Jetson Nano Orin usage with 4 cameras
I have a computer vision project that requires me to use 4 cameras concurrently in real-time to detect an object from 4 different angles for semantic object detection. I would like to enquire the following queries:
  1. Is jetson nano orin development kit able to handle this requirement?
  2. What is the lead time for the product to arrive in Singapore?
  3. Will this work with both CSI/MIPI and USB cameras? (4 cameras)
Thank you.
We would suggest use CSI/MIPI cameras for this use-case. For using USB cameras, you may hit bandwidth constraint as we have seen on Jetson Nano and Xavier NX:
connected more than two usb cameras problem on deepstream-app (Jetson Nano Dev Kit) - #12 by DaneLLL
For CSI/MIPI cameras, please check with our partners:
Jetson Ecosystem | NVIDIA Developer
Thanks for the reply. May I know in the attached screenshot, the Nano category is applicable to both Jetson Nano and Jetson Orin Nano series or just the Jetson Nano?
Also, is there a casing for Jetson Orin Nano series?
I’m Ivan from APPROHO.
The NVIDIA ORIN NANO/NX dev-kits reserved only 2 MIPI input.
You can refer to 3rd partner’s Orin NX/NANO dev-kit below. (AETINA AIB-MO22/32| AIB-MN32/42 )
It can support 128pin 8 lane mipi camera interface for ORIN NX/NANO.
Our AR0234 zoom camera can support 36pin MIPI output.
https://www.appropho.com/products_iii.html?pdid=98&type=36&cID=187
(Sorry, due to the post limitation. I can only post one link in one post.)
Plus our 6 to 1 MIPI adapter board, it can support up to 4 cameras on Orin. (Each camera output is 2 lane MIPI)
https://www.appropho.com/products_iii.html?pdid=141&type=36&cID=187
Currently, our cameras and MIPI 6 to 1 adapter board are enough for your request and can deliver in 2~3 weeks.
