Jetson Orin Nano Camera Connector
I want to use the Jetson Orin Nano dev kit with two cameras. In the datasheet for this dev kit, the following information is provided:
Camera Connector:
The Jetson Orin Nano carrier board includes two 22-position flex (0.5 mm pitch) camera connectors (J20 and J21). The connector used on the carrier board is a Molex Japan Part #54548-2272. The connectors support the following:
  • J20: CSI 1 x2 lane
  • J21: CSI 1 x2 lane or 1 x4 lane
However, in the Camera #0 Connector Pin Description – J20, it describes 4 MIPI lanes, and similarly for the Camera #1 Connector Pin Description – J21. Please refer to the datasheet Jetson_Orin_Nano_DevKit_Carrier_Board_Specification_SP-11324-001_v1.1.
Is there an error? What is the correct information? Does the dev kit support two CSI connectors with 4 lanes each?
Thank you.
J20 only supports x2 lane camera.
