Get the update on GitHub - NVIDIA/MDL-SDK: NVIDIA Material Definition Language SDK.
MDL SDK 2024.0.4 (377400.3959): 07 Oct 2024
Added and Changed Features
MDL 1.9 Language Specification
- Updated to document version 1.9.2.
General
- The default value for the backend option
enable_exceptionsis nowoff,
as this is the behavior described by the MDL specification.
MDL Compiler and Backends
- Implemented folding of
::texfunction calls with invalid textures on the DAG. - Added “
max_const_data” backend option to limit the size of global constants in the
generated code when the “enable_ro_segment” option is enabled. Larger constants are put
into read-only data segment. The default is “1024” bytes, which corresponds to
the old behavior.
MDL SDK examples
- MDL Core code_gen example:
- Added support for single-init mode.
- MDL SDK df_vulkan example:
- Added support for read-only data segments and
max_const_databackend option.
- MDL Example Execution Native:
- It now supports the
-pabbreviation for–mdl_pathas in all other examples.
- MDL Example df_native:
- Added support for argument blocks in Class Compilation mode.
- Added OpenGL GUI for editing material parameters and displaying stats during rendering.
- Changed default compilation mode to Class Compilation.
- Removed command line option
--ccwhich is now replaced
by--nocc(or disable Class Compilation mode).
Fixed Bugs
General
- libbsdf: Fixed issues for
df::thin_filmoverdf::custom_curve_layerand
df::directional_factorwith normal reflectivity approaching zero. - Fixed a build error if image plugins are disabled.
- Fixed a build error caused by picking up LLVM header files from a different location.
- Fixed documented return codes for
IExpression_factory::create_cast()and
create_decl_cast()(error codes are negative as usual, not positive). - Fixed missing build dependencies for the distiller plugins and the distiller example plugin.
- Allow material sub structs to be used inside a declarative struct and declarative functions.
- Improved error message in case a select operator cannot be executed because of the
left-hand-side type was not imported. - Fixed wrong HLSL/GLSL read functions used for shadow copies of function parameters.
- Fixed crash when compiling a function which receives a material parameter but doesn’t
use the state (GLSL backend with rodata segment disabled). - Avoid undefined behavior with “%” operator for negative values for GLSL
by implementing “a % b” as “a - (a / b) * b”. - Report when a standard library module is imported with a weak relative import names from
a module in a search path root. This is needed because standard library modules are
loaded from a high-priority search path and would shadow any relative import. This will
trigger a warning for MDL versions between 1.6 and 1.9, and an error for MDL versions
greater than 1.9. - Fixed the documentation of the backend option “
hlsl_use_resource_data” and
“glsl_use_resource_data”. These are recognized but not supported at the moment. - Fixed compilation of calls to non-inlined functions which receive material parameters as
arguments for GLSL/HLSL. - Return identity matrix instead of zero for unimplemented
tex::grid_to_object_space(). - Fixed crash when compiling an expression as
constwhich only becomesconstafter
optimization (e.g. by getting rid of state access). - libbsdf: Fixed wrong shadow mask in microfacet BSDFs.
- libbsdf: Avoid
NaNsdue to out-of-range roundings during random number updates. - MDL Core: Fixed resource indices for native code if a custom texture runtime is used.
- Fixed crashes if a non-constant default constructor occurred during code generation
in various backends.
