Are 3 chained together Sparks useful?
Is chaining 3 Sparks more powerful than 2? I don’t see many TP3 recipes and it seems like an awkward number to be.
I already have 1 Spark. And I can get a bundle of 2 at a decent price.
I’d end up with 3, which seems like awkward spot.
Would love to hear from people who have 3, or others who decided against it.
I personally use the first spark for many small models (TTS, STT, OCR and also a Qwen3.8-27B), then the remaining two sparks for a bigger but smarter model (Deepseek V4 Flash or GLM 5.3-Flash). I think this is a great combination (although I would still want a 4th Spark if possible…)
Hey, I’m currently running a cluster of 4 Sparks.
Sparks are generally set up in clusters of 2, 4, or 8 to handle high-parameter models, so I’d recommend going with 4 rather than 3.
To your question about why there aren’t many TP3 recipes out there - it’s basically the same reason 2 or 4 makes more sense. KV heads and model architecture in general are designed around even numbers. If you end up with 3, you’ll likely find yourself wanting to expand to 4 anyway (unless you’re fine running it as 2+1).
The catch is that once you go to 4, you’ll need a separate switch, and the resource investment keeps creeping up from there.
So my suggestion would be to start with 2, and if that ends up feeling insufficient, add another 2 later to get to a 4-node cluster.
Yes, two for GLM 5.3 flash with max kv cache, another one hosts asr/tts/MiniMax H3 or image generators. You have a whole studio then
