There is an issue about SPI2CAN on AGX Orin 32G.
The detail information can refer to the attached.
The doc was written in Chinese.
SPI2CAN.rtf (12.9 MB)
Hi Harris.li,
What’s your current Jetpack version in use?
Have you refer to the following instruction for CAN usage or did any loopback test to verify?
Controller Area Network (CAN) — Jetson Linux Developer Guide documentation (nvidia.com)
但是其中一路节点可以发送数据但是无法接收数据,另外一路完全正常
Which CAN bus works fine? Which CAN work with issue (CAN3!?)?
Hi Kevin,
Thanks for your reply.
Jetpack version is Jetson_Linux_R35.2.1_aarch64.
We will study flowing link first.
Yes, please make sure it works fine with internal loopback test first.
You could also use latest JP5.1.1(R35.3.1) to verify and we could synchronize the status.
Hi Kevin,
The native CAN works, and one of the SPI to CAN channels can send data, but cannot receive data.
I will update to JP5.1.1(R35.3.1).
Have you also verified SPI2 work with loopback test? (through shorting MISO and MOSI together)?
I’m look forward to your result.
FYI.
Is this still an issue to support? Any result can be shared? Thanks
Hi kayccc,
Thanks for your support. It seems that this issue has been fixed.
