Hello everybody,
I am going to run 2D complex-to-complex cuFFT on NVIDIA K40c consisting of 12 GB memory. However, there is a problem with cufftPlan2d for some sizes. For instance, for a given size of X=Y=22912, it ends up with CUFFT_ALLOC_FAILED error. It is noteworthy that the command works very well with larger size of X=Y= 23040. That is, the error does not occur because of memory leakage.
I tried to estimate the required size for performing FFT on a 2D matrix of 2291222912 using cufftEstimate2d(). It is surprisingly returns zero workload size, but the output for 2304023040 is around 3.5 GB.
You can find the code following.
Regards,
Hamidreza
void fft_kernel_gpu_single_fit(const int M, const int N, cufftComplex *A, int tSize)
printf("fft_kernel_gpu_single_fit: M %d N %d\n", M, N);
cufftComplex *gpudata;
if (cudaMalloc((void**)&gpudata, tSize * sizeof(cufftComplex)) != CUFFT_SUCCESS)
fprintf(stderr, "cudaMalloc Error: Unable to alloc memory\n");
return;
if (cudaMemcpy(gpudata, A, tSize * sizeof(cufftComplex), cudaMemcpyHostToDevice) != CUFFT_SUCCESS)
fprintf(stderr, "cudaMemcpy Error: Unable to copy data from host to gpu\n");
return;
cufftHandle plan;
/*int n[2] = {M, N};
if (cufftPlanMany(&plan, 2, n, NULL, 1, 0, NULL, 1, 0, CUFFT_C2C, 1) != CUFFT_SUCCESS)
fprintf(stderr, "CUFFT Error: Unable to create plan\n");
return;
if (cufftPlan2d(&plan, M, N, CUFFT_C2C) != CUFFT_SUCCESS)
return;
if (cufftExecC2C(plan, gpudata, gpudata, CUFFT_FORWARD) != CUFFT_SUCCESS)
fprintf(stderr, "CUFFT Error: Unable to execute plan\n");
return;
if (cudaDeviceSynchronize() != cudaSuccess)
fprintf(stderr, "Cuda Error: Failed to synchronize\n");
return;
if (cudaMemcpy(A, gpudata, tSize * sizeof(cufftComplex), cudaMemcpyDeviceToHost) != CUFFT_SUCCESS)
fprintf(stderr, "cudaMemcpy Error: Unable to copy data from gpu to host\n");
return;
return;
cufftDestroy(plan);
cudaFree(gpudata);
