Get the update on MDL SDK | NVIDIA Developer and GitHub - NVIDIA/MDL-SDK: NVIDIA Material Definition Language SDK (on branch release/2024.1).
MDL SDK 2024.1.3 (381500.5658): 15 May 2025
Added and Changed Features
General
- Added GLSL/HLSL backend options “
material_state_struct_name” and
“environment_state_struct_name”.
MDL Core examples
- Added new dependency_inspector example:
- It lists all file dependencies of an MDL module for direct and (optionally) indirect
imports and resources.
Fixed Bugs
General
- Fixed warnings/errors with newer compilers (GCC 15 beta).
- Fixed embedded RC files on Windows.
MDL Compiler and Backends
- Fixed code generation for switch statements that could result in compilation
failure in rare cases. - Fixed generation of array compound assignments outside of declarations for HLSL.
MDL Distiller and Baker
- Fixed distilling bug in the anisotropy rotation remapping causing anisotropy angles
to be flipped.
MDL Core examples
- Example codegen:
- Fixed example on Windows such that after installation it loads the distiller plugin
without depending on PATH.
- Example codegen:
MDL SDK examples
- Example modules:
- Fixed wrong executable name in command line help description.
- Example dependency_inspector:
- Example mdl_browser:
- Fixed crash on Linux.
- Example distilling_target:
- Fixed example on MacOS X such that after installation it starts without depending
on DYLD_LIBRARY_PATH.
- Example modules:
