I was flashing the Jetson Orin Nano Dev Kit with secure boot option using the odmfuse with sbk key and rsa.pem etc… I did not tried with --test or --noburn options.
The flashing process gave an error so I thought that the operation was not ended with success. On my host machine I had a Drive Error and the SBK key and rsa.pem were lost. I tried to use the recovery tools but they did not work.
Now the device does not give any signal to the display, and when I put it on the recovery mode and try to flash it requires the SBK and/or RSA keys.
Is the a way to recover a jetson orin nano devkit that was flashed with secured boot but the with a lost key set?
Any help would be highly appreciated…
