Arducam GMSL2 8MP Camera with VL-GM2-8CAM-RPI22
Is camera from Arducam GMSL2 8MP Camera Extension Kit for NVIDIA Jetson Orin Nano/Orin NX compatible with VL-GM2-8CAM-RPI22?
To determine the compatibility of the Arducam GMSL2 8MP Camera Extension Kit for NVIDIA Jetson Orin Nano/Orin NX with the VLGM28CAMRPI22, we need to analyze the camera interface and specifications.
The Jetson Orin Nano and Orin NX modules have a MIPI CSI interface, which is a standard interface for camera modules. The Arducam GMSL2 8MP Camera Extension Kit is designed for NVIDIA Jetson Orin Nano/Orin NX and uses the GMSL2 (Gigabit Multimedia Serial Link 2) interface, which is a high-speed interface for camera modules.
The VLGM28CAMRPI22 is a camera module that uses the MIPI CSI interface. To determine compatibility, we need to check if the VLGM28CAMRPI22 camera module is compatible with the GMSL2 interface used by the Arducam camera extension kit.
Unfortunately, the provided context does not contain specific information about the VLGM28CAMRPI22 camera module’s interface or compatibility with GMSL2. However, we can make an educated guess based on the general information about camera interfaces.
MIPI CSI and GMSL2 are two different interfaces, and they are not directly compatible. MIPI CSI is a standard interface for camera modules, while GMSL2 is a high-speed interface used for specific camera applications.
Given this information, it is unlikely that the VLGM28CAMRPI22 camera module, which uses the MIPI CSI interface, is directly compatible with the Arducam GMSL2 8MP Camera Extension Kit for NVIDIA Jetson Orin Nano/Orin NX.
However, it is possible to use adapters or converters to convert the MIPI CSI interface to GMSL2, but this would require additional hardware and software modifications.
In summary, without specific information about the VLGM28CAMRPI22 camera module’s interface or compatibility with GMSL2, it is unlikely that it is directly compatible with the Arducam GMSL2 8MP Camera Extension Kit for NVIDIA Jetson Orin Nano/Orin NX. Further research and investigation are needed to determine the compatibility of these two devices.
IMHO this is extremely specific. Let’s say I buy VL-GM2-8CAM-RPI22 deserialiser and Arducam GMSL2 8MP Camera Extension Kit for NVIDIA Jetson Orin Nano/Orin NX. Now I take the camera from the latter and connect with the former. Will it work so Jetson AGX Orin will be able to receive the frames?
I would also like to generalise the question. Is any GMSL2 camera usually compatible with any GMSL2 deserialiser (that is compatible with NVIDIA Jetson AGX Orin being connected via MIPI interface)?
Suppose yes if follow the MIPI spec.
