Hello everyone!
I’m trying to make the NVIDIA GPU available into my Kubernetes cluster. For that, I followed the guide in https://kubernetes.io/docs/tasks/manage-gpus/scheduling-gpus/#deploying-nvidia-gpu-device-plugin. First thing, I ensured that all the Drivers and CUDA related things were installed into a node of the cluster, so I could run the nvidia-smi command there with success. Then I installed nvidia-docker2 in the node and the nvidia plugin into the Kubernetes cluster, so that the node can run containers using this runtime (also had to change the default runtime as mentioned in the guide).
After that I tested with the recommended nvidia/cuda:10.0-base image and tested with nvidia-smi command. Success! Everything work as expected:
| NVIDIA-SMI 430.64 Driver Version: 430.64 CUDA Version: 10.1 |
| 0 Tesla T4 On | 00000000:00:1E.0 Off | 0 |
| N/A 28C P8 9W / 70W | 0MiB / 15109MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| No running processes found |
Sure, no problem. However, with a real application, the GPU started to fail and I couldn’t train my Tensorflow model inside the container. Investigating it further, we figured that the issue is that the GPU start failing some time after the container starts. To reproduce the issue we ran the same image as above with the following command:
bash -c "for i in {0..360}; do echo $i; nvidia-smi; sleep 1; done"
And the nvidia-smi command starts failing after 3 to 5 tries:
0
Thu Mar 5 22:37:19 2020
1
Thu Mar 5 22:37:20 2020
2
Thu Mar 5 22:37:21 2020
3
Thu Mar 5 22:37:22 2020
4
Thu Mar 5 22:37:23 2020
5
Failed to initialize NVML: Unknown Error
6
7
8
Notice that we start seeing the following error after some time
We checked the persistence of the driver running nvidia-smi -q and it seems to report:
Persistence Mode : Enabled
This problem only happens inside the container and the node seems fine (kubernetes doesn’t report any errors and the command seems to still run fine inside the node, even after failing inside the container).
Do you have any idea what is happening?
