Steam randomly crashes when running on Wayland. It wouldn’t be an issue, except the games also close with Steam. Steam notifications also freeze Steam permanently, requiring a killall -9 steam to work again.
Specs/Versions:
- KDE Plasma 5.25.4.
- NVIDIA Beta 515.57
- Arch Linux
- RTX 2080
nvidia-bug-report.log.gz (2.2 MB)
Logs of crash:
elo 07 22:10:49 onskankone kernel: steam[288210]: segfault at 0 ip 00000000f606be3d sp 00000000ffa6a5d0 error 4 in libnvidia-glcore.so.515.57[f548b000+1adc000]
elo 07 22:10:49 onskankone kernel: Code: 53 89 c3 31 f6 83 ec 2c 8b 80 f0 0b 00 00 8b ab a8 09 00 00 89 54 24 10 8b 93 e8 00 00 00 8b bb e0 00 00 00 8b 80 b8 3f 02 00 <8b> 0a 8b 93 64 05 00 00 85 c0 89 4c 24 0c 8b 8b 28 0c 00 00 0f 84
elo 07 22:10:49 onskankone kernel: audit: type=1701 audit(1659899449.580:2302): auid=60451 uid=60451 gid=60451 ses=9 pid=288210 comm="steam" exe="/home/onni/.local/share/Steam/ubuntu12_32/steam" sig=11 res=1
elo 07 22:10:49 onskankone audit[288210]: ANOM_ABEND auid=60451 uid=60451 gid=60451 ses=9 pid=288210 comm="steam" exe="/home/onni/.local/share/Steam/ubuntu12_32/steam" sig=11 res=1
elo 07 22:10:49 onskankone crash_20220807221049_175.dmp[308091]: Uploading dump (out-of-process)
/tmp/dumps/crash_20220807221049_175.dmp
elo 07 22:10:49 onskankone audit: BPF prog-id=195 op=LOAD
elo 07 22:10:49 onskankone audit: BPF prog-id=196 op=LOAD
elo 07 22:10:49 onskankone audit: BPF prog-id=197 op=LOAD
elo 07 22:10:49 onskankone kernel: audit: type=1334 audit(1659899449.601:2303): prog-id=195 op=LOAD
elo 07 22:10:49 onskankone kernel: audit: type=1334 audit(1659899449.601:2304): prog-id=196 op=LOAD
elo 07 22:10:49 onskankone kernel: audit: type=1334 audit(1659899449.601:2305): prog-id=197 op=LOAD
elo 07 22:10:49 onskankone systemd[1]: Started Process Core Dump (PID 308092/UID 0).
elo 07 22:10:49 onskankone audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@41-308092-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
elo 07 22:10:49 onskankone kernel: audit: type=1130 audit(1659899449.603:2306): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@41-308092-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Coredump below:
Process 288210 (steam) of user 60451 dumped core.
Module /home/onni/.local/share/Steam/ubuntu12_32/steam with build-id fbccbfb12288bac532b5a64e9390aa78627c1860
Module /home/onni/.local/share/Steam/ubuntu12_32/serverbrowser.so with build-id 02ba2e24ba042352dc588ac79ba2c02620bf243b
Module /home/onni/.local/share/Steam/ubuntu12_32/friendsui.so with build-id d3e19763dbb2e1e82d4a3774407ce79be59a57d4
Module /home/onni/.local/share/Steam/ubuntu12_32/steamservice.so with build-id 7a656372e6d2743a18b9076d7b7a48a47a9b2d24
Module /home/onni/.local/share/Steam/ubuntu12_32/libopenvr_api.so with build-id 694769e324d930c1cb34ad66982c232b0860bc72
Module /home/onni/.local/share/Steam/ubuntu12_32/steamclient.so with build-id 37d89eca2d032748037817a3a29015ab58372473
Module /home/onni/.local/share/Steam/ubuntu12_32/chromehtml.so with build-id 74d6f1fef3ba3b20eab134a6f4843dd7ffabb3f8
Module /home/onni/.local/share/Steam/ubuntu12_32/vgui2_s.so with build-id 2627d45da8185093dec2ca3e0b5b74a7da420d51
Module /home/onni/.local/share/Steam/ubuntu12_32/libogg.so.0 with build-id 4c91d8f0dd8581b0ba6780e60808dc1db9ff5151
Module /home/onni/.local/share/Steam/ubuntu12_32/libvorbis.so.0 with build-id cb40c3a2fd4c2e54822da9789d01113970595af6
Module /home/onni/.local/share/Steam/ubuntu12_32/libvorbisenc.so.2 with build-id 5de455f0c9fcd36426e121b47995d9a75bfcecbf
Module /home/onni/.local/share/Steam/ubuntu12_32/libswscale.so.5 with build-id 899463f29a2dc17e253fdc44d8c5c1f857d3790d
Module /home/onni/.local/share/Steam/ubuntu12_32/libavresample.so.4 with build-id 0e506657c7e0388a8d89e6f13c694ba77ab1587b
Module /home/onni/.local/share/Steam/ubuntu12_32/libavformat.so.58 with build-id f2588eeac146259fed0991e2c626bbf0fe466f53
Module /home/onni/.local/share/Steam/ubuntu12_32/libvpx.so.6 with build-id e7262af22bb742de3a1af404c1fcc02cea202365
Module /home/onni/.local/share/Steam/ubuntu12_32/libicuuc.so with build-id 7bca947cbb088c5ea46ae03b4e96f2ff4efc8253
Module /home/onni/.local/share/Steam/ubuntu12_32/libicui18n.so with build-id 88bf0deef8375bf4848f1fd853b1da471cfa8b7b
Module /home/onni/.local/share/Steam/ubuntu12_32/libSDL2-2.0.so.0 with build-id d247398aa0cec70124cc2754544ec7eab935e11a
Module /home/onni/.local/share/Steam/ubuntu12_32/libvideo.so with build-id b7756ee11fd9f99809e416eba6c1ac305d7c4da2
Module /home/onni/.local/share/Steam/ubuntu12_32/libavutil.so.56 with build-id abf85a06683a34855e1a1d62a1ca36a1e0b461d6
Module /home/onni/.local/share/Steam/ubuntu12_32/libavcodec.so.58 with build-id 148cef6f617f420f9e8332878f0ec4d229f9776c
Module /home/onni/.local/share/Steam/ubuntu12_32/libv8.so with build-id c46f89eda7dcdedd846d2d6879a7d51e17ee8f64
Module /home/onni/.local/share/Steam/ubuntu12_32/libvstdlib_s.so with build-id 01804c460ac3d91a9b37dba95334bf40a3fbe55d
Module /home/onni/.local/share/Steam/ubuntu12_32/libtier0_s.so with build-id 3b0d5ce7b7bb3b5093c554577bcfcbd054dcf7b2
Module /home/onni/.local/share/Steam/ubuntu12_32/steamui.so with build-id 5c7582a74e448b4b4e231214ca5ce7ec67b21fcf
Module [dso] without build-id.
Module /home/onni/.local/share/Steam/ubuntu12_32/filesystem_stdio.so with build-id 6fe5f549ecb01d25d2df06258df8dd37b6f91818
Module /home/onni/.local/share/Steam/ubuntu12_32/crashhandler.so with build-id 5bf4ffc6b4b98b652f0529d97e816afca2472cd6
Module libnss_systemd.so.2 with build-id 328373b0b3648a73104e955acbe1d0ab2d55b10f
Module libXss.so.1 with build-id 6bbc2db6c0e1f095aaeca37c89dd3dabba9e3319
Module libnss_myhostname.so.2 with build-id 0c105da14b7ccd8f6536694c4a9960d6cd75d879
Module libnss_resolve.so.2 with build-id 301e1d0563dec98b4b66973ff920baa8fe355d3d
Module libnss_mymachines.so.2 with build-id 1746846661daf95ff8831d65b77a40dd8217dba2
Module libplc4.so with build-id 5bd201a9027310b3b6cc5311f4b109bd046e2d32
Module libplds4.so with build-id 170edd20c235d02c6f246ed20344bd64078c3d06
Module libnssutil3.so with build-id a19008864ed75d7f81cfd64f1d1d917b5b1430ce
Module libnspr4.so with build-id a352246656d5c138600860a0eca2d4802b3542c3
Module libnss3.so with build-id 1a51e887e2ada60aec704ad3b9827b27c0ff6e31
Module libsmime3.so with build-id 6e9157f4e96e3863a4ca17441f46ea26389f10df
Module libnm.so.0 with build-id 7411ed415f32b1e322153a9c3e0fc578ec99e4e3
Module libuuid.so.1 with build-id cd66031432a77fcb9c2bf642cfd879aa170ffafe
Module libICE.so.6 with build-id 5c398351eae18b0185f2b9512647e40c97f4e068
Module libSM.so.6 with build-id 1cb4b8ce8ba49d0d98da7968de9ee574ed44fe6e
Module libopenal.so.1 with build-id c52c9460942f9bfb1540f5fe85c6cc9b4f4f3a02
Module libudev.so.1 with build-id 5d6c3c4be660f322164ae49a0609c353d314cedb
Module libudev.so.0 with build-id 31497fcf41f971f99d5e1b4b90944a1a6c8c6487
Module libgpg-error.so.0 with build-id 6ecfdea2e1871208214eee924c1a309656c8913d
Module libgcrypt.so.20 with build-id 8ece9a72febf606ba62e6071765e3cc597a6edf0
Module libcap.so.2 with build-id 238fa8fbe554aa67483b7520ad786930c2f57e0a
Module libopus.so.0 with build-id e51af9f0b271bc2ba66d7b413a97df4aa21d1228
Module libFLAC.so.8 with build-id 56c326c3797e9b6e25a8cfabbbaa5e0e225cfde9
Module libasyncns.so.0 with build-id 2c3c77cfaeddfda50b66c21e3f8a86cb78933ca2
Module libsystemd.so.0 with build-id f1749cef38dffab1a7d7e7153dca92b23bf65e7b
Module libsndfile.so.1 with build-id 3e89f726838072f4fa3f8a9b16bc8405876891d1
Module libdbus-1.so.3 with build-id 9a7836e28749a17ddf276a7e8bdfbfced6021807
Module libpulsecommon-16.1.so with build-id d1f892a3bc37a602d769b0664e50a7acb2257e5a
Module libvdpau.so.1 with build-id d42369090aa9fdf14c505ef29ac87c80b12daeae
Module libva-x11.so.2 with build-id d0ebd2fae84b477db5517e01282cce15a7434b1a
Module libva-drm.so.2 with build-id 75f6eb5c10eaf4e7ecb91c53684153cbfb3f4b57
Module libva.so.2 with build-id fe3c3f4ebbabaa3278c66d8d961e3436dfe8144a
Module libpulse.so.0 with build-id 8802cdae09ed16b8f9a246a1188bcc8dd26e09f9
Module libpipewire-0.3.so.0 with build-id dca7916648cef7d138b90125a218d63301ad10d2
Module libXtst.so.6 with build-id c8d14b5c1592a418613843e9ca5149154aa98f8b
Module libbrotlicommon.so.1 with build-id 6a6095e57c732bdc9f52c5b401ccd78412b34650
Module libdatrie.so.1 with build-id 505ee6a7fcb465c1a484c8c813508515e415f19b
Module liblzma.so.5 with build-id f08d32c158738d5bcd5dfab2cd522a4e940ea692
Module libzstd.so.1 with build-id 442775044f6163f8c14265443311007e63d5d3e0
Module libblkid.so.1 with build-id afea748906b270df7b0dace3a37d063cc79bc9aa
Module libbrotlidec.so.1 with build-id d217b0d877303a399de12d974671e442aaf58832
Module libbz2.so.1.0 with build-id 3e5d97f5bb82cda221ccd14318bfae2ac77b815e
Module libexpat.so.1 with build-id 04afefa75a726ecd0d440f6ba5c8be90d2dc79d0
Module libthai.so.0 with build-id 55fe252092b25fc34ec252789c21a4f1702bfef1
Module libfribidi.so.0 with build-id 2789c21c3223584b3251e2339b80f76ef6202729
Module libpixman-1.so.0 with build-id 7761654702bfc76c1fcf3a174c792eb1e899fe14
Module libxcb-shm.so.0 with build-id c478bab45d8cef998d3d744755528b23dd9c445b
Module libxcb-render.so.0 with build-id 42eaec8c69b7df78937c6b9e664a98c457e5db18
Module libXdamage.so.1 with build-id 55dd5fb5193b4ee5207ecad0d19cc6e9d7af5aa9
Module libXcomposite.so.1 with build-id 9e8c1fe3c65614cf3fb6b4bb74acffc8ab0a5e0e
Module libXcursor.so.1 with build-id ae3c97e2f155847562267b1707c75fb9884a2350
Module libXrandr.so.2 with build-id 3295bdef0e30b5fd9da27c99bf5d6fd1c14551aa
Module libXi.so.6 with build-id ae19d465b15227ab5e08de671bc16532450e384f
Module libXinerama.so.1 with build-id ac215c8573b00954e0257efdae64546bed54c652
Module libXrender.so.1 with build-id 6fcaf8f5c40556f8a59e70883c51eb05d13685f8
Module libtiff.so.5 with build-id 1282881f9efdc18907b4e65cf39e652c6178f272
Module libjpeg.so.8 with build-id 0c11491d2d39ff5819b2ce1425b8e2375d811b31
Module libpng16.so.16 with build-id 202b8ec7361ff29d13abdcbeb691a9273494d2d9
Module libpcre.so.1 with build-id 9e8433d78efdfe75dc9ca017f477cf938d804df1
Module libffi.so.8 with build-id 2bcd779cf0cb1d8583813bcf37976575a6078f4b
Module libmount.so.1 with build-id 1a0b51691abe9353156e69de06814b70d8f9f5f9
Module libz.so.1 with build-id eef8f76603fae7a2876659fe737c1aebadb8b90b
Module libXfixes.so.3 with build-id d04e7cb05d21774a5403cdea89e8023c4e2dbd78
Module libatk-1.0.so.0 with build-id 3fb6e10a0aab244ea183014512384b21976b619c
Module libfreetype.so.6 with build-id ac10dea7fcb0e1dbc52d6989bfd34abbd814c1bf
Module libfontconfig.so.1 with build-id 8a9ac4404881ead3fa46770b2da4e946201cd827
Module libharfbuzz.so.0 with build-id 4f6dbb51f0257a18ae02d7a0d3e14bbe91ddb62d
Module libpango-1.0.so.0 with build-id 3a9a464115348e2f6daa55aa2d45f5332aa4969b
Module libpangoft2-1.0.so.0 with build-id 625ca95bd9f24b1f199169a2f4ded4c11d552e5c
Module libcairo.so.2 with build-id dd8d673a0e6ca9a8454e6712ef7c6d792288a7eb
Module libpangocairo-1.0.so.0 with build-id fd95109ae4a46130cd92004fd8a06da57a01e605
Module libgdk-x11-2.0.so.0 with build-id a69ae5230528f117e83349c598be3c8e25c9c756
Module libgmodule-2.0.so.0 with build-id 0df6b28d66299d96c47fc76f629234ab99371675
Module libgdk_pixbuf-2.0.so.0 with build-id 481be1b4cddf993f8d7b903d66c2fff2afef2783
Module libglib-2.0.so.0 with build-id 6cd48b6d9f35260c79f944bd1a3eb958b91fd94b
Module libgobject-2.0.so.0 with build-id 066a15490e1540b29cae244bd589f8d236fdb058
Module libgio-2.0.so.0 with build-id d3f4fbb75e8783a33162f2b2e47bada3f223f7d3
Module libgtk-x11-2.0.so.0 with build-id 2731645ea4d8238e682781a638470a546d65b7ca
Module libdbusmenu-glib.so.4 with build-id e70e8a7c68ffd38413ba472dcd3dc4fa11cf3a86
Module libdbusmenu-gtk.so.4 with build-id 4440e96792095b827703430b1524a61ed5c1ad49
Module libindicator.so.7 with build-id cb38ddcb8f426b4809ef119f0bd60130dd01e70d
Module libappindicator.so.1 with build-id b45ce0354a3c2e26bf64fa5d9dd1c6cf4bff39fd
Module libxcb-sync.so.1 with build-id 20e3e329957f59f35c8e8109f522c4e879d110ae
Module libxcb-present.so.0 with build-id 6c7c43f22ecafb03587fb389eb02e7042764f87e
Module libxcb-dri3.so.0 with build-id e7595e557d4b7e8203b2399cd075c5cf03273fb9
Module libX11-xcb.so.1 with build-id 7e480499e2b03a245a7cced1f1977449bdb9c9cc
Module libxcb-glx.so.0 with build-id 817fea1247bcd2ed52775646ce5e5ad22768f3cf
Module libdrm.so.2 with build-id b7ccfa37c747ad0b3903429f687a55330b25094b
Module libXext.so.6 with build-id 51364f7aaaad05288c6403f4cd82dc20bd1c2975
Module libnvidia-glcore.so.515.57 with build-id 34eacdc0d5842027e9101747cfaa7a6b5416e1d9
Module libnvidia-tls.so.515.57 with build-id 5e2342e734b9e33fbd8082ba5a61b9efbe88ab01
Module libnvidia-glsi.so.515.57 with build-id b9fd9cdd5c14cd9546f19c18eddb276845b918ba
Module libGLX_nvidia.so.0 with build-id 0faf880279899ab02753d9d588cd3b9f00002740
Module libGLX.so.0 with build-id 92c5b648663ea46e00344148f13d0e4413ece785
Module libGLdispatch.so.0 with build-id deb094bd23d7b05cfe2715882db8caadfdc7a2ab
Module libGL.so.1 with build-id 7d4cc9852ee6fd480756b2bbedc10c20167ed71a
Module libXdmcp.so.6 with build-id d6d2063b49e333551fb395c4699ce68908342ca2
Module libXau.so.6 with build-id 37885701fd17e23735180bb9afefba9fd93eafce
Module libxcb.so.1 with build-id 4187de5462ea94547789043cd82a227550b36d73
Module libgcc_s.so.1 with build-id 9cfb5c42915c09e5eedaca6de47885129eeb618e
Module ld-linux.so.2 with build-id 9ca3a26f52da8017b15300c7c4a04e141b9f35e4
Module libc.so.6 with build-id 7396ced206f6155e1cc2fe0f8b65abb84a17bed4
Module libm.so.6 with build-id 3c25abc71cfb4f383b9432ddca9f43ac3ab60f70
Module libX11.so.6 with build-id 54441eb873ba14650de70b96c9724da9f6dc6eb3
Module librt.so.1 with build-id 7f7a4f2054c5474126043caa6dc16f8ddb783f1d
Module libpthread.so.0 with build-id 09c9cd14d337113173182eb80be268031743b768
Module libstdc++.so.6 with build-id c621e6367cd2f26f673b5c09f87c95755f3ff83b
Module libdl.so.2 with build-id c8841800dec17fbf5c2fb788f6abda61186cc3c3
Stack trace of thread 288210:
#0 0x00000000f606be3d n/a (libnvidia-glcore.so.515.57 + 0xe6be3d)
#1 0x00000000f606c70c n/a (libnvidia-glcore.so.515.57 + 0xe6c70c)
#2 0x00000000f60ae780 n/a (libnvidia-glcore.so.515.57 + 0xeae780)
#3 0x00000000f606e6d3 n/a (libnvidia-glcore.so.515.57 + 0xe6e6d3)
#4 0x00000000f70bc5c6 n/a (libGLX_nvidia.so.0 + 0x425c6)
#5 0x00000000f70fa743 n/a (libGLX_nvidia.so.0 + 0x80743)
#6 0x00000000f70e71a8 glXMakeCurrent (libGLX_nvidia.so.0 + 0x6d1a8)
#7 0x00000000f76a3026 n/a (libGLX.so.0 + 0x23026)
#8 0x00000000f76a9c85 n/a (libGLX.so.0 + 0x29c85)
#9 0x00000000eee7a98e n/a (/home/onni/.local/share/Steam/ubuntu12_32/vgui2_s.so + 0x5798e)
ELF object binary architecture: Intel 80386
