I have a Dockerhost with nvidia-docker2 on it (GitHub - NVIDIA/nvidia-docker: Build and run Docker containers leveraging NVIDIA GPUs)
I have successfully managed to develop, compile, and run a CUDA application inside a Docker container by using NVIDIAs devel docker container (Docker Hub). By using nvidia/cuda-devel as a base image, I was able to go into a running container and perform these tasks.
However, then I tried doing this from my own base image (not using nvidia/cuda), by installing CUDA as part of my dockerfile, logging into the container, then trying to compile my CUDA application. However, in this docker container, I cannot even run nvidia-SMI and get Failed to initialize NVML: Unknown Error.
Is the nvidia/cuda-devel base image doing something fancy to interact with the host, or some other critical step I am missing, other than just installing CUDA in the docker container? In their actual Dockerfile, I don’t see anything fancy going on: https://gitlab.com/nvidia/cuda/blob/ubuntu18.04/10.0/devel/Dockerfile
