Get the update on https://developer.nvidia.com/mdl-sdk and https://github.com/NVIDIA/MDL-SDK .
Added and Changed Features
General
- Added a linker script on Linux that hides all defined symbols except for the factory symbol(s).
MDL SDK examples
- Updated OptiX 7 example to support up to OptiX SDK 8.0.0.
- Example AXF to MDL
- Added support for AxF 1.9 sheen for SVBRDF representation.
- Improved compatibility for refracting carpaint representation.
- Improved mapping of Cook-Torrance spreads (used for non-measured BRDF fallback
and flake orientation).
- Example Execution GLSL:
- Added enable/disable SSBO and noise function remap by command line arguments.
Fixed Bugs
General
- Fixed a crash if
IMdl_resolved_resource_element::create_reader()
returnsnullptr
This might be due to an incorrect user implementation, or in legitimate cases, e.g.,
if the file disappeared between resolving and the query. - Fixed a memory leak involving the interface pointer used with the context option
“user_data”.
- Fixed a crash if
MDL Compiler and Backends
- Fixed inconsistent storing and reading of matrix material parameters in target
argument blocks for the native backend. - Avoid warnings about unsupported PTX features for native backend.
- Don’t let LLVM abort at shutdown, when writing to stderr fails.
- mdltlc: Fixed error in pattern matching of material nodes.
- Fixed HLSL/GLSL code generation that sometimes placed temporaries into a
loop body that are used outside, causing invalid code. - Fixed crash in the core compiler that might happen on heavily malformed MDL code.
- Prevent errors/warnings in the core compiler without line numbers
due to internal clone operations. - Slightly speedup compilation in multithreaded operations.
- Do not try to resolve empty resource URLs; Note that this is still malformed MDL code.
MDL SDK examples
- Example df_vulkan
- Fixed command line options to match other examples for
--mdl_path
/-p
option.
- Fixed re-coding of BRDF colors table (used in non-measured BRDF fallback).
- Fixed OpenGL 3.3 mode.
- Example df_vulkan
