Hi guys,
I’m trying to FT 2D arrays with cuFFT. I’m having trouble with certain sizes of my arrays.
I first detected the problem with and array of [20982x30978] and have found several others.
The code below is a simplified version of what I’m using. In this case cuFFT fails to create the
transform plan. I predefined four array sizes:
- [10983 x 10983]
- [11000 x 11000]
- [20982x30978]
- [21000x31000]
When using a GeForce GTX 1050 with 4Gib of memory, 1. and 3. fail with error code
CUFFT_ALLOC_FAILED, while 2. and 4. work fine.
When using a GeForce GTX Titan with 12GiG of memory, only 3 fails, again with
CUFFT_ALLOC_FAILED as error.
From the Titan’s output, I can see that the memory required for 1. is 3.9 MiB.
and for 4. is 1.8MiB. It seems that for “weird” image sizes it is required a huge
amount of memory.
So, my question, is it possible to know when the memory required is going to be super large?
just by having a look on the array dimensions?
Padding or cropping the array is an option for me, so it would be great to know which array
dimensions requires “acceptable” memory buffers.
I can always call one of the cuFFT methods to create a plan and check for CUFFT_ALLOC_FAILED,
but wondering if there is another option.
#include <iostream>
#include <vector>
#include <cufft.h>
bool createPlan( const unsigned f_width, const unsigned f_height,
const cufftType f_cufftType, size_t &f_workArea )
cufftHandle plan;
cufftResult_t err = cufftPlan2d( &plan, f_height, f_width, f_cufftType );
if( err != CUFFT_SUCCESS )
std::cout << "cufftPlan2d failed: " << err << '\n';
f_workArea = 0;
return false;
err = cufftGetSize( plan, &f_workArea );
std::cout << "cufftGetSize failed: " << err << '\n';
return false;
cufftDestroy( plan );
return true;
int main()
std::vector<unsigned> widths{ 10983, 11000, 20982, 21000 };
for( const auto& width : widths )
size_t workArea{ 0 };
if( !createPlan( width, width, CUFFT_R2C, workArea ) )
std::cout << "[" << width << " x " << width << "] failed\n";
continue;
std::cout << "Work area size [" << width << " x " << width << "] = " << workArea / 1000000 << "\n";
return 0;
Cheers,
Sandino
