Any Success with 4-lane MIPI Camera on Jetson Orin Nano CAM1
Has anyone had success with getting video from a 4-lane MIPI camera on CAM1 on a Jetson Orin Nano Super Developer Kit?
I am fairly certain that the driver we have is correctly configured to at least get some output. Is there any off-the-shelf camera that has been successfully tested in this configuration?
I asked this question on another topic, but I believe the topic was closed, so I thought it appropriate to open a new one.
Yes, some user have bring the 4 lanes sensor up on Orin Nano.
Hi @apachecreeksoftware
I recommend you to check the lane polarity configuration you are using. There’s a lane polarity swapping for CSI0/1. Check more information here:
Enrique Ramirez
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com
Website: www.ridgerun.com
Thank you very much for the reply! I will follow your suggestion.
Is there an off-the shelf 4-lane MIPI camera that is known to work that I could test my hardware with? I am starting to think there is also a hardware problem.
I know that Jetson IO provides this configuration: “Camera IMX477 Dual 4 lane”. So, It looks like there’s support on the Jetson BSP for the IMX477 camera to work with 4-lanes, but I haven’t test it.
Maybe @ShaneCCC could confirm if this has been tested on Orin Nano.
In the other hand, as we develop drivers for customers and I can confirm we have validated the CAM1 4-lane mode capture on Jetson Orin Nano Devkit using a IMX678 sensor with a driver we developed.
Enrique Ramirez
Thank you very much for the reply.! This answers my question. I will look to see what we are doing that might break compatibility with NVIDIA’s interpretation of MIPI.
hello apachecreeksoftware,
actually it’s an incorrect DTBO, we’ve removing it in the next JP-6 public release.
please see-also Topic 333270.
