Can not get CSI camera to work with Orin Nano
I have Jetson Orin Nano board with JetPack 6.1 installed. I configured CSI Camera PINs using ArduCam guidance. My camera is this ONE and my setup is attached. I get
:794 No cameras available
error when I use python3 simple_camera.py from CSI-Camera repo
I tried the PIN settings with
IMX477-C
IMX477-A
IMX477-Dual
hello onder.secen,
could you please gather the kernel init messages for checking device registration status. i.e. $ dmesg > klogs.txt
Hi @onder.secen
The cable to the camera might be flipped over to the wrong side. Try to disconnect the cable, flip it over, and reconnect.
@JerryChang Please find the attached kernel logs.
klogs.txt (60.9 KB)
hello onder.secen,
it’s camera device detection has failed.
[   11.967371] imx477 9-001a: imx477_board_setup: error during i2c read probe (-121)
[   11.967405] imx477 9-001a: board setup failed
[   11.967480] imx477: probe of 9-001a failed with error -121
you may check with sensor vendor, for instance, please confirm you’re using supported sensor driver.
