clBuildProgram always returns -11
Hi there,
I’ve been trying to get some simple OpenCL examples running for hours now. It always fails on clBuildProgram, as mentioned in the thread title. For example this one:
#include <iostream>
#include <cassert>
#include <cstring>
#include "CL/cl.h"
#include "textIO.h"
int main(int argc, char *argv[])
cl_int error = 0;   // Used to handle error codes
    cl_platform_id platforms;
    cl_uint num_platforms;
    cl_context context;
    cl_command_queue queue;
    cl_device_id device;
// Platform
    error = clGetPlatformIDs(1, &platforms, NULL);
    if (error != CL_SUCCESS) {
        std::cout << "Error getting platform id: " << error << std::endl;
        exit(error);
    } else {
        std::cout << "Platform found: " << platforms << std::endl;
// Device
    cl_uint num_devices;
    error = clGetDeviceIDs(platforms, CL_DEVICE_TYPE_GPU, 1, &device, &num_devices);
        std::cout << "Error getting device ids: " << error << std::endl;
       exit(error);
    } else {
        std::cout << "Using device ID " << device << std::endl;
        std::cout << "Devices found: " << num_devices << std::endl;
// Context
    context = clCreateContext(0, 1, &device, NULL, NULL, &error);
        std::cout << "Error creating context: " << error << std::endl;
       exit(error);
// Command-queue
    queue = clCreateCommandQueue(context, device, 0, &error);
        std::cout << "Error creating command queue: " << error << std::endl;
       exit(error);
// Creates the program
//    const char* source = TextIO::read("addVecs.cl");
    const char* source = "__kernel void mul2(__global float * mem) { int i = get_global_id(0); mem[i] *= 2; }";
    cl_program program = clCreateProgramWithSource(context, 1, &source, NULL, &error);
    assert(error == CL_SUCCESS);
std::cout << "========== Program source" << std::endl << source << std::endl;
// Builds the program
    error = clBuildProgram(program, 1, &device, NULL, NULL, NULL);
//    error = clBuildProgram(program, 0, NULL, NULL, NULL, NULL);
        std::cout << "Error building the program: " << error << std::endl;
        if (error == CL_INVALID_VALUE) {
            std::cout << "Invalid value" << std::endl;
        } else if (error == CL_INVALID_DEVICE) {
            std::cout << "Invalid device" << std::endl;
        } else if (error == CL_INVALID_BUILD_OPTIONS) {
            std::cout << "Invalid build options";
//        char buffer[4096];
//        size_t length;
//        clGetProgramBuildInfo(program, device, CL_PROGRAM_BUILD_LOG, sizeof(buffer), buffer, &length);
//        std::cout << "Program log: " << buffer;
//    assert(error == CL_SUCCESS);
// Shows the log
    char* build_log;
    size_t log_size;
    // First call to know the proper size
    std::cout << "Length: " << strlen(source) << std::endl;
    clGetProgramBuildInfo(program, device, CL_PROGRAM_BUILD_LOG, 0, NULL, &log_size);
    build_log = new char[log_size+1];
    // Second call to get the log
    clGetProgramBuildInfo(program, device, CL_PROGRAM_BUILD_LOG, log_size, build_log, NULL);
    build_log[log_size] = '
include
include
include
include “CL/cl.h”
include “textIO.h”
int main(int argc, char *argv)
cl_context context;
// Platform
    exit(error);
} else {
// Device
   exit(error);
} else {
// Context
   exit(error);
// Command-queue
   exit(error);
// const char* source = TextIO::read(“addVecs.cl”);
std::cout << “========== Program source” << std::endl << source << std::endl;
// size_t length;
// Shows the log
char* build_log;
size_t log_size;
build_log[log_size] = '\0';
std::cout << build_log << std::endl;
delete[] build_log;
// Extracting the kernel
cl_kernel vector_add_kernel = clCreateKernel(program, "addVectors", &error);
    delete[] build_log;
(clGetProgramBuildInfo is deactivated since it just segfaults when calling.)
I took the example from here.
Can anyone tell me what is going on here? Or how to find out? I’ve got the same problems with the SDK examples:
I’m on Linux, 64-bit, with a 9800 GT.
thanks
Simon
I remember having such problems with “0-linebreak-programs” when I forgot to re-add the line breaks removed by the std::getline (asides the problems a preprocessor has with macros etc. then).
That was quite some time ago, perhaps even on the Apple platform, but you could just give it a try and we can look into the problem further if it does not work.
const char* source = "__kernel void mul2(__global float * mem) { \nint i = get_global_id(0); mem[i] *= 2; \n}\n";
Unfortunately this did not help. Still the -11 error.
Isn’t it strange that I even receive the -11 when running SDK example code?
Simon
I just run your codes on my machine and it works fine. No error is produced. So I guess there are problems of your development environment。
Mine is as follow: OpenSUSE 11.4, GTX 570, Driver 270.41.06, CUDA Toolkit 4.0 RC2, GCC 4.5.1, eclipse 3.6.2 for c/cpp.
oclDeviceQuery, Platform Name = NVIDIA CUDA, Platform Version = OpenCL 1.0 CUDA 4.0.1, SDK Revision = 7027912, NumDevs = 1, Device = GeForce 9800 GT
CL_DEVICE_NAME: GeForce 9800 GT
CL_DEVICE_VENDOR: NVIDIA Corporation
CL_DRIVER_VERSION: 270.30
CL_DEVICE_VERSION: OpenCL 1.0 CUDA
CL_DEVICE_TYPE: CL_DEVICE_TYPE_GPU
This is my machine. Toolkit: latest 3.x version.
Maybe you can try other version drivers like 260.xx or latest 270.xx.
Updated to:
CL_DRIVER_VERSION: 270.41.06
Exactly the same problem. Error -11. I re-compiled the SDK examples (make clean && make -j3), all failed with -11 as well.
Try older version 260.xx? If it is not driver problem, I can not tell any other advice. External Image
Can’t I get more information from OpenCL than just the -11? Like some reason why it fails?
Or, why would clGetProgramBuildInfo segfault? I don’t understand this either.
Have you tried drivers 260.xx? The drivers 270.xx are major updates with support of CUDA 4.0 and many functions need fermi cards. Maybe there are bugs for the support of older card. Anyway just try. External Image
Tried now, but it also failed. :-/
OK, I give up. Your codes run fine on my machine. So I have no idea about what happen. External Image
What I can do now is to wish you good luck! External Image
Is there really no looking «behind the scenes»? Like a debugger or so?
I’m using the 270.xx libraries, 270.xx header files, 270.xx drivers (again now), so this should not be the reason. The graphics card should not be either. GCC neither.
PS: And, thanks for your help.
I now managed to get OpenCL running.
By installing a fresh Ubuntu 10.10 on a broken external (former Laptop) 2.5" HD and compiling/running it there.
Not exactly the solution I was looking for.
