Edit : I found something, it doesn’t happen if nothing if fullscreened. It happened with youtube videos when they were fullscreened and it happened with games when they were full screened (Among Us crashed yesterday with full screen in like 2 minutes, but have been up for like 30 minutes after I disabled the fullscreen mode and its still in 1080p resolution, covering the entire screen, but windowed)
It usually happens when gaming or playing youtube videos (mostly when playing youtube videos in full screen). It has happened once or twice when doing literally nothing, just desktop idle showing. I checked journal ctl before crash and it said this repeatedly
kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
kwin_wayland_drm: Please report this at Linux - NVIDIA Developer Forums
kwin_wayland_drm: With the output of ‘sudo dmesg’ and ‘journalctl --user-unit plasma-kwin_wayland --boot 0’
Below is the result of “sudo dmesg” :
Summary
[ 0.020503] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[ 0.020506] ACPI: Using ACPI (MADT) for SMP configuration information
[ 0.020507] ACPI: HPET id: 0x10228201 base: 0xfed00000
[ 0.020517] e820: update [mem 0xb9379000-0xb93cffff] usable ==> reserved
[ 0.020532] CPU topo: Max. logical packages: 1
[ 0.020532] CPU topo: Max. logical dies: 1
[ 0.020533] CPU topo: Max. dies per package: 1
[ 0.020536] CPU topo: Max. threads per core: 2
[ 0.020536] CPU topo: Num. cores per package: 6
[ 0.020537] CPU topo: Num. threads per package: 12
[ 0.020537] CPU topo: Allowing 12 present CPUs plus 0 hotplug CPUs
[ 0.020538] CPU topo: Rejected CPUs 20
[ 0.020556] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.020557] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[ 0.020558] PM: hibernation: Registered nosave memory: [mem 0x09c1f000-0x09ffffff]
[ 0.020560] PM: hibernation: Registered nosave memory: [mem 0x0a200000-0x0a20dfff]
[ 0.020561] PM: hibernation: Registered nosave memory: [mem 0x0b000000-0x0b01ffff]
[ 0.020562] PM: hibernation: Registered nosave memory: [mem 0xb9379000-0xb93cffff]
[ 0.020563] PM: hibernation: Registered nosave memory: [mem 0xbb0c2000-0xbb0c2fff]
[ 0.020564] PM: hibernation: Registered nosave memory: [mem 0xbc730000-0xbddfefff]
[ 0.020565] PM: hibernation: Registered nosave memory: [mem 0xbf000000-0xffffffff]
[ 0.020566] [mem 0xc0000000-0xfe9fffff] available for PCI devices
[ 0.020567] Booting paravirtualized kernel on bare hardware
[ 0.020569] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1910969940391419 ns
[ 0.024902] setup_percpu: NR_CPUS:8192 nr_cpumask_bits:12 nr_cpu_ids:12 nr_node_ids:1
[ 0.025418] percpu: Embedded 67 pages/cpu s237568 r8192 d28672 u524288
[ 0.025423] pcpu-alloc: s237568 r8192 d28672 u524288 alloc=1*2097152
[ 0.025424] pcpu-alloc: [0] 00 01 02 03 [0] 04 05 06 07
[ 0.025427] pcpu-alloc: [0] 08 09 10 11
[ 0.025440] Kernel command line: initrd=\initramfs-linux.img root=PARTUUID=abb72c58-3924-4d49-ac97-9be1e9bfd17d rw nvidia-drm.modeset=1
[ 0.025487] printk: log buffer data + meta data: 131072 + 458752 = 589824 bytes
[ 0.026439] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.026876] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.026931] Fallback order for Node 0: 0
[ 0.026933] Built 1 zonelists, mobility grouping on. Total pages: 4180033
[ 0.026934] Policy zone: Normal
[ 0.027075] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
[ 0.027103] software IO TLB: area num 16.
[ 0.053887] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=12, Nodes=1
[ 0.053922] ftrace: allocating 55512 entries in 217 pages
[ 0.068482] ftrace: allocated 217 pages with 5 groups
[ 0.068547] Dynamic Preempt: full
[ 0.068590] rcu: Preemptible hierarchical RCU implementation.
[ 0.068591] rcu: RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=12.
[ 0.068592] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.068592] Trampoline variant of Tasks RCU enabled.
[ 0.068593] Rude variant of Tasks RCU enabled.
[ 0.068593] Tracing variant of Tasks RCU enabled.
[ 0.068594] rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies.
[ 0.068594] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=12
[ 0.068602] RCU Tasks: Setting shift to 4 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=12.
[ 0.068603] RCU Tasks Rude: Setting shift to 4 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=12.
[ 0.068605] RCU Tasks Trace: Setting shift to 4 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=12.
[ 0.072313] NR_IRQS: 524544, nr_irqs: 1064, preallocated irqs: 16
[ 0.072494] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.072581] kfence: initialized - using 2097152 bytes for 255 objects at 0x(ptrval)-0x(ptrval)
[ 0.072608] Console: colour dummy device 80x25
[ 0.072609] printk: legacy console [tty0] enabled
[ 0.072645] ACPI: Core revision 20240827
[ 0.072746] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484873504 ns
[ 0.072760] APIC: Switch to symmetric I/O mode setup
[ 0.073162] AMD-Vi: Using global IVHD EFR:0x0, EFR2:0x0
[ 0.240537] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.244751] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x6a78c066979, max_idle_ns: 881591064308 ns
[ 0.244755] Calibrating delay loop (skipped), value calculated using timer frequency.. 7386.47 BogoMIPS (lpj=3693236)
[ 0.244767] x86/cpu: User Mode Instruction Prevention (UMIP) activated
[ 0.244815] LVT offset 1 assigned for vector 0xf9
[ 0.244964] LVT offset 2 assigned for vector 0xf4
[ 0.245006] Last level iTLB entries: 4KB 512, 2MB 512, 4MB 256
[ 0.245007] Last level dTLB entries: 4KB 2048, 2MB 2048, 4MB 1024, 1GB 0
[ 0.245009] process: using mwait in idle threads
[ 0.245011] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.245012] Spectre V2 : Mitigation: Retpolines
[ 0.245013] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.245013] Spectre V2 : Spectre v2 / SpectreRSB : Filling RSB on VMEXIT
[ 0.245014] Spectre V2 : Enabling Restricted Speculation for firmware calls
[ 0.245015] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.245015] Spectre V2 : User space: Mitigation: STIBP always-on protection
[ 0.245016] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
[ 0.245017] Speculative Return Stack Overflow: Mitigation: Safe RET
[ 0.245021] x86/fpu: Supporting XSAVE feature 0x001: ‘x87 floating point registers’
[ 0.245022] x86/fpu: Supporting XSAVE feature 0x002: ‘SSE registers’
[ 0.245023] x86/fpu: Supporting XSAVE feature 0x004: ‘AVX registers’
[ 0.245023] x86/fpu: Supporting XSAVE feature 0x200: ‘Protection Keys User registers’
[ 0.245024] x86/fpu: Supporting XSAVE feature 0x800: ‘Control-flow User registers’
[ 0.245025] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.245026] x86/fpu: xstate_offset[9]: 832, xstate_sizes[9]: 8
[ 0.245027] x86/fpu: xstate_offset[11]: 840, xstate_sizes[11]: 16
[ 0.245027] x86/fpu: Enabled xstate features 0xa07, context size is 856 bytes, using ‘compacted’ format.
[ 0.271347] Freeing SMP alternatives memory: 48K
[ 0.271351] pid_max: default: 32768 minimum: 301
[ 0.274576] LSM: initializing lsm=capability,landlock,lockdown,yama,bpf
[ 0.274655] landlock: Up and running.
[ 0.274658] Yama: becoming mindful.
[ 0.274888] LSM support for eBPF active
[ 0.274930] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.274946] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.377327] smpboot: CPU0: AMD Ryzen 5 5600X 6-Core Processor (family: 0x19, model: 0x21, stepping: 0x0)
[ 0.377576] Performance Events: Fam17h+ core perfctr, AMD PMU driver.
[ 0.377582] … version: 0
[ 0.377584] … bit width: 48
[ 0.377585] … generic registers: 6
[ 0.377586] … value mask: 0000ffffffffffff
[ 0.377587] … max period: 00007fffffffffff
[ 0.377588] … fixed-purpose events: 0
[ 0.377589] … event mask: 000000000000003f
[ 0.377670] signal: max sigframe size: 3376
[ 0.377721] rcu: Hierarchical SRCU implementation.
[ 0.377722] rcu: Max phase no-delay instances is 400.
[ 0.377753] Timer migration: 2 hierarchy levels; 8 children per group; 2 crossnode level
[ 0.381819] MCE: In-kernel MCE decoding enabled.
[ 0.381860] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.381957] smp: Bringing up secondary CPUs …
[ 0.382060] smpboot: x86: Booting SMP configuration:
[ 0.382062] … node #0, CPUs: #1 #2 #3 #4 #5 #6 #7 #8 #9 #10 #11
[ 0.392864] Spectre V2 : Update user space SMT mitigation: STIBP always-on
[ 0.397795] smp: Brought up 1 node, 12 CPUs
[ 0.397795] smpboot: Total of 12 processors activated (88637.66 BogoMIPS)
[ 0.399853] Memory: 16160340K/16720132K available (19197K kernel code, 2903K rwdata, 16272K rodata, 4528K init, 4964K bss, 539512K reserved, 0K cma-reserved)
[ 0.400067] devtmpfs: initialized
[ 0.400067] x86/mm: Memory block size: 128MB
[ 0.402067] ACPI: PM: Registering ACPI NVS region [mem 0x0a200000-0x0a20dfff] (57344 bytes)
[ 0.402067] ACPI: PM: Registering ACPI NVS region [mem 0xbcab4000-0xbd159fff] (6971392 bytes)
[ 0.402067] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.402067] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[ 0.402067] pinctrl core: initialized pinctrl subsystem
[ 0.402135] PM: RTC time: 07:00:51, date: 2025-05-01
[ 0.402894] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.403109] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[ 0.403183] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.403255] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.403263] audit: initializing netlink subsys (disabled)
[ 0.403271] audit: type=2000 audit(1746082851.164:1): state=initialized audit_enabled=0 res=1
[ 0.403271] thermal_sys: Registered thermal governor ‘fair_share’
[ 0.403271] thermal_sys: Registered thermal governor ‘bang_bang’
[ 0.403271] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.403271] thermal_sys: Registered thermal governor ‘user_space’
[ 0.403271] thermal_sys: Registered thermal governor ‘power_allocator’
[ 0.403271] cpuidle: using governor ladder
[ 0.403271] cpuidle: using governor menu
[ 0.403271] Detected 1 PCC Subspaces
[ 0.403271] Registering PCC driver as Mailbox controller
[ 0.403271] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.403771] PCI: ECAM [mem 0xf0000000-0xf7ffffff] (base 0xf0000000) for domain 0000 [bus 00-7f]
[ 0.403781] PCI: Using configuration type 1 for base access
[ 0.403922] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[ 0.409960] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.409963] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.409965] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.409966] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.410508] raid6: skipped pq benchmark and selected avx2x4
[ 0.410511] raid6: using avx2x2 recovery algorithm
[ 0.410612] ACPI: Added _OSI(Module Device)
[ 0.410614] ACPI: Added _OSI(Processor Device)
[ 0.410616] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.410618] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.438469] ACPI: 9 ACPI AML tables successfully acquired and loaded
[ 0.441028] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 0.455845] ACPI: Interpreter enabled
[ 0.455864] ACPI: PM: (supports S0 S3 S4 S5)
[ 0.455866] ACPI: Using IOAPIC for interrupt routing
[ 0.457703] PCI: Using host bridge windows from ACPI; if necessary, use “pci=nocrs” and report a bug
[ 0.457705] PCI: Using E820 reservations for host bridge windows
[ 0.458347] ACPI: Enabled 8 GPEs in block 00 to 1F
[ 0.475488] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.475494] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.475734] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR DPC]
[ 0.475746] acpi PNP0A08:00: [Firmware Info]: ECAM [mem 0xf0000000-0xf7ffffff] for domain 0000 [bus 00-7f] only partially covers this bridge
[ 0.476404] PCI host bridge to bus 0000:00
[ 0.476409] pci_bus 0000:00: root bus resource [io 0x0000-0x03af window]
[ 0.476411] pci_bus 0000:00: root bus resource [io 0x03e0-0x0cf7 window]
[ 0.476413] pci_bus 0000:00: root bus resource [io 0x03b0-0x03df window]
[ 0.476415] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.476417] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000dffff window]
[ 0.476419] pci_bus 0000:00: root bus resource [mem 0xc0000000-0xfec2ffff window]
[ 0.476421] pci_bus 0000:00: root bus resource [mem 0xfee00000-0xffffffff window]
[ 0.476423] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.476437] pci 0000:00:00.0: [1022:1480] type 00 class 0x060000 conventional PCI endpoint
[ 0.476547] pci 0000:00:00.2: [1022:1481] type 00 class 0x080600 conventional PCI endpoint
[ 0.476650] pci 0000:00:01.0: [1022:1482] type 00 class 0x060000 conventional PCI endpoint
[ 0.476720] pci 0000:00:01.2: [1022:1483] type 01 class 0x060400 PCIe Root Port
[ 0.476737] pci 0000:00:01.2: PCI bridge to [bus 01-05]
[ 0.476742] pci 0000:00:01.2: bridge window [io 0xf000-0xffff]
[ 0.476745] pci 0000:00:01.2: bridge window [mem 0xfc200000-0xfc8fffff]
[ 0.476762] pci 0000:00:01.2: enabling Extended Tags
[ 0.476817] pci 0000:00:01.2: PME# supported from D0 D3hot D3cold
[ 0.477009] pci 0000:00:02.0: [1022:1482] type 00 class 0x060000 conventional PCI endpoint
[ 0.477074] pci 0000:00:03.0: [1022:1482] type 00 class 0x060000 conventional PCI endpoint
[ 0.477138] pci 0000:00:03.1: [1022:1483] type 01 class 0x060400 PCIe Root Port
[ 0.477153] pci 0000:00:03.1: PCI bridge to [bus 06]
[ 0.477157] pci 0000:00:03.1: bridge window [io 0xe000-0xefff]
[ 0.477160] pci 0000:00:03.1: bridge window [mem 0xfb000000-0xfc0fffff]
[ 0.477167] pci 0000:00:03.1: bridge window [mem 0xd0000000-0xe1ffffff 64bit pref]
[ 0.477218] pci 0000:00:03.1: PME# supported from D0 D3hot D3cold
[ 0.478080] pci 0000:00:04.0: [1022:1482] type 00 class 0x060000 conventional PCI endpoint
[ 0.478147] pci 0000:00:05.0: [1022:1482] type 00 class 0x060000 conventional PCI endpoint
[ 0.478212] pci 0000:00:07.0: [1022:1482] type 00 class 0x060000 conventional PCI endpoint
[ 0.478274] pci 0000:00:07.1: [1022:1484] type 01 class 0x060400 PCIe Root Port
[ 0.478287] pci 0000:00:07.1: PCI bridge to [bus 07]
[ 0.478300] pci 0000:00:07.1: enabling Extended Tags
[ 0.478335] pci 0000:00:07.1: PME# supported from D0 D3hot D3cold
[ 0.478461] pci 0000:00:08.0: [1022:1482] type 00 class 0x060000 conventional PCI endpoint
[ 0.478525] pci 0000:00:08.1: [1022:1484] type 01 class 0x060400 PCIe Root Port
[ 0.478539] pci 0000:00:08.1: PCI bridge to [bus 08]
[ 0.478546] pci 0000:00:08.1: bridge window [mem 0xfca00000-0xfccfffff]
[ 0.478557] pci 0000:00:08.1: enabling Extended Tags
[ 0.478611] pci 0000:00:08.1: PME# supported from D0 D3hot D3cold
[ 0.478774] pci 0000:00:14.0: [1022:790b] type 00 class 0x0c0500 conventional PCI endpoint
[ 0.478888] pci 0000:00:14.3: [1022:790e] type 00 class 0x060100 conventional PCI endpoint
[ 0.479016] pci 0000:00:18.0: [1022:1440] type 00 class 0x060000 conventional PCI endpoint
[ 0.479058] pci 0000:00:18.1: [1022:1441] type 00 class 0x060000 conventional PCI endpoint
[ 0.479099] pci 0000:00:18.2: [1022:1442] type 00 class 0x060000 conventional PCI endpoint
[ 0.479140] pci 0000:00:18.3: [1022:1443] type 00 class 0x060000 conventional PCI endpoint
[ 0.479181] pci 0000:00:18.4: [1022:1444] type 00 class 0x060000 conventional PCI endpoint
[ 0.479221] pci 0000:00:18.5: [1022:1445] type 00 class 0x060000 conventional PCI endpoint
[ 0.479264] pci 0000:00:18.6: [1022:1446] type 00 class 0x060000 conventional PCI endpoint
[ 0.479305] pci 0000:00:18.7: [1022:1447] type 00 class 0x060000 conventional PCI endpoint
[ 0.479421] pci 0000:01:00.0: [1022:43ee] type 00 class 0x0c0330 PCIe Legacy Endpoint
[ 0.479460] pci 0000:01:00.0: BAR 0 [mem 0xfc8a0000-0xfc8a7fff 64bit]
[ 0.479473] pci 0000:01:00.0: enabling Extended Tags
[ 0.479532] pci 0000:01:00.0: PME# supported from D3hot D3cold
[ 0.479705] pci 0000:01:00.1: [1022:43eb] type 00 class 0x010601 PCIe Legacy Endpoint
[ 0.479748] pci 0000:01:00.1: BAR 5 [mem 0xfc880000-0xfc89ffff]
[ 0.479751] pci 0000:01:00.1: ROM [mem 0xfc800000-0xfc87ffff pref]
[ 0.479769] pci 0000:01:00.1: enabling Extended Tags
[ 0.479817] pci 0000:01:00.1: PME# supported from D3hot D3cold
[ 0.479940] pci 0000:01:00.2: [1022:43e9] type 01 class 0x060400 PCIe Switch Upstream Port
[ 0.479966] pci 0000:01:00.2: PCI bridge to [bus 02-05]
[ 0.479973] pci 0000:01:00.2: bridge window [io 0xf000-0xffff]
[ 0.479977] pci 0000:01:00.2: bridge window [mem 0xfc200000-0xfc7fffff]
[ 0.479999] pci 0000:01:00.2: enabling Extended Tags
[ 0.480051] pci 0000:01:00.2: PME# supported from D3hot D3cold
[ 0.480186] pci 0000:00:01.2: PCI bridge to [bus 01-05]
[ 0.480339] pci 0000:02:00.0: [1022:43ea] type 01 class 0x060400 PCIe Switch Downstream Port
[ 0.480367] pci 0000:02:00.0: PCI bridge to [bus 03]
[ 0.480376] pci 0000:02:00.0: bridge window [mem 0xfc700000-0xfc7fffff]
[ 0.480399] pci 0000:02:00.0: enabling Extended Tags
[ 0.480460] pci 0000:02:00.0: PME# supported from D3hot D3cold
[ 0.480612] pci 0000:02:07.0: [1022:43ea] type 01 class 0x060400 PCIe Switch Downstream Port
[ 0.480639] pci 0000:02:07.0: PCI bridge to [bus 04]
[ 0.480648] pci 0000:02:07.0: bridge window [mem 0xfc200000-0xfc4fffff]
[ 0.480672] pci 0000:02:07.0: enabling Extended Tags
[ 0.480733] pci 0000:02:07.0: PME# supported from D3hot D3cold
[ 0.480877] pci 0000:02:08.0: [1022:43ea] type 01 class 0x060400 PCIe Switch Downstream Port
[ 0.480905] pci 0000:02:08.0: PCI bridge to [bus 05]
[ 0.480912] pci 0000:02:08.0: bridge window [io 0xf000-0xffff]
[ 0.480915] pci 0000:02:08.0: bridge window [mem 0xfc600000-0xfc6fffff]
[ 0.480939] pci 0000:02:08.0: enabling Extended Tags
[ 0.481000] pci 0000:02:08.0: PME# supported from D3hot D3cold
[ 0.481152] pci 0000:01:00.2: PCI bridge to [bus 02-05]
[ 0.481222] pci 0000:03:00.0: [1bb1:5013] type 00 class 0x010802 PCIe Endpoint
[ 0.481288] pci 0000:03:00.0: BAR 0 [mem 0xfc700000-0xfc703fff 64bit]
[ 0.481307] pci 0000:03:00.0: enabling Extended Tags
[ 0.481603] pci 0000:02:00.0: PCI bridge to [bus 03]
[ 0.481686] pci 0000:04:00.0: [14e4:43a0] type 00 class 0x028000 PCIe Endpoint
[ 0.481762] pci 0000:04:00.0: BAR 0 [mem 0xfc400000-0xfc407fff 64bit]
[ 0.481768] pci 0000:04:00.0: BAR 2 [mem 0xfc200000-0xfc3fffff 64bit]
[ 0.481944] pci 0000:04:00.0: supports D1 D2
[ 0.481946] pci 0000:04:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.482262] pci 0000:02:07.0: PCI bridge to [bus 04]
[ 0.482386] pci 0000:05:00.0: [10ec:8125] type 00 class 0x020000 PCIe Endpoint
[ 0.482455] pci 0000:05:00.0: BAR 0 [io 0xf000-0xf0ff]
[ 0.482462] pci 0000:05:00.0: BAR 2 [mem 0xfc600000-0xfc60ffff 64bit]
[ 0.482468] pci 0000:05:00.0: BAR 4 [mem 0xfc610000-0xfc613fff 64bit]
[ 0.482621] pci 0000:05:00.0: supports D1 D2
[ 0.482623] pci 0000:05:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.482965] pci 0000:02:08.0: PCI bridge to [bus 05]
[ 0.483064] pci 0000:06:00.0: [10de:2216] type 00 class 0x030000 PCIe Legacy Endpoint
[ 0.483089] pci 0000:06:00.0: BAR 0 [mem 0xfb000000-0xfbffffff]
[ 0.483092] pci 0000:06:00.0: BAR 1 [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.483096] pci 0000:06:00.0: BAR 3 [mem 0xe0000000-0xe1ffffff 64bit pref]
[ 0.483098] pci 0000:06:00.0: BAR 5 [io 0xe000-0xe07f]
[ 0.483101] pci 0000:06:00.0: ROM [mem 0xfc000000-0xfc07ffff pref]
[ 0.483150] pci 0000:06:00.0: PME# supported from D0 D3hot
[ 0.483333] pci 0000:06:00.1: [10de:1aef] type 00 class 0x040300 PCIe Endpoint
[ 0.483357] pci 0000:06:00.1: BAR 0 [mem 0xfc080000-0xfc083fff]
[ 0.483507] pci 0000:00:03.1: PCI bridge to [bus 06]
[ 0.483557] pci 0000:07:00.0: [1022:148a] type 00 class 0x130000 PCIe Endpoint
[ 0.483581] pci 0000:07:00.0: enabling Extended Tags
[ 0.483730] pci 0000:00:07.1: PCI bridge to [bus 07]
[ 0.483798] pci 0000:08:00.0: [1022:1485] type 00 class 0x130000 PCIe Endpoint
[ 0.483825] pci 0000:08:00.0: enabling Extended Tags
[ 0.483960] pci 0000:08:00.1: [1022:1486] type 00 class 0x108000 PCIe Endpoint
[ 0.483982] pci 0000:08:00.1: BAR 2 [mem 0xfcb00000-0xfcbfffff]
[ 0.483986] pci 0000:08:00.1: BAR 5 [mem 0xfcc08000-0xfcc09fff]
[ 0.483991] pci 0000:08:00.1: enabling Extended Tags
[ 0.484111] pci 0000:08:00.3: [1022:149c] type 00 class 0x0c0330 PCIe Endpoint
[ 0.484134] pci 0000:08:00.3: BAR 0 [mem 0xfca00000-0xfcafffff 64bit]
[ 0.484142] pci 0000:08:00.3: enabling Extended Tags
[ 0.484180] pci 0000:08:00.3: PME# supported from D0 D3hot D3cold
[ 0.484302] pci 0000:08:00.4: [1022:1487] type 00 class 0x040300 PCIe Endpoint
[ 0.484323] pci 0000:08:00.4: BAR 0 [mem 0xfcc00000-0xfcc07fff]
[ 0.484332] pci 0000:08:00.4: enabling Extended Tags
[ 0.484368] pci 0000:08:00.4: PME# supported from D0 D3hot D3cold
[ 0.484491] pci 0000:00:08.1: PCI bridge to [bus 08]
[ 0.484927] ACPI: PCI: Interrupt link LNKA configured for IRQ 0
[ 0.485003] ACPI: PCI: Interrupt link LNKB configured for IRQ 0
[ 0.485069] ACPI: PCI: Interrupt link LNKC configured for IRQ 0
[ 0.485148] ACPI: PCI: Interrupt link LNKD configured for IRQ 0
[ 0.485220] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
[ 0.485281] ACPI: PCI: Interrupt link LNKF configured for IRQ 0
[ 0.485341] ACPI: PCI: Interrupt link LNKG configured for IRQ 0
[ 0.485402] ACPI: PCI: Interrupt link LNKH configured for IRQ 0
[ 0.486765] iommu: Default domain type: Translated
[ 0.486765] iommu: DMA domain TLB invalidation policy: lazy mode
[ 0.486896] SCSI subsystem initialized
[ 0.486896] libata version 3.00 loaded.
[ 0.486896] ACPI: bus type USB registered
[ 0.486896] usbcore: registered new interface driver usbfs
[ 0.486896] usbcore: registered new interface driver hub
[ 0.486896] usbcore: registered new device driver usb
[ 0.486896] EDAC MC: Ver: 3.0.0
[ 0.486907] efivars: Registered efivars operations
[ 0.486982] NetLabel: Initializing
[ 0.486983] NetLabel: domain hash size = 128
[ 0.486985] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.487003] NetLabel: unlabeled traffic allowed by default
[ 0.487009] mctp: management component transport protocol core
[ 0.487010] NET: Registered PF_MCTP protocol family
[ 0.487020] PCI: Using ACPI for IRQ routing
[ 0.490719] PCI: pci_cache_line_size set to 64 bytes
[ 0.490778] e820: reserve RAM buffer [mem 0x09c1f000-0x0bffffff]
[ 0.490781] e820: reserve RAM buffer [mem 0x0a200000-0x0bffffff]
[ 0.490782] e820: reserve RAM buffer [mem 0x0b000000-0x0bffffff]
[ 0.490784] e820: reserve RAM buffer [mem 0xb119d018-0xb3ffffff]
[ 0.490785] e820: reserve RAM buffer [mem 0xb11c6018-0xb3ffffff]
[ 0.490787] e820: reserve RAM buffer [mem 0xb9379000-0xbbffffff]
[ 0.490788] e820: reserve RAM buffer [mem 0xbb0c2000-0xbbffffff]
[ 0.490789] e820: reserve RAM buffer [mem 0xbc730000-0xbfffffff]
[ 0.490791] e820: reserve RAM buffer [mem 0xbf000000-0xbfffffff]
[ 0.490792] e820: reserve RAM buffer [mem 0x43f380000-0x43fffffff]
[ 0.490863] pci 0000:06:00.0: vgaarb: setting as boot VGA device
[ 0.490863] pci 0000:06:00.0: vgaarb: bridge control possible
[ 0.490863] pci 0000:06:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[ 0.490863] vgaarb: loaded
[ 0.490863] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.490863] hpet0: 3 comparators, 32-bit 14.318180 MHz counter
[ 0.492820] clocksource: Switched to clocksource tsc-early
[ 0.492974] VFS: Disk quotas dquot_6.6.0
[ 0.492984] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.493003] pnp: PnP ACPI init
[ 0.493106] system 00:00: [mem 0xf0000000-0xf7ffffff] has been reserved
[ 0.493203] system 00:01: [mem 0xfd200000-0xfd2fffff] has been reserved
[ 0.493485] system 00:03: [io 0x0a00-0x0a2f] has been reserved
[ 0.493488] system 00:03: [io 0x0a30-0x0a3f] has been reserved
[ 0.493490] system 00:03: [io 0x0a40-0x0a4f] has been reserved
[ 0.493493] system 00:03: [mem 0xfe000000-0xfe00ffff] has been reserved
[ 0.493818] system 00:04: [io 0x04d0-0x04d1] has been reserved
[ 0.493820] system 00:04: [io 0x040b] has been reserved
[ 0.493822] system 00:04: [io 0x04d6] has been reserved
[ 0.493824] system 00:04: [io 0x0c00-0x0c01] has been reserved
[ 0.493826] system 00:04: [io 0x0c14] has been reserved
[ 0.493828] system 00:04: [io 0x0c50-0x0c51] has been reserved
[ 0.493830] system 00:04: [io 0x0c52] has been reserved
[ 0.493832] system 00:04: [io 0x0c6c] has been reserved
[ 0.493834] system 00:04: [io 0x0c6f] has been reserved
[ 0.493836] system 00:04: [io 0x0cd8-0x0cdf] has been reserved
[ 0.493838] system 00:04: [io 0x0800-0x089f] has been reserved
[ 0.493840] system 00:04: [io 0x0b00-0x0b0f] has been reserved
[ 0.493842] system 00:04: [io 0x0b20-0x0b3f] has been reserved
[ 0.493844] system 00:04: [io 0x0900-0x090f] has been reserved
[ 0.493846] system 00:04: [io 0x0910-0x091f] has been reserved
[ 0.493849] system 00:04: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.493851] system 00:04: [mem 0xfec01000-0xfec01fff] could not be reserved
[ 0.493853] system 00:04: [mem 0xfedc0000-0xfedc0fff] has been reserved
[ 0.493857] system 00:04: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.493859] system 00:04: [mem 0xfed80000-0xfed8ffff] could not be reserved
[ 0.493862] system 00:04: [mem 0xfec10000-0xfec10fff] has been reserved
[ 0.493864] system 00:04: [mem 0xff000000-0xffffffff] has been reserved
[ 0.494740] pnp: PnP ACPI: found 5 devices
[ 0.500697] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.500754] NET: Registered PF_INET protocol family
[ 0.500854] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.514161] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[ 0.514181] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.514234] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.514413] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[ 0.514532] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.514602] MPTCP token hash table entries: 16384 (order: 6, 393216 bytes, linear)
[ 0.514648] UDP hash table entries: 8192 (order: 7, 524288 bytes, linear)
[ 0.514707] UDP-Lite hash table entries: 8192 (order: 7, 524288 bytes, linear)
[ 0.514775] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.514782] NET: Registered PF_XDP protocol family
[ 0.514795] pci 0000:02:00.0: PCI bridge to [bus 03]
[ 0.514800] pci 0000:02:00.0: bridge window [mem 0xfc700000-0xfc7fffff]
[ 0.514809] pci 0000:02:07.0: PCI bridge to [bus 04]
[ 0.514814] pci 0000:02:07.0: bridge window [mem 0xfc200000-0xfc4fffff]
[ 0.514822] pci 0000:02:08.0: PCI bridge to [bus 05]
[ 0.514825] pci 0000:02:08.0: bridge window [io 0xf000-0xffff]
[ 0.514830] pci 0000:02:08.0: bridge window [mem 0xfc600000-0xfc6fffff]
[ 0.514838] pci 0000:01:00.2: PCI bridge to [bus 02-05]
[ 0.514841] pci 0000:01:00.2: bridge window [io 0xf000-0xffff]
[ 0.514846] pci 0000:01:00.2: bridge window [mem 0xfc200000-0xfc7fffff]
[ 0.514853] pci 0000:00:01.2: PCI bridge to [bus 01-05]
[ 0.514856] pci 0000:00:01.2: bridge window [io 0xf000-0xffff]
[ 0.514859] pci 0000:00:01.2: bridge window [mem 0xfc200000-0xfc8fffff]
[ 0.514865] pci 0000:00:03.1: PCI bridge to [bus 06]
[ 0.514867] pci 0000:00:03.1: bridge window [io 0xe000-0xefff]
[ 0.514871] pci 0000:00:03.1: bridge window [mem 0xfb000000-0xfc0fffff]
[ 0.514874] pci 0000:00:03.1: bridge window [mem 0xd0000000-0xe1ffffff 64bit pref]
[ 0.514878] pci 0000:00:07.1: PCI bridge to [bus 07]
[ 0.514884] pci 0000:00:08.1: PCI bridge to [bus 08]
[ 0.514888] pci 0000:00:08.1: bridge window [mem 0xfca00000-0xfccfffff]
[ 0.514893] pci_bus 0000:00: resource 4 [io 0x0000-0x03af window]
[ 0.514895] pci_bus 0000:00: resource 5 [io 0x03e0-0x0cf7 window]
[ 0.514897] pci_bus 0000:00: resource 6 [io 0x03b0-0x03df window]
[ 0.514899] pci_bus 0000:00: resource 7 [io 0x0d00-0xffff window]
[ 0.514901] pci_bus 0000:00: resource 8 [mem 0x000a0000-0x000dffff window]
[ 0.514903] pci_bus 0000:00: resource 9 [mem 0xc0000000-0xfec2ffff window]
[ 0.514904] pci_bus 0000:00: resource 10 [mem 0xfee00000-0xffffffff window]
[ 0.514906] pci_bus 0000:01: resource 0 [io 0xf000-0xffff]
[ 0.514908] pci_bus 0000:01: resource 1 [mem 0xfc200000-0xfc8fffff]
[ 0.514910] pci_bus 0000:02: resource 0 [io 0xf000-0xffff]
[ 0.514912] pci_bus 0000:02: resource 1 [mem 0xfc200000-0xfc7fffff]
[ 0.514914] pci_bus 0000:03: resource 1 [mem 0xfc700000-0xfc7fffff]
[ 0.514916] pci_bus 0000:04: resource 1 [mem 0xfc200000-0xfc4fffff]
[ 0.514917] pci_bus 0000:05: resource 0 [io 0xf000-0xffff]
[ 0.514919] pci_bus 0000:05: resource 1 [mem 0xfc600000-0xfc6fffff]
[ 0.514921] pci_bus 0000:06: resource 0 [io 0xe000-0xefff]
[ 0.514923] pci_bus 0000:06: resource 1 [mem 0xfb000000-0xfc0fffff]
[ 0.514925] pci_bus 0000:06: resource 2 [mem 0xd0000000-0xe1ffffff 64bit pref]
[ 0.514927] pci_bus 0000:08: resource 1 [mem 0xfca00000-0xfccfffff]
[ 0.515162] pci 0000:06:00.1: extending delay after power-on from D3hot to 20 msec
[ 0.515189] pci 0000:06:00.1: D0 power state depends on 0000:06:00.0
[ 0.515364] PCI: CLS 64 bytes, default 64
[ 0.515380] pci 0000:00:00.2: AMD-Vi: IOMMU performance counters supported
[ 0.515421] Trying to unpack rootfs image as initramfs…
[ 0.515433] pci 0000:00:00.0: Adding to iommu group 0
[ 0.515458] pci 0000:00:01.0: Adding to iommu group 1
[ 0.515480] pci 0000:00:01.2: Adding to iommu group 2
[ 0.515501] pci 0000:00:02.0: Adding to iommu group 3
[ 0.515522] pci 0000:00:03.0: Adding to iommu group 4
[ 0.515537] pci 0000:00:03.1: Adding to iommu group 5
[ 0.515557] pci 0000:00:04.0: Adding to iommu group 6
[ 0.515578] pci 0000:00:05.0: Adding to iommu group 7
[ 0.515600] pci 0000:00:07.0: Adding to iommu group 8
[ 0.515615] pci 0000:00:07.1: Adding to iommu group 9
[ 0.515636] pci 0000:00:08.0: Adding to iommu group 10
[ 0.515651] pci 0000:00:08.1: Adding to iommu group 11
[ 0.515679] pci 0000:00:14.0: Adding to iommu group 12
[ 0.515694] pci 0000:00:14.3: Adding to iommu group 12
[ 0.515762] pci 0000:00:18.0: Adding to iommu group 13
[ 0.515777] pci 0000:00:18.1: Adding to iommu group 13
[ 0.515791] pci 0000:00:18.2: Adding to iommu group 13
[ 0.515806] pci 0000:00:18.3: Adding to iommu group 13
[ 0.515820] pci 0000:00:18.4: Adding to iommu group 13
[ 0.515834] pci 0000:00:18.5: Adding to iommu group 13
[ 0.515850] pci 0000:00:18.6: Adding to iommu group 13
[ 0.515864] pci 0000:00:18.7: Adding to iommu group 13
[ 0.515899] pci 0000:01:00.0: Adding to iommu group 14
[ 0.515915] pci 0000:01:00.1: Adding to iommu group 14
[ 0.515933] pci 0000:01:00.2: Adding to iommu group 14
[ 0.515938] pci 0000:02:00.0: Adding to iommu group 14
[ 0.515944] pci 0000:02:07.0: Adding to iommu group 14
[ 0.515949] pci 0000:02:08.0: Adding to iommu group 14
[ 0.515955] pci 0000:03:00.0: Adding to iommu group 14
[ 0.515960] pci 0000:04:00.0: Adding to iommu group 14
[ 0.515967] pci 0000:05:00.0: Adding to iommu group 14
[ 0.515995] pci 0000:06:00.0: Adding to iommu group 15
[ 0.516012] pci 0000:06:00.1: Adding to iommu group 15
[ 0.516027] pci 0000:07:00.0: Adding to iommu group 16
[ 0.516043] pci 0000:08:00.0: Adding to iommu group 17
[ 0.516058] pci 0000:08:00.1: Adding to iommu group 18
[ 0.516074] pci 0000:08:00.3: Adding to iommu group 19
[ 0.516090] pci 0000:08:00.4: Adding to iommu group 20
[ 0.517704] AMD-Vi: Extended features (0x58f77ef22294a5a, 0x0): PPR NX GT IA PC GA_vAPIC
[ 0.517712] AMD-Vi: Interrupt remapping enabled
[ 0.517791] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.517793] software IO TLB: mapped [mem 0x00000000b4b00000-0x00000000b8b00000] (64MB)
[ 0.517830] LVT offset 0 assigned for vector 0x400
[ 0.518675] perf: AMD IBS detected (0x000003ff)
[ 0.518680] perf/amd_iommu: Detected AMD IOMMU #0 (2 banks, 4 counters/bank).
[ 0.539382] Initialise system trusted keyrings
[ 0.539391] Key type blacklist registered
[ 0.539435] workingset: timestamp_bits=36 max_order=22 bucket_order=0
[ 0.539698] fuse: init (API version 7.42)
[ 0.539775] integrity: Platform Keyring initialized
[ 0.539779] integrity: Machine keyring initialized
[ 0.549401] xor: automatically using best checksumming function avx
[ 0.549403] Key type asymmetric registered
[ 0.549404] Asymmetric key parser ‘x509’ registered
[ 0.549422] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 0.549469] io scheduler mq-deadline registered
[ 0.549470] io scheduler kyber registered
[ 0.549479] io scheduler bfq registered
[ 0.550469] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.550570] pcieport 0000:00:01.2: PME: Signaling with IRQ 27
[ 0.550635] pcieport 0000:00:01.2: AER: enabled with IRQ 27
[ 0.550770] pcieport 0000:00:03.1: PME: Signaling with IRQ 28
[ 0.550832] pcieport 0000:00:03.1: AER: enabled with IRQ 28
[ 0.551032] pcieport 0000:00:07.1: PME: Signaling with IRQ 30
[ 0.551096] pcieport 0000:00:07.1: AER: enabled with IRQ 30
[ 0.551210] pcieport 0000:00:08.1: PME: Signaling with IRQ 31
[ 0.551272] pcieport 0000:00:08.1: AER: enabled with IRQ 31
[ 0.551927] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.552049] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 0.552070] ACPI: button: Power Button [PWRB]
[ 0.552107] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 0.555489] ACPI: button: Power Button [PWRF]
[ 0.556192] Could not retrieve perf counters (-19)
[ 0.556433] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.558395] Non-volatile memory driver v1.3
[ 0.558397] Linux agpgart interface v0.103
[ 0.608510] tpm_crb MSFT0101:00: Disabling hwrng
[ 0.608770] ACPI: bus type drm_connector registered
[ 0.610272] ahci 0000:01:00.1: version 3.0
[ 0.610404] ahci 0000:01:00.1: SSS flag set, parallel bus scan disabled
[ 0.610450] ahci 0000:01:00.1: AHCI vers 0001.0301, 32 command slots, 6 Gbps, SATA mode
[ 0.610453] ahci 0000:01:00.1: 6/6 ports implemented (port mask 0x3f)
[ 0.610456] ahci 0000:01:00.1: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part sxs deso sadm sds apst
[ 0.610934] scsi host0: ahci
[ 0.611040] scsi host1: ahci
[ 0.611133] scsi host2: ahci
[ 0.611218] scsi host3: ahci
[ 0.611312] scsi host4: ahci
[ 0.611404] scsi host5: ahci
[ 0.611439] ata1: SATA max UDMA/133 abar m131072@0xfc880000 port 0xfc880100 irq 39 lpm-pol 3
[ 0.611443] ata2: SATA max UDMA/133 abar m131072@0xfc880000 port 0xfc880180 irq 39 lpm-pol 3
[ 0.611445] ata3: SATA max UDMA/133 abar m131072@0xfc880000 port 0xfc880200 irq 39 lpm-pol 3
[ 0.611447] ata4: SATA max UDMA/133 abar m131072@0xfc880000 port 0xfc880280 irq 39 lpm-pol 3
[ 0.611449] ata5: SATA max UDMA/133 abar m131072@0xfc880000 port 0xfc880300 irq 39 lpm-pol 3
[ 0.611451] ata6: SATA max UDMA/133 abar m131072@0xfc880000 port 0xfc880380 irq 39 lpm-pol 3
[ 0.611581] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 0.611586] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 0.640097] Freeing initrd memory: 124080K
[ 0.666905] xhci_hcd 0000:01:00.0: hcc params 0x0200ef81 hci version 0x110 quirks 0x0000000000000010
[ 0.667235] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 0.667239] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 0.667243] xhci_hcd 0000:01:00.0: Host supports USB 3.1 Enhanced SuperSpeed
[ 0.667314] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.14
[ 0.667317] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.667319] usb usb1: Product: xHCI Host Controller
[ 0.667321] usb usb1: Manufacturer: Linux 6.14.4-arch1-1 xhci-hcd
[ 0.667323] usb usb1: SerialNumber: 0000:01:00.0
[ 0.667448] hub 1-0:1.0: USB hub found
[ 0.667463] hub 1-0:1.0: 10 ports detected
[ 0.667875] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 0.667900] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.14
[ 0.667903] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.667904] usb usb2: Product: xHCI Host Controller
[ 0.667906] usb usb2: Manufacturer: Linux 6.14.4-arch1-1 xhci-hcd
[ 0.667908] usb usb2: SerialNumber: 0000:01:00.0
[ 0.667986] hub 2-0:1.0: USB hub found
[ 0.667996] hub 2-0:1.0: 4 ports detected
[ 0.668277] xhci_hcd 0000:08:00.3: xHCI Host Controller
[ 0.668282] xhci_hcd 0000:08:00.3: new USB bus registered, assigned bus number 3
[ 0.668385] xhci_hcd 0000:08:00.3: hcc params 0x0278ffe5 hci version 0x110 quirks 0x0000000000000010
[ 0.668642] xhci_hcd 0000:08:00.3: xHCI Host Controller
[ 0.668645] xhci_hcd 0000:08:00.3: new USB bus registered, assigned bus number 4
[ 0.668648] xhci_hcd 0000:08:00.3: Host supports USB 3.1 Enhanced SuperSpeed
[ 0.668683] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.14
[ 0.668685] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.668687] usb usb3: Product: xHCI Host Controller
[ 0.668689] usb usb3: Manufacturer: Linux 6.14.4-arch1-1 xhci-hcd
[ 0.668691] usb usb3: SerialNumber: 0000:08:00.3
[ 0.668780] hub 3-0:1.0: USB hub found
[ 0.668788] hub 3-0:1.0: 4 ports detected
[ 0.668999] usb usb4: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 0.669023] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.14
[ 0.669025] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.669027] usb usb4: Product: xHCI Host Controller
[ 0.669029] usb usb4: Manufacturer: Linux 6.14.4-arch1-1 xhci-hcd
[ 0.669030] usb usb4: SerialNumber: 0000:08:00.3
[ 0.669109] hub 4-0:1.0: USB hub found
[ 0.669117] hub 4-0:1.0: 4 ports detected
[ 0.669362] usbcore: registered new interface driver usbserial_generic
[ 0.669368] usbserial: USB Serial support registered for generic
[ 0.669435] rtc_cmos 00:02: RTC can wake from S4
[ 0.669634] rtc_cmos 00:02: registered as rtc0
[ 0.669658] rtc_cmos 00:02: setting system clock to 2025-05-01T07:00:51 UTC (1746082851)
[ 0.669683] rtc_cmos 00:02: alarms up to one month, y3k, 114 bytes nvram
[ 0.669726] amd_pstate: the _CPC object is not present in SBIOS or ACPI disabled
[ 0.669931] efifb: probing for efifb
[ 0.669940] efifb: framebuffer at 0xd0000000, using 3072k, total 3072k
[ 0.669942] efifb: mode is 1024x768x32, linelength=4096, pages=1
[ 0.669944] efifb: scrolling: redraw
[ 0.669945] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.669979] fbcon: Deferring console take-over
[ 0.669980] fb0: EFI VGA frame buffer device
[ 0.670007] hid: raw HID events driver (C) Jiri Kosina
[ 0.670067] drop_monitor: Initializing network drop monitor service
[ 0.670168] NET: Registered PF_INET6 protocol family
[ 0.675903] Segment Routing with IPv6
[ 0.675906] RPL Segment Routing with IPv6
[ 0.675919] In-situ OAM (IOAM) with IPv6
[ 0.675945] NET: Registered PF_PACKET protocol family
[ 0.676861] microcode: Current revision: 0x0a20102d
[ 0.676863] microcode: Updated early from: 0x0a201016
[ 0.677050] resctrl: L3 allocation detected
[ 0.677052] resctrl: MB allocation detected
[ 0.677053] resctrl: L3 monitoring detected
[ 0.677075] IPI shorthand broadcast: enabled
[ 0.679414] sched_clock: Marking stable (513006853, 166236627)->(691321691, -12078211)
[ 0.679556] registered taskstats version 1
[ 0.679916] Loading compiled-in X.509 certificates
[ 0.685135] Loaded X.509 cert ‘Build time autogenerated kernel key: 70e4eca6c722d62622e1aefc991ebc30e5d5af29’
[ 0.689303] zswap: loaded using pool zstd/zsmalloc
[ 0.689350] Demotion targets for Node 0: null
[ 0.689482] Key type .fscrypt registered
[ 0.689483] Key type fscrypt-provisioning registered
[ 0.690058] Btrfs loaded, zoned=yes, fsverity=yes
[ 0.690143] integrity: Loading X.509 certificate: UEFI:db
[ 0.690162] integrity: Loaded X.509 cert ‘Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4’
[ 0.690164] integrity: Loading X.509 certificate: UEFI:db
[ 0.690180] integrity: Loaded X.509 cert ‘Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53’
[ 0.691309] PM: Magic number: 9:768:14
[ 0.691375] memory memory58: hash matches
[ 0.694883] RAS: Correctable Errors collector initialized.
[ 0.707386] clk: Disabling unused clocks
[ 0.707388] PM: genpd: Disabling unused power domains
[ 0.964660] usb 1-6: new high-speed USB device number 2 using xhci_hcd
[ 1.079862] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.107653] ata1.00: ATA-10: ST2000DM005-2U9102, 0001, max UDMA/133
[ 1.116747] ata1.00: 3907029168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[ 1.165759] ata1.00: configured for UDMA/133
[ 1.174294] usb 1-6: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
[ 1.174297] usb 1-6: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.174299] usb 1-6: Product: USB2.0 Hub
[ 1.174935] scsi 0:0:0:0: Direct-Access ATA ST2000DM005-2U91 0001 PQ: 0 ANSI: 5
[ 1.175183] sd 0:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
[ 1.175187] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 1.175195] sd 0:0:0:0: [sda] Write Protect is off
[ 1.175197] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.175209] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 1.175230] sd 0:0:0:0: [sda] Preferred minimum I/O size 4096 bytes
[ 1.181317] hub 1-6:1.0: USB hub found
[ 1.185282] hub 1-6:1.0: 4 ports detected
[ 1.210459] sda: sda1 sda2
[ 1.210524] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.378244] usb 1-7: new full-speed USB device number 3 using xhci_hcd
[ 1.483348] ata2: SATA link down (SStatus 0 SControl 300)
[ 1.550276] tsc: Refined TSC clocksource calibration: 3693.061 MHz
[ 1.550281] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x6a7777116fa, max_idle_ns: 881590883556 ns
[ 1.550298] clocksource: Switched to clocksource tsc
[ 1.718243] usb 1-6.2: new full-speed USB device number 4 using xhci_hcd
[ 1.753043] usb 1-7: New USB device found, idVendor=048d, idProduct=5702, bcdDevice= 0.01
[ 1.753047] usb 1-7: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.753048] usb 1-7: Product: ITE Device
[ 1.753050] usb 1-7: Manufacturer: ITE Tech. Inc.
[ 1.942251] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.942893] ata3.00: ATA-8: ST1000DM010-2EP102, CC46, max UDMA/133
[ 1.943094] ata3.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[ 1.944110] ata3.00: configured for UDMA/133
[ 1.954364] scsi 2:0:0:0: Direct-Access ATA ST1000DM010-2EP1 CC46 PQ: 0 ANSI: 5
[ 1.954590] sd 2:0:0:0: [sdb] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 1.954593] sd 2:0:0:0: [sdb] 4096-byte physical blocks
[ 1.954601] sd 2:0:0:0: [sdb] Write Protect is off
[ 1.954603] sd 2:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 1.954615] sd 2:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 1.954636] sd 2:0:0:0: [sdb] Preferred minimum I/O size 4096 bytes
[ 2.005684] sdb: sdb1 sdb2
[ 2.005757] sd 2:0:0:0: [sdb] Attached SCSI disk
[ 2.085246] usb 1-9: new full-speed USB device number 5 using xhci_hcd
[ 2.226215] usb 1-6.2: New USB device found, idVendor=03f0, idProduct=0b92, bcdDevice=41.02
[ 2.226218] usb 1-6.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.226220] usb 1-6.2: Product: HyperX Virtual Surround Sound
[ 2.226222] usb 1-6.2: Manufacturer: HP, Inc
[ 2.226224] usb 1-6.2: SerialNumber: 00000000
[ 2.259354] ata4: SATA link down (SStatus 0 SControl 300)
[ 2.419245] usb 1-6.3: new full-speed USB device number 6 using xhci_hcd
[ 2.447725] usb 1-9: New USB device found, idVendor=2516, idProduct=0165, bcdDevice= 7.10
[ 2.447728] usb 1-9: New USB device strings: Mfr=3, Product=1, SerialNumber=0
[ 2.447730] usb 1-9: Product: MM730 Gaming Mouse
[ 2.447731] usb 1-9: Manufacturer: Cooler Master Technology Inc.
[ 2.612196] usb 1-6.3: not running at top speed; connect to a high speed hub
[ 2.642195] usb 1-6.3: New USB device found, idVendor=320f, idProduct=5000, bcdDevice= 1.02
[ 2.642197] usb 1-6.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.642199] usb 1-6.3: Product: RGB Keyboard
[ 2.642201] usb 1-6.3: Manufacturer: Evision
[ 2.779245] usb 1-10: new high-speed USB device number 7 using xhci_hcd
[ 2.985218] usb 1-10: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
[ 2.985221] usb 1-10: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.985223] usb 1-10: Product: USB2.0 Hub
[ 2.996203] hub 1-10:1.0: USB hub found
[ 3.000176] hub 1-10:1.0: 4 ports detected
[ 3.038245] usb 1-6.4: new full-speed USB device number 8 using xhci_hcd
[ 3.287163] usb 1-6.4: New USB device found, idVendor=17a0, idProduct=0310, bcdDevice= 1.00
[ 3.287166] usb 1-6.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.287168] usb 1-6.4: Product: Samson Meteor Mic
[ 3.287170] usb 1-6.4: Manufacturer: Samson Technologies
[ 3.294243] ata5: failed to resume link (SControl 0)
[ 3.294257] ata5: SATA link down (SStatus 0 SControl 0)
[ 3.334248] usb 1-10.4: new full-speed USB device number 9 using xhci_hcd
[ 3.646145] usb 1-10.4: New USB device found, idVendor=1e71, idProduct=2006, bcdDevice= 2.00
[ 3.646149] usb 1-10.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.646151] usb 1-10.4: Product: NZXT USB Device
[ 3.646152] usb 1-10.4: Manufacturer: NZXT. - Inc.
[ 3.646154] usb 1-10.4: SerialNumber: 00000000001A
[ 4.334243] ata6: failed to resume link (SControl 0)
[ 4.334257] ata6: SATA link down (SStatus 0 SControl 0)
[ 4.335333] Freeing unused decrypted memory: 2028K
[ 4.335891] Freeing unused kernel image (initmem) memory: 4528K
[ 4.335906] Write protecting the kernel read-only data: 36864k
[ 4.336330] Freeing unused kernel image (text/rodata gap) memory: 1280K
[ 4.336372] Freeing unused kernel image (rodata/data gap) memory: 112K
[ 4.383471] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 4.383475] rodata_test: all tests were successful
[ 4.383478] Run /init as init process
[ 4.383480] with arguments:
[ 4.383481] /init
[ 4.383483] with environment:
[ 4.383484] HOME=/
[ 4.383485] TERM=linux
[ 4.397961] fbcon: Taking over console
[ 4.398075] Console: switching to colour frame buffer device 128x48
[ 4.428459] nvidia: loading out-of-tree module taints kernel.
[ 4.428468] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 4.544154] nvidia-nvlink: Nvlink Core is being initialized, major device number 240
[ 4.545275] nvidia 0000:06:00.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=none:owns=none
[ 4.597269] NVRM: loading NVIDIA UNIX Open Kernel Module for x86_64 570.144 Release Build (archlinux-builder@echo archlinux)
[ 4.639120] nvidia-modeset: Loading NVIDIA UNIX Open Kernel Mode Setting Driver for x86_64 570.144 Release Build (archlinux-builder@echo archlinux)
[ 4.774955] [drm] [nvidia-drm] [GPU ID 0x00000600] Loading driver
[ 6.514103] [drm] Initialized nvidia-drm 0.0.0 for 0000:06:00.0 on minor 0
[ 6.514179] Console: switching to colour dummy device 80x25
[ 6.514197] nvidia 0000:06:00.0: vgaarb: deactivate vga console
[ 6.661761] fbcon: nvidia-drmdrmfb (fb0) is primary device
[ 6.730169] Console: switching to colour frame buffer device 240x67
[ 6.744542] nvidia 0000:06:00.0: [drm] fb0: nvidia-drmdrmfb frame buffer device
[ 6.887496] nvme nvme0: pci function 0000:03:00.0
[ 6.895914] nvme nvme0: missing or invalid SUBNQN field.
[ 6.957278] nvme nvme0: allocated 128 MiB host memory buffer (1 segment).
[ 7.025407] nvme nvme0: 8/0/0 default/read/poll queues
[ 7.036151] nvme0n1: p1 p2 p3 p4
[ 7.088093] usbcore: registered new interface driver usbhid
[ 7.088095] usbhid: USB HID core driver
[ 7.091346] hid-generic 0003:048D:5702.0001: hiddev96,hidraw0: USB HID v1.12 Device [ITE Tech. Inc. ITE Device] on usb-0000:01:00.0-7/input0
[ 7.091448] input: HP, Inc HyperX Virtual Surround Sound Consumer Control as /devices/pci0000:00/0000:00:01.2/0000:01:00.0/usb1/1-6/1-6.2/1-6.2:1.3/0003:03F0:0B92.0002/input/input2
[ 7.142302] input: HP, Inc HyperX Virtual Surround Sound as /devices/pci0000:00/0000:00:01.2/0000:01:00.0/usb1/1-6/1-6.2/1-6.2:1.3/0003:03F0:0B92.0002/input/input3
[ 7.142510] hid-generic 0003:03F0:0B92.0002: input,hiddev97,hidraw1: USB HID v1.11 Device [HP, Inc HyperX Virtual Surround Sound] on usb-0000:01:00.0-6.2/input3
[ 7.142585] input: Cooler Master Technology Inc. MM730 Gaming Mouse as /devices/pci0000:00/0000:00:01.2/0000:01:00.0/usb1/1-9/1-9:1.0/0003:2516:0165.0003/input/input4
[ 7.142634] hid-generic 0003:2516:0165.0003: input,hidraw2: USB HID v1.11 Mouse [Cooler Master Technology Inc. MM730 Gaming Mouse] on usb-0000:01:00.0-9/input0
[ 7.142717] hid-generic 0003:2516:0165.0004: hiddev98,hidraw3: USB HID v1.11 Device [Cooler Master Technology Inc. MM730 Gaming Mouse] on usb-0000:01:00.0-9/input1
[ 7.142802] input: Cooler Master Technology Inc. MM730 Gaming Mouse System Control as /devices/pci0000:00/0000:00:01.2/0000:01:00.0/usb1/1-9/1-9:1.2/0003:2516:0165.0005/input/input5
[ 7.193300] input: Cooler Master Technology Inc. MM730 Gaming Mouse Consumer Control as /devices/pci0000:00/0000:00:01.2/0000:01:00.0/usb1/1-9/1-9:1.2/0003:2516:0165.0005/input/input6
[ 7.193352] input: Cooler Master Technology Inc. MM730 Gaming Mouse Keyboard as /devices/pci0000:00/0000:00:01.2/0000:01:00.0/usb1/1-9/1-9:1.2/0003:2516:0165.0005/input/input7
[ 7.193399] hid-generic 0003:2516:0165.0005: input,hidraw4: USB HID v1.11 Keyboard [Cooler Master Technology Inc. MM730 Gaming Mouse] on usb-0000:01:00.0-9/input2
[ 7.193507] input: Evision RGB Keyboard as /devices/pci0000:00/0000:00:01.2/0000:01:00.0/usb1/1-6/1-6.3/1-6.3:1.0/0003:320F:5000.0006/input/input8
[ 7.302313] hid-generic 0003:320F:5000.0006: input,hidraw5: USB HID v1.11 Keyboard [Evision RGB Keyboard] on usb-0000:01:00.0-6.3/input0
[ 7.302794] input: Evision RGB Keyboard as /devices/pci0000:00/0000:00:01.2/0000:01:00.0/usb1/1-6/1-6.3/1-6.3:1.1/0003:320F:5000.0007/input/input9
[ 7.353295] input: Evision RGB Keyboard as /devices/pci0000:00/0000:00:01.2/0000:01:00.0/usb1/1-6/1-6.3/1-6.3:1.1/0003:320F:5000.0007/input/input10
[ 7.353375] hid-generic 0003:320F:5000.0007: input,hiddev99,hidraw6: USB HID v1.11 Keyboard [Evision RGB Keyboard] on usb-0000:01:00.0-6.3/input1
[ 7.353452] input: Samson Technologies Samson Meteor Mic Consumer Control as /devices/pci0000:00/0000:00:01.2/0000:01:00.0/usb1/1-6/1-6.4/1-6.4:1.3/0003:17A0:0310.0008/input/input11
[ 7.404313] hid-generic 0003:17A0:0310.0008: input,hiddev100,hidraw7: USB HID v1.00 Device [Samson Technologies Samson Meteor Mic] on usb-0000:01:00.0-6.4/input3
[ 7.404517] hid-generic 0003:1E71:2006.0009: hiddev101,hidraw8: USB HID v1.11 Device [NZXT. - Inc. NZXT USB Device] on usb-0000:01:00.0-10.4/input0
[ 7.652728] EXT4-fs (nvme0n1p3): mounted filesystem 0354c456-7630-4f71-8a3a-9f4c8606084f r/w with ordered data mode. Quota mode: none.
[ 7.797496] systemd[1]: systemd 257.5-2-arch running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +IPE +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +BTF +XKBCOMMON +UTMP -SYSVINIT +LIBARCHIVE)
[ 7.797502] systemd[1]: Detected architecture x86-64.
[ 7.800150] systemd[1]: Hostname set to .
[ 7.911525] systemd[1]: bpf-restrict-fs: LSM BPF program attached
[ 8.216553] systemd[1]: Queued start job for default target Graphical Interface.
[ 8.233291] systemd[1]: Created slice Slice /system/dhcpcd.
[ 8.233683] systemd[1]: Created slice Slice /system/dirmngr.
[ 8.234017] systemd[1]: Created slice Slice /system/getty.
[ 8.234355] systemd[1]: Created slice Slice /system/gpg-agent.
[ 8.234692] systemd[1]: Created slice Slice /system/gpg-agent-browser.
[ 8.235024] systemd[1]: Created slice Slice /system/gpg-agent-extra.
[ 8.235361] systemd[1]: Created slice Slice /system/gpg-agent-ssh.
[ 8.235694] systemd[1]: Created slice Slice /system/keyboxd.
[ 8.236032] systemd[1]: Created slice Slice /system/modprobe.
[ 8.236434] systemd[1]: Created slice Slice /system/systemd-fsck.
[ 8.236769] systemd[1]: Created slice User and Session Slice.
[ 8.236929] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 8.237173] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 8.237306] systemd[1]: Expecting device /dev/disk/by-uuid/143EEF9B3EEF7460…
[ 8.237399] systemd[1]: Expecting device /dev/disk/by-uuid/51005a92-68ee-4a18-8560-c4cafc7d9589…
[ 8.237491] systemd[1]: Expecting device /dev/disk/by-uuid/F6DC0888DC084579…
[ 8.237580] systemd[1]: Expecting device /dev/disk/by-uuid/F789-93C2…
[ 8.237668] systemd[1]: Expecting device /dev/disk/by-uuid/e531b8f1-68b5-4551-8e3b-2c7775cf7771…
[ 8.237759] systemd[1]: Expecting device /sys/subsystem/net/devices/enp1s0f0u6u1…
[ 8.237854] systemd[1]: Reached target Local Integrity Protected Volumes.
[ 8.237969] systemd[1]: Reached target Remote File Systems.
[ 8.238073] systemd[1]: Reached target Slice Units.
[ 8.238185] systemd[1]: Reached target Local Verity Protected Volumes.
[ 8.238350] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 8.242989] systemd[1]: Listening on Process Core Dump Socket.
[ 8.243735] systemd[1]: Listening on Credential Encryption/Decryption.
[ 8.243924] systemd[1]: Listening on Journal Socket (/dev/log).
[ 8.244097] systemd[1]: Listening on Journal Sockets.
[ 8.244226] systemd[1]: TPM PCR Measurements was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ 8.244243] systemd[1]: Make TPM PCR Policy was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ 8.244305] systemd[1]: Listening on udev Control Socket.
[ 8.244454] systemd[1]: Listening on udev Kernel Socket.
[ 8.244613] systemd[1]: Listening on User Database Manager Socket.
[ 8.245768] systemd[1]: Mounting Huge Pages File System…
[ 8.246415] systemd[1]: Mounting POSIX Message Queue File System…
[ 8.247075] systemd[1]: Mounting Kernel Debug File System…
[ 8.247737] systemd[1]: Mounting Kernel Trace File System…
[ 8.248495] systemd[1]: Starting Create List of Static Device Nodes…
[ 8.249235] systemd[1]: Starting Load Kernel Module configfs…
[ 8.250164] systemd[1]: Starting Load Kernel Module dm_mod…
[ 8.251085] systemd[1]: Starting Load Kernel Module drm…
[ 8.252000] systemd[1]: Starting Load Kernel Module fuse…
[ 8.252956] systemd[1]: Starting Load Kernel Module loop…
[ 8.253126] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
[ 8.253158] systemd[1]: Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67).
[ 8.254791] systemd[1]: Starting Journal Service…
[ 8.255801] systemd[1]: Starting Load Kernel Modules…
[ 8.255901] systemd[1]: TPM PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ 8.256502] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 8.256627] systemd[1]: Early TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ 8.257198] systemd[1]: Starting Load udev Rules from Credentials…
[ 8.257890] systemd[1]: Starting Coldplug All udev Devices…
[ 8.258806] systemd[1]: Starting Virtual Console Setup…
[ 8.261423] systemd[1]: Mounted Huge Pages File System.
[ 8.261685] systemd[1]: Mounted POSIX Message Queue File System.
[ 8.261897] systemd[1]: Mounted Kernel Debug File System.
[ 8.262135] systemd[1]: Mounted Kernel Trace File System.
[ 8.262589] systemd[1]: Finished Create List of Static Device Nodes.
[ 8.263034] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 8.263225] systemd[1]: Finished Load Kernel Module configfs.
[ 8.265019] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 8.265198] systemd[1]: Finished Load Kernel Module drm.
[ 8.265260] loop: module loaded
[ 8.265280] device-mapper: uevent: version 1.0.3
[ 8.265343] device-mapper: ioctl: 4.49.0-ioctl (2025-01-17) initialised: dm-devel@lists.linux.dev
[ 8.265898] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
[ 8.266058] systemd[1]: Finished Load Kernel Module dm_mod.
[ 8.267043] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 8.267221] systemd[1]: Finished Load Kernel Module fuse.
[ 8.269209] systemd[1]: modprobe@loop.service: Deactivated successfully.
[ 8.269428] systemd[1]: Finished Load Kernel Module loop.
[ 8.270607] systemd[1]: Finished Load udev Rules from Credentials.
[ 8.270866] systemd-journald[355]: Collecting audit messages is disabled.
[ 8.272145] systemd[1]: Mounting FUSE Control File System…
[ 8.272848] i2c_dev: i2c /dev entries driver
[ 8.273060] systemd[1]: Mounting Kernel Configuration File System…
[ 8.273415] systemd[1]: Repartition Root Disk was skipped because no trigger condition checks were met.
[ 8.274099] systemd[1]: Starting Create Static Device Nodes in /dev gracefully…
[ 8.274409] EXT4-fs (nvme0n1p3): re-mounted 0354c456-7630-4f71-8a3a-9f4c8606084f r/w. Quota mode: none.
[ 8.275277] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 8.277385] systemd[1]: Finished Load Kernel Modules.
[ 8.278086] systemd[1]: Mounted FUSE Control File System.
[ 8.278874] systemd[1]: Mounted Kernel Configuration File System.
[ 8.280655] systemd[1]: Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
[ 8.281470] systemd[1]: Starting Load/Save OS Random Seed…
[ 8.282677] systemd[1]: Starting Apply Kernel Variables…
[ 8.283061] systemd[1]: TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ 8.287292] systemd[1]: Finished Virtual Console Setup.
[ 8.294001] systemd[1]: Finished Load/Save OS Random Seed.
[ 8.294639] systemd[1]: Finished Apply Kernel Variables.
[ 8.297972] systemd[1]: Starting User Database Manager…
[ 8.318987] systemd[1]: Started User Database Manager.
[ 8.329084] systemd[1]: Started Journal Service.
[ 8.361879] systemd-journald[355]: Received client request to flush runtime journal.
[ 8.552223] mousedev: PS/2 mouse device common for all mice
[ 8.585925] mc: Linux media interface: v0.10
[ 8.587212] input: PC Speaker as /devices/platform/pcspkr/input/input13
[ 8.587309] nzxt-smart2 0003:1E71:2006.0009: hidraw8: USB HID v1.11 Device [NZXT. - Inc. NZXT USB Device] on usb-0000:01:00.0-10.4/input0
[ 8.588187] ccp 0000:08:00.1: enabling device (0000 → 0002)
[ 8.589421] ACPI Warning: SystemIO range 0x0000000000000B00-0x0000000000000B08 conflicts with OpRegion 0x0000000000000B00-0x0000000000000B0F (\GSA1.SMBI) (20240827/utaddress-204)
[ 8.589428] ACPI: OSL: Resource conflict; ACPI support missing from driver?
[ 8.589852] gigabyte-wmi DEADBEEF-2001-0000-00A0-C90629100000: No temperature sensors usable
[ 8.592045] ccp 0000:08:00.1: ccp: unable to access the device: you might be running a broken BIOS.
[ 8.592120] ccp 0000:08:00.1: psp enabled
[ 8.597692] sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver
[ 8.598635] sp5100-tco sp5100-tco: Using 0xfeb00000 for watchdog MMIO address
[ 8.598786] sp5100-tco sp5100-tco: initialized. heartbeat=60 sec (nowayout=0)
[ 8.602190] RAPL PMU: API unit is 2^-32 Joules, 2 fixed counters, 163840 ms ovfl timer
[ 8.602193] RAPL PMU: hw unit of domain package 2^-16 Joules
[ 8.602195] RAPL PMU: hw unit of domain core 2^-16 Joules
[ 8.633778] cryptd: max_cpu_qlen set to 1000
[ 8.634769] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 8.637491] Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 8.637610] Loaded X.509 cert ‘wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600’
[ 8.638593] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 8.638597] cfg80211: failed to load regulatory.db
[ 8.640795] r8169 0000:05:00.0 eth0: RTL8125B, 18:c0:4d:3a:bf:78, XID 641, IRQ 71
[ 8.640800] r8169 0000:05:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
[ 8.652742] r8169 0000:05:00.0 eno1: renamed from eth0
[ 8.653654] AES CTR mode by8 optimization enabled
[ 8.685544] snd_hda_intel 0000:06:00.1: enabling device (0000 → 0002)
[ 8.685616] snd_hda_intel 0000:06:00.1: Disabling MSI
[ 8.685626] snd_hda_intel 0000:06:00.1: Handle vga_switcheroo audio client
[ 8.685714] snd_hda_intel 0000:08:00.4: enabling device (0000 → 0002)
[ 8.688496] wl: module license ‘MIXED/Proprietary’ taints kernel.
[ 8.688499] Disabling lock debugging due to kernel taint
[ 8.688501] wl: module license taints kernel.
[ 8.698411] ------------[ cut here ]------------
[ 8.698413] Unpatched return thunk in use. This should not happen!
[ 8.698416] WARNING: CPU: 1 PID: 453 at arch/x86/kernel/cpu/bugs.c:3074 __warn_thunk+0x2a/0x40
[ 8.698422] Modules linked in: wl(POE+) snd_hda_intel irqbypass polyval_clmulni snd_intel_dspcfg polyval_generic snd_intel_sdw_acpi snd_usb_audio(+) ghash_clmulni_intel snd_hda_codec sha512_ssse3 snd_usbmidi_lib sha256_ssse3 snd_ump sha1_ssse3 snd_hda_core aesni_intel snd_rawmidi snd_hwdep snd_seq_device crypto_simd snd_pcm cryptd r8169 cfg80211 rapl snd_timer realtek sp5100_tco mdio_devres snd i2c_piix4 wmi_bmof gigabyte_wmi pcspkr k10temp rfkill ccp libphy i2c_smbus soundcore nzxt_smart2 mc mousedev joydev gpio_amdpt gpio_generic mac_hid i2c_dev crypto_user loop dm_mod nfnetlink ip_tables x_tables hid_generic nvme nvme_core nvme_auth usbhid nvidia_drm(OE) drm_ttm_helper ttm nvidia_uvm(OE) nvidia_modeset(OE) video wmi nvidia(OE)
[ 8.698490] CPU: 1 UID: 0 PID: 453 Comm: (udev-worker) Tainted: P OE 6.14.4-arch1-1 #1 fe5fd5140ef53fa47886c198b421077448d940d2
[ 8.698494] Tainted: [P]=PROPRIETARY_MODULE, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
[ 8.698496] Hardware name: Gigabyte Technology Co., Ltd. B550 AORUS PRO/B550 AORUS PRO, BIOS F13 07/08/2021
[ 8.698498] RIP: 0010:__warn_thunk+0x2a/0x40
[ 8.698501] Code: 66 0f 1f 00 0f 1f 44 00 00 80 3d 0a 40 39 02 00 74 05 e9 84 d5 e1 ff 48 c7 c7 d8 d1 97 8b c6 05 f5 3f 39 02 01 e8 96 38 06 00 <0f> 0b e9 6a d5 e1 ff 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00
[ 8.698503] RSP: 0018:ffffae74c2abf8c0 EFLAGS: 00010286
[ 8.698506] RAX: 0000000000000000 RBX: 0000000000000000 RCX: 0000000000000027
[ 8.698507] RDX: ffff8c06eeca1908 RSI: 0000000000000001 RDI: ffff8c06eeca1900
[ 8.698509] RBP: ffffae74c2abf910 R08: 0000000000000000 R09: ffffae74c2abf740
[ 8.698510] R10: ffffffff8c2b4468 R11: 0000000000000003 R12: ffffffffc2499ac5
[ 8.698511] R13: ffffae74c2abf958 R14: ffff8c03c534ea80 R15: ffff8c03db36f898
[ 8.698513] FS: 00007a0a56bad880(0000) GS:ffff8c06eec80000(0000) knlGS:0000000000000000
[ 8.698515] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 8.698516] CR2: 00007a0a5579470a CR3: 00000001115e8000 CR4: 0000000000f50ef0
[ 8.698518] PKRU: 55555554
[ 8.698520] Call Trace:
[ 8.698521]
[ 8.698523] warn_thunk_thunk+0x1a/0x30
[ 8.698529] getvar+0x20/0x70 [wl 30c5fbc51291b450b882f38eb1d45d14ab017b2c]
[ 8.698555] ? orc_header+0x1790/0x1790 [wl 30c5fbc51291b450b882f38eb1d45d14ab017b2c]
[ 8.698593] wl_module_init+0x17/0xa0 [wl 30c5fbc51291b450b882f38eb1d45d14ab017b2c]
[ 8.698613] ? do_one_initcall+0x5b/0x310
[ 8.698617] ? do_init_module+0x60/0x230
[ 8.698622] ? init_module_from_file+0x89/0xe0
[ 8.698627] ? idempotent_init_module+0x115/0x310
[ 8.698631] ? __x64_sys_finit_module+0x65/0xc0
[ 8.698634] ? do_syscall_64+0x82/0x190
[ 8.698638] ? srso_alias_return_thunk+0x5/0xfbef5
[ 8.698640] ? filemap_get_pages+0x93/0x6c0
[ 8.698644] ? srso_alias_return_thunk+0x5/0xfbef5
[ 8.698645] ? ktime_get_coarse_real_ts64_mg+0x89/0xb0
[ 8.698649] ? srso_alias_return_thunk+0x5/0xfbef5
[ 8.698650] ? current_time+0x40/0x130
[ 8.698653] ? srso_alias_return_thunk+0x5/0xfbef5
[ 8.698655] ? atime_needs_update+0xa0/0x120
[ 8.698658] ? srso_alias_return_thunk+0x5/0xfbef5
[ 8.698659] ? touch_atime+0x1e/0x120
[ 8.698662] ? srso_alias_return_thunk+0x5/0xfbef5
[ 8.698663] ? filemap_read+0x3ca/0x400
[ 8.698672] ? vfs_read+0x164/0x370
[ 8.698675] ? srso_alias_return_thunk+0x5/0xfbef5
[ 8.698677] ? vfs_read+0x164/0x370
[ 8.698679] ? srso_alias_return_thunk+0x5/0xfbef5
[ 8.698681] ? __rseq_handle_notify_resume+0xa2/0x4c0
[ 8.698686] ? srso_alias_return_thunk+0x5/0xfbef5
[ 8.698688] ? switch_fpu_return+0x4e/0xd0
[ 8.698692] ? srso_alias_return_thunk+0x5/0xfbef5
[ 8.698693] ? arch_exit_to_user_mode_prepare.isra.0+0x79/0x90
[ 8.698696] ? srso_alias_return_thunk+0x5/0xfbef5
[ 8.698698] ? syscall_exit_to_user_mode+0x37/0x1c0
[ 8.698700] ? srso_alias_return_thunk+0x5/0xfbef5
[ 8.698702] ? do_syscall_64+0x8e/0x190
[ 8.698705] ? srso_alias_return_thunk+0x5/0xfbef5
[ 8.698707] ? syscall_exit_to_user_mode+0x37/0x1c0
[ 8.698709] ? srso_alias_return_thunk+0x5/0xfbef5
[ 8.698710] ? do_syscall_64+0x8e/0x190
[ 8.698713] ? srso_alias_return_thunk+0x5/0xfbef5
[ 8.698715] ? srso_alias_return_thunk+0x5/0xfbef5
[ 8.698717] ? entry_SYSCALL_64_after_hwframe+0x76/0x7e
[ 8.698723]
[ 8.698724] —[ end trace 0000000000000000 ]—
[ 8.698746] wl 0000:04:00.0: enabling device (0000 → 0002)
[ 8.716482] wlan0: Broadcom BCM43a0 802.11 Hybrid Wireless Controller 6.30.223.271 (r587334)
[ 8.736424] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:03.1/0000:06:00.1/sound/card1/input14
[ 8.736538] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:03.1/0000:06:00.1/sound/card1/input15
[ 8.736664] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:03.1/0000:06:00.1/sound/card1/input16
[ 8.736768] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:03.1/0000:06:00.1/sound/card1/input17
[ 8.740481] wl 0000:04:00.0 wlp4s0: renamed from wlan0
[ 8.749648] snd_hda_codec_realtek hdaudioC2D0: autoconfig for ALC1220: line_outs=3 (0x14/0x15/0x16/0x0/0x0) type:line
[ 8.749652] snd_hda_codec_realtek hdaudioC2D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 8.749654] snd_hda_codec_realtek hdaudioC2D0: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[ 8.749656] snd_hda_codec_realtek hdaudioC2D0: mono: mono_out=0x0
[ 8.749658] snd_hda_codec_realtek hdaudioC2D0: dig-out=0x1e/0x0
[ 8.749660] snd_hda_codec_realtek hdaudioC2D0: inputs:
[ 8.749662] snd_hda_codec_realtek hdaudioC2D0: Rear Mic=0x18
[ 8.749664] snd_hda_codec_realtek hdaudioC2D0: Front Mic=0x19
[ 8.749665] snd_hda_codec_realtek hdaudioC2D0: Line=0x1a
[ 8.751040] kvm_amd: TSC scaling supported
[ 8.751043] kvm_amd: Nested Virtualization enabled
[ 8.751044] kvm_amd: Nested Paging enabled
[ 8.751046] kvm_amd: LBR virtualization supported
[ 8.751050] kvm_amd: Virtual VMLOAD VMSAVE supported
[ 8.751051] kvm_amd: Virtual GIF supported
[ 8.763134] input: HD-Audio Generic Rear Mic as /devices/pci0000:00/0000:00:08.1/0000:08:00.4/sound/card2/input18
[ 8.763195] input: HD-Audio Generic Front Mic as /devices/pci0000:00/0000:00:08.1/0000:08:00.4/sound/card2/input19
[ 8.763279] input: HD-Audio Generic Line as /devices/pci0000:00/0000:00:08.1/0000:08:00.4/sound/card2/input20
[ 8.763369] input: HD-Audio Generic Line Out Front as /devices/pci0000:00/0000:00:08.1/0000:08:00.4/sound/card2/input21
[ 8.764260] input: HD-Audio Generic Line Out Surround as /devices/pci0000:00/0000:00:08.1/0000:08:00.4/sound/card2/input22
[ 8.764325] input: HD-Audio Generic Line Out CLFE as /devices/pci0000:00/0000:00:08.1/0000:08:00.4/sound/card2/input23
[ 8.764381] input: HD-Audio Generic Front Headphone as /devices/pci0000:00/0000:00:08.1/0000:08:00.4/sound/card2/input24
[ 8.802651] intel_rapl_common: Found RAPL domain package
[ 8.802654] intel_rapl_common: Found RAPL domain core
[ 8.803548] amd_atl: AMD Address Translation Library initialized
[ 9.286909] ntfs3: Enabled Linux POSIX ACLs support
[ 9.286911] ntfs3: Read-only LZX/Xpress compression included
[ 9.287527] FAT-fs (nvme0n1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 9.287719] ntfs3(sdb2): It is recommened to use chkdsk.
[ 9.290780] ntfs3(sda2): It is recommened to use chkdsk.
[ 9.373046] EXT4-fs (nvme0n1p4): mounted filesystem e531b8f1-68b5-4551-8e3b-2c7775cf7771 r/w with ordered data mode. Quota mode: none.
[ 9.539055] usbcore: registered new interface driver snd-usb-audio
[ 98.681278] Realtek Internal NBASE-T PHY r8169-0-500:00: attached PHY driver (mii_bus:phy_addr=r8169-0-500:00, irq=MAC)
[ 98.821418] r8169 0000:05:00.0 eno1: Link is Down
[ 100.794223] ------------[ cut here ]------------
[ 100.794226] memcpy: detected field-spanning write (size 468) of single field “dst” at src/wl/sys/wl_cfg80211_hybrid.c:3075 (size 0)
[ 100.794240] WARNING: CPU: 3 PID: 522 at src/wl/sys/wl_cfg80211_hybrid.c:3075 wl_inform_single_bss+0x2b5/0x3f0 [wl]
[ 100.794298] Modules linked in: vfat ntfs3 fat amd_atl intel_rapl_msr intel_rapl_common kvm_amd snd_hda_codec_realtek snd_hda_codec_generic snd_hda_codec_hdmi snd_hda_scodec_component kvm wl(POE) snd_hda_intel irqbypass polyval_clmulni snd_intel_dspcfg polyval_generic snd_intel_sdw_acpi snd_usb_audio ghash_clmulni_intel snd_hda_codec sha512_ssse3 snd_usbmidi_lib sha256_ssse3 snd_ump sha1_ssse3 snd_hda_core aesni_intel snd_rawmidi snd_hwdep snd_seq_device crypto_simd snd_pcm cryptd r8169 cfg80211 rapl snd_timer realtek sp5100_tco mdio_devres snd i2c_piix4 wmi_bmof gigabyte_wmi pcspkr k10temp rfkill ccp libphy i2c_smbus soundcore nzxt_smart2 mc mousedev joydev gpio_amdpt gpio_generic mac_hid i2c_dev crypto_user loop dm_mod nfnetlink ip_tables x_tables hid_generic nvme nvme_core nvme_auth usbhid nvidia_drm(OE) drm_ttm_helper ttm nvidia_uvm(OE) nvidia_modeset(OE) video wmi nvidia(OE)
[ 100.794392] CPU: 3 UID: 0 PID: 522 Comm: wl_event_handle Tainted: P W OE 6.14.4-arch1-1 #1 fe5fd5140ef53fa47886c198b421077448d940d2
[ 100.794397] Tainted: [P]=PROPRIETARY_MODULE, [W]=WARN, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
[ 100.794399] Hardware name: Gigabyte Technology Co., Ltd. B550 AORUS PRO/B550 AORUS PRO, BIOS F13 07/08/2021
[ 100.794401] RIP: 0010:wl_inform_single_bss+0x2b5/0x3f0 [wl]
[ 100.794442] Code: 71 b6 15 00 00 0f 85 8c fe ff ff 31 c9 48 c7 c2 48 b2 49 c2 4c 89 f6 48 c7 c7 a0 b1 49 c2 c6 05 51 b6 15 00 01 e8 7b f7 15 c8 <0f> 0b e9 66 fe ff ff e8 6f 97 e4 c8 85 c0 0f 84 9f fe ff ff e9 4f
[ 100.794444] RSP: 0018:ffffae74c0e57db0 EFLAGS: 00010286
[ 100.794447] RAX: 0000000000000000 RBX: ffff8c03d460000c RCX: 0000000000000027
[ 100.794449] RDX: ffff8c06eeda1908 RSI: 0000000000000001 RDI: ffff8c06eeda1900
[ 100.794451] RBP: ffff8c03d34c4000 R08: 0000000000000000 R09: ffffae74c0e57c30
[ 100.794453] R10: ffffffff8c2b4468 R11: 0000000000000003 R12: 00000000000001d4
[ 100.794455] R13: ffff8c03d4600014 R14: 00000000000001d4 R15: ffff8c03d08e2900
[ 100.794457] FS: 0000000000000000(0000) GS:ffff8c06eed80000(0000) knlGS:0000000000000000
[ 100.794459] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 100.794461] CR2: 00007e9fd9a5f2b0 CR3: 0000000112696000 CR4: 0000000000f50ef0
[ 100.794463] PKRU: 55555554
[ 100.794465] Call Trace:
[ 100.794467]
[ 100.794470] ? srso_alias_return_thunk+0x5/0xfbef5
[ 100.794475] ? warn_thunk_thunk+0x1a/0x30
[ 100.794480] ? wl_notify_scan_status+0x134/0x260 [wl 30c5fbc51291b450b882f38eb1d45d14ab017b2c]
[ 100.794518] ? wl_event_handler+0x7a/0x180 [wl 30c5fbc51291b450b882f38eb1d45d14ab017b2c]
[ 100.794552] ? wl_cfg80211_add_key+0x380/0x380 [wl 30c5fbc51291b450b882f38eb1d45d14ab017b2c]
[ 100.794585] ? kthread+0xef/0x230
[ 100.794589] ? __pfx_kthread+0x10/0x10
[ 100.794593] ? ret_from_fork+0x34/0x50
[ 100.794596] ? __pfx_kthread+0x10/0x10
[ 100.794599] ? ret_from_fork_asm+0x1a/0x30
[ 100.794606]
[ 100.794608] —[ end trace 0000000000000000 ]—
[ 111.917589] nvme nvme0: using unchecked data buffer
[ 118.933177] warning: `ThreadPoolForeg’ uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
Output of journalctl :
Summary
[kush@sybil ~]$ journalctl --user-unit plasma-kwin_wayland --boot 0
May 01 12:32:42 sybil systemd[655]: Starting KDE Window Manager…
May 01 12:32:42 sybil systemd[655]: Started KDE Window Manager.
May 01 12:32:42 sybil kwin_wayland[702]: No backend specified, automatically choosing drm
May 01 12:32:44 sybil kwin_wayland_wrapper[815]: The XKEYBOARD keymap compiler (xkbcomp) reports:
May 01 12:32:44 sybil kwin_wayland_wrapper[815]: > Warning: Could not resolve keysym XF86RefreshRateToggle
May 01 12:32:44 sybil kwin_wayland_wrapper[815]: > Warning: Could not resolve keysym XF86Accessibility
May 01 12:32:44 sybil kwin_wayland_wrapper[815]: > Warning: Could not resolve keysym XF86DoNotDisturb
May 01 12:32:44 sybil kwin_wayland_wrapper[815]: Errors from xkbcomp are not fatal to the X server
May 01 12:32:44 sybil kwin_wayland_wrapper[820]: The XKEYBOARD keymap compiler (xkbcomp) reports:
May 01 12:32:44 sybil kwin_wayland_wrapper[820]: > Warning: Unsupported maximum keycode 708, clipping.
May 01 12:32:44 sybil kwin_wayland_wrapper[820]: > X11 cannot support keycodes above 255.
May 01 12:32:44 sybil kwin_wayland_wrapper[820]: > Warning: Could not resolve keysym XF86RefreshRateToggle
May 01 12:32:44 sybil kwin_wayland_wrapper[820]: > Warning: Could not resolve keysym XF86Accessibility
May 01 12:32:44 sybil kwin_wayland_wrapper[820]: > Warning: Could not resolve keysym XF86DoNotDisturb
May 01 12:32:44 sybil kwin_wayland_wrapper[820]: Errors from xkbcomp are not fatal to the X server
May 01 12:32:44 sybil kcminit[821]: Initializing “/usr/lib/qt6/plugins/plasma/kcms/systemsettings/kcm_fonts.so”
May 01 12:32:44 sybil kcminit[821]: Initializing “/usr/lib/qt6/plugins/plasma/kcms/systemsettings/kcm_style.so”
May 01 12:32:50 sybil kwin_wayland[702]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
May 01 12:32:50 sybil kwin_wayland[702]: kwin_scene_opengl: 0x501: GL_INVALID_VALUE error generated. , and must be 1 or greater.
May 01 12:32:50 sybil kwin_wayland[702]: kwin_scene_opengl: Invalid framebuffer status: “GL_FRAMEBUFFER_INCOMPLETE_ATTACHMENT”
May 01 12:32:50 sybil kwin_wayland[702]: kwin_scene_opengl: 0x502: GL_INVALID_OPERATION error generated. Framebuffer name must be generated before being bound.
May 01 12:32:50 sybil kwin_wayland[702]: kwin_scene_opengl: 0x506: GL_INVALID_FRAMEBUFFER_OPERATION error generated. Operation is not valid because a bound fr>
May 01 12:32:51 sybil kwin_wayland[702]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
May 01 12:33:10 sybil kwin_wayland[702]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
May 01 12:33:10 sybil kwin_wayland[702]: kwin_scene_opengl: 0x501: GL_INVALID_VALUE error generated. , and must be 1 or greater.
May 01 12:33:10 sybil kwin_wayland[702]: kwin_scene_opengl: Invalid framebuffer status: “GL_FRAMEBUFFER_INCOMPLETE_ATTACHMENT”
May 01 12:33:10 sybil kwin_wayland[702]: kwin_scene_opengl: 0x502: GL_INVALID_OPERATION error generated. Framebuffer name must be generated before being bound.
May 01 12:33:10 sybil kwin_wayland[702]: kwin_scene_opengl: 0x506: GL_INVALID_FRAMEBUFFER_OPERATION error generated. Operation is not valid because a bound fr>
May 01 12:33:28 sybil kwin_wayland[702]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
May 01 12:33:28 sybil kwin_wayland[702]: kwin_scene_opengl: 0x501: GL_INVALID_VALUE error generated. , and must be 1 or greater.
May 01 12:33:28 sybil kwin_wayland[702]: kwin_scene_opengl: Invalid framebuffer status: “GL_FRAMEBUFFER_INCOMPLETE_ATTACHMENT”
May 01 12:33:28 sybil kwin_wayland[702]: kwin_scene_opengl: 0x502: GL_INVALID_OPERATION error generated. Framebuffer name must be generated before being bound.
May 01 12:33:28 sybil kwin_wayland[702]: kwin_scene_opengl: 0x506: GL_INVALID_FRAMEBUFFER_OPERATION error generated. Operation is not valid because a bound fr>
