anonymous_jit_identity exception
Hey,
I got a anonymous_jit_identity exception when building my program. In my kernel I use one function that I use twice. If I comment out one function call, the excpetion disappears…Someone knows how to deal with the anonymous_jit_identity, I cannot debug my code, so thats a big problem. And I’m getting those strange exceptions almost all the time…
i just had exactly the same problem here.
my code worked before, but then i added a new function. then the code didn’t compile. even if i removed the newly added function, the code didn’t compile.
i read back the compiling information, it says this:
retrieving binary for ‘anonymous_jit_identity’, for gpu=‘sm_11’, usage mode=’
the problem is that, i removed almost everything from my code and only left an empty entry function like this:
the code still doesn’t compile and gives the same error. i don’t understand.
__kernel void VectorAdd(int iNumElements)
can anybody help me?
i’m using macbook with nv9400 under windows xp.
thanks.
i tried to replace the “matrixmul.cl” demo code with my “problematic” opencl code, and it does compile!
so now i guess the problem is somewhere in my c++ code.
i don’t understand.
i also tried the same c++ project under windows vista with 8800 gtx, same problem.
i found the problem.
can’t believe it was so stupid.
ciErr1 = clBuildProgram(cpProgram, 0, NULL, NULL, NULL, NULL);
	shrLog(LOGBOTH, 0, "clBuildProgram...\n");
if (ciErr1 != CL_SUCCESS)
i used this code to compile the program, however, i missed the line " if (ciErr1 != CL_SUCCESS)" when i pasted the code from another line.
so no matter it compiles or not, the code gets into the build error handling part.
can’t believe i wasted the entire afternoon on this. i kinda feel shame to post my problem and the stupid code here.
stupid mouse!!! the mouse is weird on macbook under windows, i always miss certain part when i selecting a piece of text.
