Are there plans to implement -ffinite-math-only -fno-signed-zeros?
Or -ffast-math in general, for that matter…
See Compiler Explorer
Using clang, no code is generated for the arithmetic bits, since for normal floating points the result is NOOP (add and subtract the same amount).
NVCC cannot optimize that. In simulation codes where a lot of constants are used (think stencil codes) this implies unnecessary operations. In order to work around this, we need to employ rather ugly code generation to explicitly list the operations for each direction instead of using a simple table of constants like we can do on CPU.
Also notice that the integer version is not fully optimized. NVCC does succeed in removing the multiplication by 0, but not in realizing that the addition and subtraction cancel out. Earlier versions of clang (16 an earlier) do not optimize this either.
The integer version will be fully optimized if input pointer and output pointer are marked as __restrict__ to tell the compiler there is no pointer aliasing. The float version is unaffected.
Are you referring to host-code clang? Because the godbolt link you provided shows arithmetic being generated from cuclang.
I guess I must be dense.
Anyway the way to make a feature request the usual suggestion is to file a bug. Future plans are rarely discussed on these forums.
I understand the code deposited at Compile Explorer is just an example, but off-hand I don’t see how -fno-signed-zeros would help with code like this? In the context of addition signed zeros usually don’t propagate far, and by initializing with +0 that seems certain here?
The utility of -ffinite-math-only I can see, as without it the additions cannot be optimized out because A[i] could be infinity, in which case -INF + INF must deliver a NaN, so the addition cannot simply be removed.
Historically, when it comes to floating-point computation, the general philosophy of the CUDA compiler has been to treat such code conservatively, with the exception of FMA merging, which is turned on by default because it is just too important to fully utilize the computational throuighput of the GPU, but it can be turned off with a compiler switch. The existing -use_fast_math switch activates a very specific set of “looseness” features in handling floating-point computations that was designed for staying performance-competitive with code written using NVIDIA’s Cg shading language in the early days of CUDA. You can tell its one of the earliest switches because it doesn’t follow the regular convention (using underscore instead of dash).
The conservative treatment of floating-point computation was motivated by the desire to keep programmer’s sanity by not destroying carefully crafted numerical algorithms. This is something various host compilers of the time did at the drop of a hat, with poorly designed or unavailable compiler switches to control it. Minimizing programmer frustration is paramount when trying to establish a new computing platform. To be perfectly honest, I have been writing high-performance floating-point code for almost three decades, and I usually go with the equivalent of what clang folks know as -ffp-model=strict or -ffp-model=precise to maintain my sanity.
The compiler world has progressed since these design decisions were made. Supporting deviations from IEEE-754 compliant floating-point handling with fairly fine-grained opt-in features with which programmers are familiar from other tool chains seems non-problematic in principle. If you decide to file an enhancement request with NVIDIA (which I would encourage), make sure to include motivation, e.g. how much performance gain at application level would be expected, which application areas could benefit, etc. NVIDIA has historically been very open to customer requests, that is how CUDA and its ecosystem grew. The more customers ask for the same feature, the wider the general applicability, and the more pronounced the impact of what is being requested the higher the chances that feature will get implemented.
Good point, this is useful, thanks!
I meant that using cuclang, for the float kernel:
__global__ void floatKernel(const float *A, float *C, int numElements) {
  int i = blockDim.x * blockIdx.x + threadIdx.x;
    if (i < numElements)
        C[i] = 0.f;
        C[i] += 1 * A[i];
        C[i] += -1 * A[i];
        C[i] += 0 * A[i];
I get this PTX:
        ld.param.u64    %rd2, [floatKernel(float const*, float*, int)_param_1];
        cvta.to.global.u64      %rd3, %rd2;
        ld.param.u32    %r1, [floatKernel(float const*, float*, int)_param_2];
        mov.u32         %r2, %ntid.x;
        mov.u32         %r3, %ctaid.x;
        mov.u32         %r4, %tid.x;
        mad.lo.s32      %r5, %r2, %r3, %r4;
        setp.ge.s32     %p1, %r5, %r1;
        @%p1 bra        $L__BB0_2;
        mul.wide.s32    %rd4, %r5, 4;
        add.s64         %rd1, %rd3, %rd4;
        mov.b32         %r6, 0;
        st.global.u32   [%rd1], %r6;
$L__BB0_2:
        ret;
For the simplified kernel:
        C[i] = 0.f;
I get the same PTX:
        @%p1 bra        $L__BB0_2;
        mov.b32         %r6, 0;
$L__BB0_2:
        ret;
I thought the same, but when I remove the -fno-signed-zeros from the options code is generated for the arithmetic bits, removing -fno-signed-zerosresults in more code. Actually -ffinite-math-only > no flags > -fno-signed-zeros > -fno-signed-zeros -ffinite-math-only, by LOC. I don’t get the compiler logic though.
Thanks, that is encouraging! I’ll look into it. I can work a bit and provide actual performance numbers (naive implementation with all the mults by 0, 1, -1, vs CAS-generated simplifed expressions). Off the top of my head it is about 20-30%, so pretty significant.
Is cuclang something that is provided and/or maintained by NVIDIA?
My advice to file an enhancement request with NVIDIA was based on the assumption that you are using nvcc with its LLVM-derived NVVM component for generating PTX, which is then in turn compiled into SASS (machine code) by NVIDIA’s proprietary optimizing compiler ptxas.
Since PTX code represents both a virtual architecture and a compiler intermediate representation, meaningful performance assessments in CUDA context must always consider SASS rather than PTX. In this case the result is unlikely to look much different, as pxtas invoked as part of the CUDA toolchain follows the same conservative approach with regard to floating-point computation that I outline earlier.
It can be non-trivial to determine what code transformations are “legal” with (1) full IEEE-754 compliance (2) specific parts of IEEE-754 compliance removed. It takes a lot of careful reasoning taking into account exactly what properties are guaranteed under various switch settings and what corner cases arise from that. This is also an area where compilers still have many flaws. The Intel “classic” compiler was the most reliable one in this regard, after many years of trying to improve floating-point consistency. But it was abandoned three years ago in favor of a clang-based solution, and it seems Intel engineers are now busy teaching that compiler proper floating-point handling.
I recently was looking at some fairly simple code compiled by the latest clang which contained two calls to sqrtf(). With somewhat relaxed floating-point settings, the first one got translated into a naked square root instruction, while the second one resulted in a call to the system math library. I could not figure out what caused this discrepancy. My goal was to have both sqrtf() instances map directly to a square root instruction. I have yet to resolve that issue.
Agreed, if I provide numbers, they must be runtime numbers.
I just did compile the float example ptx to SASS for clang and nvcc and they are both identical without -ffast-math. Removal of the arithmetic part with -ffast-math can be seen in the SASS, as you correctly suspected.
When I click on the godbolt link you provided, I get this PTX:
.visible .entry floatKernel(float const*, float*, int)(
        .param .u64 floatKernel(float const*, float*, int)_param_0,
        .param .u64 floatKernel(float const*, float*, int)_param_1,
        .param .u32 floatKernel(float const*, float*, int)_param_2
        ld.param.u64    %rd1, [floatKernel(float const*, float*, int)_param_0];
        ld.param.u32    %r2, [floatKernel(float const*, float*, int)_param_2];
        mov.u32         %r3, %ntid.x;
        mov.u32         %r4, %ctaid.x;
        mov.u32         %r5, %tid.x;
        mad.lo.s32      %r1, %r3, %r4, %r5;
        setp.ge.s32     %p1, %r1, %r2;
        @%p1 bra        $L__BB0_2;
        mul.wide.s32    %rd4, %r1, 4;
        add.s64         %rd5, %rd3, %rd4;
        mov.u32         %r6, 0;
        st.global.u32   [%rd5], %r6;
        cvta.to.global.u64      %rd6, %rd1;
        add.s64         %rd7, %rd6, %rd4;
        ld.global.f32   %f1, [%rd7];
        add.ftz.f32     %f2, %f1, 0f00000000;
        st.global.f32   [%rd5], %f2;
        ld.global.f32   %f3, [%rd7];
        sub.ftz.f32     %f4, %f2, %f3;
        st.global.f32   [%rd5], %f4;
        ld.global.f32   %f5, [%rd7];
        fma.rn.ftz.f32  %f6, %f5, 0f00000000, %f4;
        st.global.f32   [%rd5], %f6;
$L__BB0_2:
        ret;
Looks different. Strange.
Maybe you are looking at the right column? that’s the NVCC output, the middle column is the clang-cu output.
