I’m using a Jetson Orin Nano Developer Kit running JetPack 6.1 (L4T 36.x), and I’m trying to use a Raspberry Pi HQ Camera. However, I’m encountering an issue where the camera is not detected at all.
My current setup:
Board: NVIDIA Jetson Orin Nano Developer Kit
JetPack / L4T: JetPack 6.1 (L4T 36.x)
Camera: Raspberry Pi HQ Camera (IMX477, CSI-2 interface)
Interface: Connected directly to CSI port on the Jetson carrier board
What I did:
Ran
ls /dev/video*→ No devices found -
Used
sudo /opt/nvidia/jetson-io/jetson-io.py→ Enabled IMX477-A under CSI Camera options -
Rebooted the board → Still no
/dev/video0or any camera device node appears
Followed Arducam’s Jetson-IO configuration guide as per their tutorial
And removed R8 resistor from camera module( Raspberry Pi HQ camera IMX477 Linux driver for Jetson )
Question:
How can I properly enable and verify the IMX477 camera on Jetson Orin Nano with JetPack 6.1?
Is additional driver installation required, or is the IMX477 supported out of the box on JetPack 6.1?
Do I need to modify the device tree or use
v4l2-ctlwith a specific configuration?
Any guidance on how to correctly bring up this camera would be greatly appreciated.
