvcf-reqid")
# Poll the /status endpoint
while True:
print("Polling for response...")
status_response = requests.get(f"{status_url}/{req_id}", headers=headers)
if status_response.status_code != 202:
output_file.write_text(status_response.text)
break
# Wait before polling again
time.sleep(2)
else:
print(f"Unexpected HTTP status: {response.status_code}")
print(f"Response: {response.text}")
I got the following results:
Making request…
Request accepted…
Polling for response…
Response output to file: output.json
The output.json is :
{"type":"about:blank","status":500,"title":"Internal Server Error","detail":"Inference error"}
Could you please give me some hints on this ?
