Worker: nvcr.io/nvidia/aerial/aodt-sim-runtime:1.5.1 (aodt 1.5.1, CUDA 12.9.1), Driver 595.71.05, Ubuntu 22.04 host, single H100. I know from the earlier thread that H100 is not a qualified GPU for 1.5.1; both issues below are CPU-side and do not touch the GPU. Client: dt-client 0.1.0Editable install from the 1.5 client repo, remote gRPC transport.
Batched EM run, 42 RUs, 285 UEs, 1 tile (35,688 buildings, 4.1M triangles), 2 time steps, duration/interval timeline, non-RAN mode. Two runs: first with cirs and raypaths opted in, second with raypaths (full) only.
Run 1: cirs + raypaths. Write phase never finished
EM solve was fine: ~13.3 s and ~13.8 s per time step, ~12.05M paths per step, 57 GB on the GPU.
Log timeline:
14:04:22 [time_sample=0] Adding 12054318 cir results to cirs table
14:04:43 [time_sample=1] Adding 12054318 cir results to cirs table
14:04:29 Finalizing simulation and writing results to DB
14:04:29 Waiting for all DB writes to complete before Parquet flush...
After that, only the 30 s NVML heartbeat for two hours. Two DB worker processes (one per time step), each at 100% of one core, ~117 min CPU each when I killed them. Zero rows in cirs or raypaths in ClickHouse, no INSERT in system.query_log, no socket writes in strace. Not the database.
perf top on a DB worker:
95.51% libclickhouse.so [.] 0x2c868
2.89% libclickhouse.so [.] 0x2c883
0.50% libclickhouse.so [.] 0x2c87d
objdump resolves that to insertCIRs(db_settings const&, std::vector<emsolver::RayPath> const&, std::vector<TXInfo> const&, std::vector<RXInfo> const&, std::vector<unsigned> const&, std::vector<std::vector<unsigned>> const&, bool, int), hot loop:
2c868: add $0x228,%rbx ; next RayPath, sizeof = 552
2c86f: cmp %rbx,%r14 ; end?
2c878: cmp %eax,(%rbx) ; field @0x00
2c88a: cmp %eax,0x4(%rbx) ; field @0x04
2c893: cmp 0x8(%rbx),%eax ; field @0x08
2c89c: cmp 0xc(%rbx),%eax ; field @0x0c
2c8a5: cmp 0x10(%rbx),%eax ; field @0x10
2c8ae: cmp 0x14(%rbx),%eax ; field @0x14
A linear scan over the entire RayPath vector matching six integer fields, once per link and antenna pair. For this scene, that is 42 x 285 x 4 element pairs = ~48k full passes over a 12M element, 6.6 GB array per time step. At that memory bandwidth, that is many hours per step, which matches what I saw. The bool argument (first antenna pair only) divides the pass count by 4, making it unusable for bulk export.
Run 2: raypaths (full) only. Write phase completes in ~90 s
Same scene, cirs removed from opt_in_tables, raypaths: full kept.
17:24:19 Finalizing simulation and writing results to DB
17:24:19 [time_sample=0] Adding 12054318 ray results to raypaths table
17:24:19 Waiting for all DB writes to complete before Parquet flush...
17:24:19 [time_sample=1] Adding 12054318 ray results to raypaths table
17:25:48 [time_sample=0] Rays insert took 89035.6 ms
17:25:48 [time_sample=1] Rays insert took 81367.2 ms
17:26:02 Exported raypaths t0-2: 24108636 rows in 6260.7ms
Both steps inserted in parallel, ~85 s each for 12.05M rows. Parquet export of all 24,108,636 rows took 6.3 s and produced a 983 MiB file with per-path points, normals, interaction_types, prim_ids, and complex amplitude per (ru_ant_el, ue_ant_el) pair. So insertRaypaths is linear and the problem is confined to insertCIRs.
The second arm of the same tile (different tilts, otherwise identical) went load 21.7 s, solve 146 s, insert ~85 s per step, export 23,785,742 rows in 6.1 s. About 3 minutes end-to-end, whereas the first attempt did not finish in 2 hours.
For my purposes, this is the workaround: delay and gain per path are already in the raypaths Parquet, so I can bin CIRs myself in pandas without touching insertCIRs. I will cross-check against Interactive Mode get_cirs on a small subset.
Secondary issue, both runs: 30 min scenario load is node placement
client.start() took 1.955e6 ms (32.6 min) on run 1 and 1.811e6 ms (30.2 min) on run 2 for a 146 KB YAML. Main worker process at 100% of one core the whole time, ~140 other threads busy-waiting. Meshes then loaded in 4.4 s.
Three py-spy dumps of the main worker process during the load, 90 s apart, all show the same stack:
_find_downward_projection aodt/stage/world_reader.py:328
get_z_from_x_y_per_tile aodt/stage/world_reader.py:574
get_z_from_x_y aodt/stage/world_reader.py:480
proj_point_to_cartesian aodt/fetcher/world_prim.py:130
deploy_nodes_from_sim_config aodt/fetcher/node_prim.py:439
Locals in get_z_from_x_y_per_tile: include_buildings: True, buildings = a list of every building prim in the tile. For each 2D node, it shoots one downward ray and calls _find_downward_projection once per building prim through a BBoxCache, with no spatial index. That is 35,688 Python-level calls per node. 42 RUs + 285 UEs = 327 nodes, so ~11.7M calls, about 5.5 s per node. The busy threads are the TBB pool under BBoxCache computing bounds on the large meshes.
Workaround, confirmed on two loads: pass alt on every georeferenced node. That takes the dim: 3 branch in proj_point_to_cartesian, which still calls get_z_from_x_y but with include_buildings=False, so only the ground plane is tested. Same 42 RU / 285 UE scene, same tile, load went from 1.81e6 ms to 17,468 ms and 21,661 ms on two runs. RU z in rus.parquet is identical (1250 stage units) either way, so the fast path lands nodes in the same place; alt must be 0.0 because the node height attributes (aerial_gnb_height, set_ues_height) are applied on top of it. Cartesian points with z skip projection entirely.
Suggested fix: build a BVH or a 2D grid over building footprints per tile once at scene load and query that per node.
Questions
- Is the
insertCIRspattern known, and does 1.6 change the CIR export path? A single bucketing pass by (link, antenna pair) before the per-link loop would make it linear. - Is Interactive Mode (
allocate_cirs_memory/get_cirs/to_numpy_all_cir/export_results) the intended route for bulk CIR extraction at this scale in the meantime, or is reconstructing from the raypaths Parquet the expected approach?
Full worker logs, perf / objdump output, and the py-spy dumps available on request.
