Jetpack 6.0 connect IMX477 camerea facing issue in initialising
Hardware - GPU(Jetson orion nano)
Hardware - CPU
Operating System
Riva Version
TLT Version (if relevant)
How to reproduce the issue ? (This is for errors. Please share the command and the detailed log here)
Log
v4l2-ctl --list-devices
NVIDIA Tegra Video Input Device (platform:tegra-camrtc-ca):
/dev/media0
Cannot open device /dev/video0, exiting.
hello madz.moody,
may I double check the camera module you’re working with? for instance, is it Raspberry Pi High Quality Camera, IMX477?
besides, it’s by default recognize Raspberry Pi, IMX219 as camera device,
you may also running with Jetson-IO to configure CSI connector to enable IMX477 supports.
yes , Arducam HQ Camera (12.3MP 1/2.3-inch IMX477) with 6mm CS Mount Lens.
here is the log i down graded to jetpack 5.1 still iam facing the issue
![Screenshot from 2024-12-24 12-24-59|690x214](upload://65cWr3gFkJic65
Screenshot from 2024-12-24 12-28-14
RzYC30AzjorZm.png)
so i have followed few step adding enabling gpio , spi and configuring CSI using jetson-io still iam not able to solve problem.
there’re board setup failures, it’s likely hardware issue, please contact with sensor vendor for further support.
Noted ,and Thanks for support
