After decoding, an exception occurred when I called VIDIOC_STREAMOFF.
If you call v4l2_close directly, it will cause a deadlock.
How can I safely release resources after decoding.
We have two samples demonstrating video decoding:
/usr/src/jetson_multimedia_api/samples/00_video_decode/
/usr/src/jetson_multimedia_api/samples/unittest_samples/decoder_unit_sample/
Please check the flow in termination and apply to your code.
I have written against the sample, but I don’t know why there is a problem.
Are there any specific requirements for closing?
There is code about sending end of stream(EoS) at output plane and get EoS at capture plane. Please check if you include it.
