Hello nvidia Team,
I have just ordered today the 945-13766-0005-000 Development Kit Jetson Orin Nano Developer Kit.
I’m new to the nvidia environment system, but I already like it. The information database is really big. For me as an engineer its like someone opened the door to charlies chocolate factory.
I want to use the board to gain images from 2 cameas.
IMX283 and IMX335
I have already seen, that the Developer Board Connector J21 supports the 4 lane datatransmission, because of the clock.
I need to create an flexband cable, which will suit my camera pinout and the J21 pinout, so that i can connect my cameras to the adapter board.
both cam schematics are showing following naming conventions for the datalanes:
But the J21 connector has the pinout :
So how do i know what the order of connection needs to be?
MIPI_D0 ->? CSI 3/2 DATA 0/1?
MIPI_D1-> ? CSI 3/2 DATA 0/1?
MIPI_D2 ->? CSI 3/2 DATA 0/1?
MIPI_D3-> ? CSI 3/2 DATA 0/1?
I have already seen, that the csi pinout is changeable via the pin configurator.
Do I need to reconfigure the pins for my application and if so, is there a good description how to do that?
I also have read that I need to create an device tree for the cameras? Is this still needed for those two cams, because I have found them at the supported cameras?
If it is still necessary, how can I do that? Is there a good description to it?
Thank you a lot for answering my questions!
br
DK
