Applications not using GPU inside docker container
Hi everyone,
I’ve been trying to make my GPU be utilized when using any graphical application from inside of the docker container, but with no success so far. Posting this as an issue since I’ve followed the instructions here to the letter but still failed to make progress.
My setup:
Ubuntu on the host: 20.04.6 LTS
Nvidia driver version: 525.147.05
Cuda version: 12.0
kernel version: 5.15.0-97-generic
nvidia-container-toolskit version: 1.15.0-rc.3
docker version: 24.0.4
nvidia-docker2 version: 2.14.0-1
I’ve been trying to run the container as follows:
docker run -it --rm --privileged -e DISPLAY=$DISPLAY --runtime=nvidia --gpus all -v /tmp/.X11-unix:/tmp/.X11-unix nvidia/cuda:11.6.2-base-ubuntu20.04 bash
after which, when I run nvidia-smi I do get the expected output:
Tue Mar 12 15:10:54 2024
| NVIDIA-SMI 525.147.05   Driver Version: 525.147.05   CUDA Version: 12.0     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|                               |                      |               MIG M. |
|   0  NVIDIA RTX A300...  Off  | 00000000:01:00.0 Off |                  N/A |
| N/A   53C    P8    13W /  80W |    552MiB /  6144MiB |     17%      Default |
|                               |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                  GPU Memory |
|        ID   ID                                                   Usage      |
However, when I install glmark2 and run it it does not utilize the GPU at all. Moreover, after installing nvidia-settings and nvidia-prime I do not see an option to switch nvidia prime to performace mode in the nvidia settings (I should not that after switching that on my host the GPU started being utilized).
Anyone has any ideas on what is going on and what I might be doing wrong? I’d appreciate any help, running out of ideas here.
Thanks in advance,
Michal
I’m having similar problem with Docker:
I get the following at the terminal:
| NVIDIA-SMI 550.54.15              Driver Version: 550.54.15      CUDA Version: 12.4     |
|   0  NVIDIA GeForce RTX 4060        On  |   00000000:01:00.0 Off |                  N/A |
|  0%   42C    P8             N/A /  115W |       1MiB /   8188MiB |      0%      Default |
|                                         |                        |                  N/A |
|   1  NVIDIA GeForce GTX 1080        On  |   00000000:81:00.0 Off |                  N/A |
| 24%   42C    P8              8W /  180W |       1MiB /   8192MiB |      0%      Default |
|                                         |                        |                  N/A |
| Processes:        |
|        ID   ID                                                               Usage      |
|  No running processes found                                                             |
This is what I get when I run nvidia-smi in docker:
docker run --rm -ti --runtime=nvidia -e NVIDIA_VISIBLE_DEVICES=all ubuntu nvidia-smi -L
Failed to initialize NVML: Unknown Error
Longshot but did you every get this working?
