I opened an issue on NVIDIA docker’s GitHub, but in case that isn’t the proper place, I’m cross posting here.
I’m a complete newcomer to Docker, so the following questions might be a bit naive, but I’m stuck and I need help.
I’m trying to reproduce some results in research. The authors just released code along with a specification of how to build a Docker image to reproduce their results. The relevant bit is copied below:
I believe I installed Docker correctly:
$ docker --version
Docker version 19.03.13, build 4484c46d9d
$ sudo docker run hello-world
Hello from Docker!
This message shows that your installation appears to be working correctly.
To generate this message, Docker took the following steps:
1. The Docker client contacted the Docker daemon.
2. The Docker daemon pulled the "hello-world" image from the Docker Hub.
(amd64)
3. The Docker daemon created a new container from that image which runs the
executable that produces the output you are currently reading.
4. The Docker daemon streamed that output to the Docker client, which sent it
to your terminal.
To try something more ambitious, you can run an Ubuntu container with:
$ docker run -it ubuntu bash
Share images, automate workflows, and more with a free Docker ID:
https://hub.docker.com/
For more examples and ideas, visit:
https://docs.docker.com/get-started/
However, when I try checking that my nvidia-docker installation was successful, I get the following error:
$ sudo docker run --gpus all --rm nvidia/cuda:10.1-base nvidia-smi
docker: Error response from daemon: OCI runtime create failed: container_linux.go:349: starting container process caused "process_linux.go:449: container init caused \"process_linux.go:432: running prestart hook 0 caused \\\"error running hook: exit status 1, stdout: , stderr: nvidia-container-cli: initialization error: nvml error: driver not loaded\\\\n\\\"\"": unknown.
It looks the key error is
I don’t have a GPU locally and I’m finding conflicting information on whether CUDA needs to be installed before NVIDIA Docker. For instance, this NVIDIA moderator says “A proper nvidia docker plugin installation starts with a proper CUDA install on the base machine.”
My questions are the following:
- Can I install NVIDIA Docker without having CUDA installed?
- If so, what is the source of this error and how do I fix it?
- If not, how do I create this Docker image to reproduce the results?
