in one of the HPE server inventory we observed one NIC card is different than others,
What may went wrong here ? is the below picture slot1 expected to be ConnectX-6 Dx 100GE 2P NIC, but it is showing Mellanox network adapter, is it cosmic error or some wrong adapter may be inserted in that slot or network plugin unit is missing ?
Hello praveen,
Thank you for posting your inquiry on the NVIDIA Developer Forum - Infrastructure and Networking - Section.
The issue you are facing can have different root causes.
- Hardware has limitation regarding the quantity of network adapters support in the system and under the installed OS
- Adapter is faulty. Triage step would be moving the adapter to another slot and see if the issue follows the adapter
- PCI Slot faulty. Same triage steps as previous bullet. If issue resides with slot, slot is malfunctioning and support should be obtained by HPE
Thank you and regards,
~NVIDIA Networking Technical Support
