I am using Jetson TX2 module with internal sound card for one of my project. In this design I am using DMIC3 and DSPK2 ports. Mic and speaker both are working with below mixer settings.
Firmware: R32.4.2
1.Enabling DMIC Routing Path
amixer -c tegrasndt186ref cset name=“MVC1 Mux” DMIC3
amixer -c tegrasndt186ref cset name=“ADMAIF1 Mux” MVC1
amixer -c tegrasndt186ref cset name=“DMIC3 Boost Gain” 50
amixer -c tegrasndt186ref cset name=“MVC1 Vol” 12602
amixer -c tegrasndt186ref cset name=“MVC1 input bit format” 32
amixer -c tegrasndt186ref cset name=“DMIC3 output bit format” 32
2.Enabling DSPK Routing Path
amixer -c tegrasndt186ref cset name=“DSPK2 Mux” ADMAIF1
3.Increase dmic gain
amixer -c tegrasndt186ref sset “DMIC3 Boost Gain” 1000
4.increase speaker volume
amixer -c tegrasndt186ref cset name=“MVC1 Mux” ADMAIF1
amixer -c tegrasndt186ref cset name=“DSPK2 Mux” MVC1
5.Record and play commands
echo “MIC:Recording started” | tee -a /media/log/arecord_log.txt
arecord -D hw:tegrasndt186ref,0 -r 48000 -c 1 -f S16_LE mic_testing.wav >> /dev/null 2>&1 &
echo “SPEAKER:Playback started” | tee -a /media/log/arecord_log.txt
aplay -D hw:tegrasndt186ref,0 /thermal_app/data/mic_testing.wav >> /dev/null 2>&1 &
But sometimes the dmic is unable to record and giving below error
root@localhost:/home/ubuntu# arecord -D hw:tegrasndt186ref,0 -r 48000 -c 1 -f S16_LE mic_testing2.wav
Recording WAVE ‘mic_testing2.wav’ : Signed 16 bit Little Endian, Rate 48000 Hz, Mono
arecord: pcm_read:2103: read error: Input/output error
while aplay also the recorded file is terminating within 1-2 sec and plays nothing
Please suggest why this error is occured
Also attaching Debug Trace for the same:
root@localhost:/home/ubuntu# sudo cat /sys/kernel/debug/tracing/trace
tracer: nop
entries-in-buffer/entries-written: 74/74 #P:6
_-----=> irqs-off
/ _----=> need-resched
| / _---=> hardirq/softirq
|| / _--=> preempt-depth
||| / delay
TASK-PID CPU# |||| TIMESTAMP FUNCTION
alsa-sink-ADMAI-6837 [000] … 78.781325: snd_soc_dapm_widget_power: widget=Playback 1 val=1
alsa-sink-ADMAI-6837 [000] … 78.781395: snd_soc_dapm_widget_power: widget=ADMAIF1 Receive val=1
alsa-sink-ADMAI-6837 [000] … 78.781414: snd_soc_dapm_widget_power: widget=ADMAIF1 RX val=1
alsa-sink-ADMAI-6837 [000] … 78.781528: snd_soc_dapm_widget_power: widget=DSPK2 Mux val=1
alsa-sink-ADMAI-6837 [000] … 78.781571: snd_soc_dapm_widget_power: widget=I2S1 Mux val=1
alsa-sink-ADMAI-6837 [000] … 78.781575: snd_soc_dapm_widget_power: widget=DSPK2 TX val=1
alsa-sink-ADMAI-6837 [000] … 78.781582: snd_soc_dapm_widget_power: widget=I2S1 TX val=1
alsa-sink-ADMAI-6837 [000] … 78.781590: snd_soc_dapm_widget_power: widget=DSPK2 Transmit val=1
alsa-sink-ADMAI-6837 [000] … 78.781600: snd_soc_dapm_widget_power: widget=I2S1 Transmit val=1
alsa-sink-ADMAI-6837 [000] … 78.781607: snd_soc_dapm_widget_power: widget=DSPK2 Transmit-DSPK2 CIF Receive val=1
alsa-sink-ADMAI-6837 [000] … 78.781615: snd_soc_dapm_widget_power: widget=I2S1 Transmit-I2S1 CIF Receive val=1
alsa-sink-ADMAI-6837 [000] … 78.781625: snd_soc_dapm_widget_power: widget=DSPK2 CIF Receive val=1
alsa-sink-ADMAI-6837 [000] … 78.781636: snd_soc_dapm_widget_power: widget=I2S1 CIF Receive val=1
alsa-sink-ADMAI-6837 [000] … 78.781644: snd_soc_dapm_widget_power: widget=DSPK2 DAP TX val=1
alsa-sink-ADMAI-6837 [000] … 78.781655: snd_soc_dapm_widget_power: widget=I2S1 CIF RX val=1
alsa-sink-ADMAI-6837 [000] … 78.781667: snd_soc_dapm_widget_power: widget=DSPK2 DAP Transmit val=1
alsa-sink-ADMAI-6837 [000] … 78.781678: snd_soc_dapm_widget_power: widget=I2S1 DAP TX val=1
alsa-sink-ADMAI-6837 [000] … 78.781692: snd_soc_dapm_widget_power: widget=DSPK2 DAP Transmit-d1 Playback val=1
alsa-sink-ADMAI-6837 [000] … 78.781700: snd_soc_dapm_widget_power: widget=I2S1 DAP Transmit val=1
alsa-sink-ADMAI-6837 [000] … 78.781708: snd_soc_dapm_widget_power: widget=d1 Playback val=1
alsa-sink-ADMAI-6837 [000] … 78.781718: snd_soc_dapm_widget_power: widget=I2S1 DAP Transmit-x Playback val=1
alsa-sink-ADMAI-6837 [000] … 78.781846: snd_soc_dapm_widget_power: widget=d1 OUT val=1
alsa-sink-ADMAI-6837 [000] … 78.781861: snd_soc_dapm_widget_power: widget=x Playback val=1
alsa-sink-ADMAI-6837 [000] … 78.781868: snd_soc_dapm_widget_power: widget=d1 Headphone val=1
alsa-sink-ADMAI-6837 [000] … 78.781876: snd_soc_dapm_widget_power: widget=x OUT val=1
alsa-sink-ADMAI-6837 [000] … 78.781889: snd_soc_dapm_widget_power: widget=x Headphone val=1
alsa-source-ADM-6844 [000] … 78.855567: snd_soc_dapm_widget_power: widget=Capture 1 val=1
alsa-source-ADM-6844 [000] … 78.855611: snd_soc_dapm_widget_power: widget=ADMAIF1 Transmit val=1
alsa-source-ADM-6844 [000] … 78.855631: snd_soc_dapm_widget_power: widget=ADMAIF1 TX val=1
alsa-source-ADM-6844 [000] … 78.855634: snd_soc_dapm_widget_power: widget=ADMAIF1 Mux val=1
alsa-source-ADM-6844 [000] … 78.855957: snd_soc_dapm_widget_power: widget=MVC1 RX val=1
alsa-source-ADM-6844 [000] … 78.855969: snd_soc_dapm_widget_power: widget=MVC1 Receive val=1
alsa-source-ADM-6844 [000] … 78.855980: snd_soc_dapm_widget_power: widget=MVC1 MVC Transmit-MVC1 Receive val=1
alsa-source-ADM-6844 [000] … 78.855988: snd_soc_dapm_widget_power: widget=MVC1 MVC Transmit val=1
alsa-source-ADM-6844 [000] … 78.855991: snd_soc_dapm_widget_power: widget=MVC1 MVC TX val=1
alsa-source-ADM-6844 [000] … 78.855999: snd_soc_dapm_widget_power: widget=MVC1 MVC RX val=1
alsa-source-ADM-6844 [000] … 78.856006: snd_soc_dapm_widget_power: widget=MVC1 MVC Receive val=1
alsa-source-ADM-6844 [000] … 78.856013: snd_soc_dapm_widget_power: widget=MVC1 Transmit-MVC1 MVC Receive val=1
alsa-source-ADM-6844 [000] … 78.856016: snd_soc_dapm_widget_power: widget=MVC1 Transmit val=1
alsa-source-ADM-6844 [000] … 78.856021: snd_soc_dapm_widget_power: widget=MVC1 TX val=1
alsa-source-ADM-6844 [000] … 78.856027: snd_soc_dapm_widget_power: widget=MVC1 Mux val=1
alsa-source-ADM-6844 [000] … 78.856333: snd_soc_dapm_widget_power: widget=DMIC3 RX val=1
alsa-source-ADM-6844 [000] … 78.856345: snd_soc_dapm_widget_power: widget=DMIC3 Receive val=1
alsa-source-ADM-6844 [000] … 78.856352: snd_soc_dapm_widget_power: widget=DMIC3 DMIC Transmit-DMIC3 Receive val=1
alsa-source-ADM-6844 [000] … 78.856360: snd_soc_dapm_widget_power: widget=DMIC3 DMIC Transmit val=1
alsa-source-ADM-6844 [000] … 78.856370: snd_soc_dapm_widget_power: widget=DMIC3 DMIC TX val=1
alsa-source-ADM-6844 [000] … 78.856376: snd_soc_dapm_widget_power: widget=DMIC3 DMIC RX val=1
alsa-source-ADM-6844 [000] … 78.856387: snd_soc_dapm_widget_power: widget=DMIC3 DMIC Receive val=1
alsa-source-ADM-6844 [000] … 78.856394: snd_soc_dapm_widget_power: widget=c Capture-DMIC3 DMIC Receive val=1
alsa-source-ADM-6844 [000] … 78.856401: snd_soc_dapm_widget_power: widget=c Capture val=1
alsa-source-ADM-6844 [000] … 78.856411: snd_soc_dapm_widget_power: widget=c IN val=1
alsa-source-ADM-6844 [000] … 78.856421: snd_soc_dapm_widget_power: widget=c Mic val=1
pulseaudio-6808 [004] … 78.878417: snd_soc_dapm_widget_power: widget=Playback 1 val=0
pulseaudio-6808 [004] … 78.878425: snd_soc_dapm_widget_power: widget=ADMAIF1 Receive val=0
pulseaudio-6808 [004] … 78.878427: snd_soc_dapm_widget_power: widget=ADMAIF1 RX val=0
pulseaudio-6808 [004] … 78.878438: snd_soc_dapm_widget_power: widget=DSPK2 Mux val=0
pulseaudio-6808 [004] … 78.878444: snd_soc_dapm_widget_power: widget=I2S1 Mux val=0
pulseaudio-6808 [004] … 78.878446: snd_soc_dapm_widget_power: widget=DSPK2 TX val=0
pulseaudio-6808 [004] … 78.878448: snd_soc_dapm_widget_power: widget=I2S1 TX val=0
pulseaudio-6808 [004] … 78.878449: snd_soc_dapm_widget_power: widget=DSPK2 Transmit val=0
pulseaudio-6808 [004] … 78.878451: snd_soc_dapm_widget_power: widget=I2S1 Transmit val=0
pulseaudio-6808 [004] … 78.878452: snd_soc_dapm_widget_power: widget=DSPK2 Transmit-DSPK2 CIF Receive val=0
pulseaudio-6808 [004] … 78.878454: snd_soc_dapm_widget_power: widget=I2S1 Transmit-I2S1 CIF Receive val=0
pulseaudio-6808 [004] … 78.878456: snd_soc_dapm_widget_power: widget=DSPK2 CIF Receive val=0
pulseaudio-6808 [004] … 78.878458: snd_soc_dapm_widget_power: widget=I2S1 CIF Receive val=0
pulseaudio-6808 [004] … 78.878459: snd_soc_dapm_widget_power: widget=DSPK2 DAP TX val=0
pulseaudio-6808 [004] … 78.878462: snd_soc_dapm_widget_power: widget=I2S1 CIF RX val=0
pulseaudio-6808 [004] … 78.878463: snd_soc_dapm_widget_power: widget=DSPK2 DAP Transmit val=0
pulseaudio-6808 [004] … 78.878465: snd_soc_dapm_widget_power: widget=I2S1 DAP TX val=0
pulseaudio-6808 [004] … 78.878467: snd_soc_dapm_widget_power: widget=DSPK2 DAP Transmit-d1 Playback val=0
pulseaudio-6808 [004] … 78.878469: snd_soc_dapm_widget_power: widget=I2S1 DAP Transmit val=0
pulseaudio-6808 [004] … 78.878471: snd_soc_dapm_widget_power: widget=d1 Playback val=0
pulseaudio-6808 [004] … 78.878472: snd_soc_dapm_widget_power: widget=I2S1 DAP Transmit-x Playback val=0
pulseaudio-6808 [004] … 78.878474: snd_soc_dapm_widget_power: widget=d1 OUT val=0
pulseaudio-6808 [004] … 78.878475: snd_soc_dapm_widget_power: widget=x Playback val=0
pulseaudio-6808 [004] … 78.878477: snd_soc_dapm_widget_power: widget=d1 Headphone val=0
pulseaudio-6808 [004] … 78.878478: snd_soc_dapm_widget_power: widget=x OUT val=0
pulseaudio-6808 [004] … 78.878480: snd_soc_dapm_widget_power: widget=x Headphone val=0
pulseaudio-6808 [005] … 78.885073: snd_soc_dapm_widget_power: widget=Capture 1 val=0
pulseaudio-6808 [005] … 78.885077: snd_soc_dapm_widget_power: widget=ADMAIF1 Transmit val=0
pulseaudio-6808 [005] … 78.885078: snd_soc_dapm_widget_power: widget=ADMAIF1 TX val=0
pulseaudio-6808 [005] … 78.885079: snd_soc_dapm_widget_power: widget=ADMAIF1 Mux val=0
pulseaudio-6808 [005] … 78.885094: snd_soc_dapm_widget_power: widget=MVC1 RX val=0
pulseaudio-6808 [005] … 78.885096: snd_soc_dapm_widget_power: widget=MVC1 Receive val=0
pulseaudio-6808 [005] … 78.885097: snd_soc_dapm_widget_power: widget=MVC1 MVC Transmit-MVC1 Receive val=0
pulseaudio-6808 [005] … 78.885098: snd_soc_dapm_widget_power: widget=MVC1 MVC Transmit val=0
pulseaudio-6808 [005] … 78.885099: snd_soc_dapm_widget_power: widget=MVC1 MVC TX val=0
pulseaudio-6808 [005] … 78.885100: snd_soc_dapm_widget_power: widget=MVC1 MVC RX val=0
pulseaudio-6808 [005] … 78.885101: snd_soc_dapm_widget_power: widget=MVC1 MVC Receive val=0
pulseaudio-6808 [005] … 78.885102: snd_soc_dapm_widget_power: widget=MVC1 Transmit-MVC1 MVC Receive val=0
pulseaudio-6808 [005] … 78.885102: snd_soc_dapm_widget_power: widget=MVC1 Transmit val=0
pulseaudio-6808 [005] … 78.885103: snd_soc_dapm_widget_power: widget=MVC1 TX val=0
pulseaudio-6808 [005] … 78.885104: snd_soc_dapm_widget_power: widget=MVC1 Mux val=0
pulseaudio-6808 [005] … 78.885118: snd_soc_dapm_widget_power: widget=DMIC3 RX val=0
pulseaudio-6808 [005] … 78.885121: snd_soc_dapm_widget_power: widget=DMIC3 Receive val=0
pulseaudio-6808 [005] … 78.885122: snd_soc_dapm_widget_power: widget=DMIC3 DMIC Transmit-DMIC3 Receive val=0
pulseaudio-6808 [005] … 78.885123: snd_soc_dapm_widget_power: widget=DMIC3 DMIC Transmit val=0
pulseaudio-6808 [005] … 78.885124: snd_soc_dapm_widget_power: widget=DMIC3 DMIC TX val=0
pulseaudio-6808 [005] … 78.885125: snd_soc_dapm_widget_power: widget=DMIC3 DMIC RX val=0
pulseaudio-6808 [005] … 78.885126: snd_soc_dapm_widget_power: widget=DMIC3 DMIC Receive val=0
pulseaudio-6808 [005] … 78.885127: snd_soc_dapm_widget_power: widget=c Capture-DMIC3 DMIC Receive val=0
pulseaudio-6808 [005] … 78.885128: snd_soc_dapm_widget_power: widget=c Capture val=0
pulseaudio-6808 [005] … 78.885128: snd_soc_dapm_widget_power: widget=c IN val=0
pulseaudio-6808 [005] … 78.885129: snd_soc_dapm_widget_power: widget=c Mic val=0
arecord-7592 [000] … 89.370297: snd_soc_dapm_widget_power: widget=Capture 1 val=1
arecord-7592 [000] … 89.370309: snd_soc_dapm_widget_power: widget=ADMAIF1 Transmit val=1
arecord-7592 [000] … 89.370314: snd_soc_dapm_widget_power: widget=ADMAIF1 TX val=1
arecord-7592 [000] … 89.370319: snd_soc_dapm_widget_power: widget=ADMAIF1 Mux val=1
arecord-7592 [000] … 89.370354: snd_soc_dapm_widget_power: widget=MVC1 RX val=1
arecord-7592 [000] … 89.370362: snd_soc_dapm_widget_power: widget=MVC1 Receive val=1
arecord-7592 [000] … 89.370366: snd_soc_dapm_widget_power: widget=MVC1 MVC Transmit-MVC1 Receive val=1
arecord-7592 [000] … 89.370370: snd_soc_dapm_widget_power: widget=MVC1 MVC Transmit val=1
arecord-7592 [000] … 89.370373: snd_soc_dapm_widget_power: widget=MVC1 MVC TX val=1
arecord-7592 [000] … 89.370378: snd_soc_dapm_widget_power: widget=MVC1 MVC RX val=1
arecord-7592 [000] … 89.370381: snd_soc_dapm_widget_power: widget=MVC1 MVC Receive val=1
arecord-7592 [000] … 89.370384: snd_soc_dapm_widget_power: widget=MVC1 Transmit-MVC1 MVC Receive val=1
arecord-7592 [000] … 89.370387: snd_soc_dapm_widget_power: widget=MVC1 Transmit val=1
arecord-7592 [000] … 89.370391: snd_soc_dapm_widget_power: widget=MVC1 TX val=1
arecord-7592 [000] … 89.370395: snd_soc_dapm_widget_power: widget=MVC1 Mux val=1
arecord-7592 [000] … 89.370431: snd_soc_dapm_widget_power: widget=DMIC3 RX val=1
arecord-7592 [000] … 89.370439: snd_soc_dapm_widget_power: widget=DMIC3 Receive val=1
arecord-7592 [000] … 89.370443: snd_soc_dapm_widget_power: widget=DMIC3 DMIC Transmit-DMIC3 Receive val=1
arecord-7592 [000] … 89.370447: snd_soc_dapm_widget_power: widget=DMIC3 DMIC Transmit val=1
arecord-7592 [000] … 89.370451: snd_soc_dapm_widget_power: widget=DMIC3 DMIC TX val=1
arecord-7592 [000] … 89.370454: snd_soc_dapm_widget_power: widget=DMIC3 DMIC RX val=1
arecord-7592 [000] … 89.370458: snd_soc_dapm_widget_power: widget=DMIC3 DMIC Receive val=1
arecord-7592 [000] … 89.370462: snd_soc_dapm_widget_power: widget=c Capture-DMIC3 DMIC Receive val=1
arecord-7592 [000] … 89.370465: snd_soc_dapm_widget_power: widget=c Capture val=1
arecord-7592 [000] … 89.370469: snd_soc_dapm_widget_power: widget=c IN val=1
arecord-7592 [000] … 89.370472: snd_soc_dapm_widget_power: widget=c Mic val=1
arecord-7592 [000] … 97.275626: snd_soc_dapm_widget_power: widget=Capture 1 val=0
arecord-7592 [000] … 97.275708: snd_soc_dapm_widget_power: widget=ADMAIF1 Transmit val=0
arecord-7592 [000] … 97.275716: snd_soc_dapm_widget_power: widget=ADMAIF1 TX val=0
arecord-7592 [000] … 97.275722: snd_soc_dapm_widget_power: widget=ADMAIF1 Mux val=0
arecord-7592 [000] … 97.276010: snd_soc_dapm_widget_power: widget=MVC1 RX val=0
arecord-7592 [000] … 97.276022: snd_soc_dapm_widget_power: widget=MVC1 Receive val=0
arecord-7592 [000] … 97.276033: snd_soc_dapm_widget_power: widget=MVC1 MVC Transmit-MVC1 Receive val=0
arecord-7592 [000] … 97.276040: snd_soc_dapm_widget_power: widget=MVC1 MVC Transmit val=0
arecord-7592 [000] … 97.276047: snd_soc_dapm_widget_power: widget=MVC1 MVC TX val=0
arecord-7592 [000] … 97.276055: snd_soc_dapm_widget_power: widget=MVC1 MVC RX val=0
arecord-7592 [000] … 97.276061: snd_soc_dapm_widget_power: widget=MVC1 MVC Receive val=0
arecord-7592 [000] … 97.276068: snd_soc_dapm_widget_power: widget=MVC1 Transmit-MVC1 MVC Receive val=0
arecord-7592 [000] … 97.276071: snd_soc_dapm_widget_power: widget=MVC1 Transmit val=0
arecord-7592 [000] … 97.276075: snd_soc_dapm_widget_power: widget=MVC1 TX val=0
arecord-7592 [000] … 97.276078: snd_soc_dapm_widget_power: widget=MVC1 Mux val=0
arecord-7592 [000] … 97.276374: snd_soc_dapm_widget_power: widget=DMIC3 RX val=0
arecord-7592 [000] … 97.276390: snd_soc_dapm_widget_power: widget=DMIC3 Receive val=0
arecord-7592 [000] … 97.276397: snd_soc_dapm_widget_power: widget=DMIC3 DMIC Transmit-DMIC3 Receive val=0
arecord-7592 [000] … 97.276405: snd_soc_dapm_widget_power: widget=DMIC3 DMIC Transmit val=0
arecord-7592 [000] … 97.276416: snd_soc_dapm_widget_power: widget=DMIC3 DMIC TX val=0
arecord-7592 [000] … 97.276423: snd_soc_dapm_widget_power: widget=DMIC3 DMIC RX val=0
arecord-7592 [000] … 97.276431: snd_soc_dapm_widget_power: widget=DMIC3 DMIC Receive val=0
arecord-7592 [000] … 97.276438: snd_soc_dapm_widget_power: widget=c Capture-DMIC3 DMIC Receive val=0
arecord-7592 [000] … 97.276446: snd_soc_dapm_widget_power: widget=c Capture val=0
arecord-7592 [000] … 97.276453: snd_soc_dapm_widget_power: widget=c IN val=0
arecord-7592 [000] … 97.276464: snd_soc_dapm_widget_power: widget=c Mic val=0
aplay-7593 [000] … 102.814736: snd_soc_dapm_widget_power: widget=Playback 1 val=1
aplay-7593 [000] … 102.814740: snd_soc_dapm_widget_power: widget=ADMAIF1 Receive val=1
aplay-7593 [000] … 102.814741: snd_soc_dapm_widget_power: widget=ADMAIF1 RX val=1
aplay-7593 [000] … 102.814748: snd_soc_dapm_widget_power: widget=DSPK2 Mux val=1
aplay-7593 [000] … 102.814751: snd_soc_dapm_widget_power: widget=I2S1 Mux val=1
aplay-7593 [000] … 102.814752: snd_soc_dapm_widget_power: widget=DSPK2 TX val=1
aplay-7593 [000] … 102.814754: snd_soc_dapm_widget_power: widget=I2S1 TX val=1
aplay-7593 [000] … 102.814755: snd_soc_dapm_widget_power: widget=DSPK2 Transmit val=1
aplay-7593 [000] … 102.814755: snd_soc_dapm_widget_power: widget=I2S1 Transmit val=1
aplay-7593 [000] … 102.814756: snd_soc_dapm_widget_power: widget=DSPK2 Transmit-DSPK2 CIF Receive val=1
aplay-7593 [000] … 102.814757: snd_soc_dapm_widget_power: widget=I2S1 Transmit-I2S1 CIF Receive val=1
aplay-7593 [000] … 102.814758: snd_soc_dapm_widget_power: widget=DSPK2 CIF Receive val=1
aplay-7593 [000] … 102.814759: snd_soc_dapm_widget_power: widget=I2S1 CIF Receive val=1
aplay-7593 [000] … 102.814760: snd_soc_dapm_widget_power: widget=DSPK2 DAP TX val=1
aplay-7593 [000] … 102.814760: snd_soc_dapm_widget_power: widget=I2S1 CIF RX val=1
aplay-7593 [000] … 102.814761: snd_soc_dapm_widget_power: widget=DSPK2 DAP Transmit val=1
aplay-7593 [000] … 102.814762: snd_soc_dapm_widget_power: widget=I2S1 DAP TX val=1
aplay-7593 [000] … 102.814763: snd_soc_dapm_widget_power: widget=DSPK2 DAP Transmit-d1 Playback val=1
aplay-7593 [000] … 102.814764: snd_soc_dapm_widget_power: widget=I2S1 DAP Transmit val=1
aplay-7593 [000] … 102.814765: snd_soc_dapm_widget_power: widget=d1 Playback val=1
aplay-7593 [000] … 102.814765: snd_soc_dapm_widget_power: widget=I2S1 DAP Transmit-x Playback val=1
aplay-7593 [000] … 102.814766: snd_soc_dapm_widget_power: widget=d1 OUT val=1
aplay-7593 [000] … 102.814767: snd_soc_dapm_widget_power: widget=x Playback val=1
aplay-7593 [000] … 102.814768: snd_soc_dapm_widget_power: widget=d1 Headphone val=1
aplay-7593 [000] … 102.814769: snd_soc_dapm_widget_power: widget=x OUT val=1
aplay-7593 [000] … 102.814770: snd_soc_dapm_widget_power: widget=x Headphone val=1
aplay-7593 [000] … 108.498683: snd_soc_dapm_widget_power: widget=Playback 1 val=0
aplay-7593 [000] … 108.498697: snd_soc_dapm_widget_power: widget=ADMAIF1 Receive val=0
aplay-7593 [000] … 108.498702: snd_soc_dapm_widget_power: widget=ADMAIF1 RX val=0
aplay-7593 [000] … 108.498727: snd_soc_dapm_widget_power: widget=DSPK2 Mux val=0
aplay-7593 [000] … 108.498739: snd_soc_dapm_widget_power: widget=I2S1 Mux val=0
aplay-7593 [000] … 108.498744: snd_soc_dapm_widget_power: widget=DSPK2 TX val=0
aplay-7593 [000] … 108.498748: snd_soc_dapm_widget_power: widget=I2S1 TX val=0
aplay-7593 [000] … 108.498752: snd_soc_dapm_widget_power: widget=DSPK2 Transmit val=0
aplay-7593 [000] … 108.498756: snd_soc_dapm_widget_power: widget=I2S1 Transmit val=0
aplay-7593 [000] … 108.498760: snd_soc_dapm_widget_power: widget=DSPK2 Transmit-DSPK2 CIF Receive val=0
aplay-7593 [000] … 108.498765: snd_soc_dapm_widget_power: widget=I2S1 Transmit-I2S1 CIF Receive val=0
aplay-7593 [000] … 108.498769: snd_soc_dapm_widget_power: widget=DSPK2 CIF Receive val=0
aplay-7593 [000] … 108.498773: snd_soc_dapm_widget_power: widget=I2S1 CIF Receive val=0
aplay-7593 [000] … 108.498777: snd_soc_dapm_widget_power: widget=DSPK2 DAP TX val=0
aplay-7593 [000] … 108.498781: snd_soc_dapm_widget_power: widget=I2S1 CIF RX val=0
aplay-7593 [000] … 108.498785: snd_soc_dapm_widget_power: widget=DSPK2 DAP Transmit val=0
aplay-7593 [000] … 108.498789: snd_soc_dapm_widget_power: widget=I2S1 DAP TX val=0
aplay-7593 [000] … 108.498794: snd_soc_dapm_widget_power: widget=DSPK2 DAP Transmit-d1 Playback val=0
aplay-7593 [000] … 108.498799: snd_soc_dapm_widget_power: widget=I2S1 DAP Transmit val=0
aplay-7593 [000] … 108.498803: snd_soc_dapm_widget_power: widget=d1 Playback val=0
aplay-7593 [000] … 108.498807: snd_soc_dapm_widget_power: widget=I2S1 DAP Transmit-x Playback val=0
aplay-7593 [000] … 108.498811: snd_soc_dapm_widget_power: widget=d1 OUT val=0
aplay-7593 [000] … 108.498815: snd_soc_dapm_widget_power: widget=x Playback val=0
aplay-7593 [000] … 108.498819: snd_soc_dapm_widget_power: widget=d1 Headphone val=0
aplay-7593 [000] … 108.498822: snd_soc_dapm_widget_power: widget=x OUT val=0
aplay-7593 [000] … 108.498826: snd_soc_dapm_widget_power: widget=x Headphone val=0
aplay-7630 [000] … 150.845969: snd_soc_dapm_widget_power: widget=Playback 1 val=1
aplay-7630 [000] … 150.845974: snd_soc_dapm_widget_power: widget=ADMAIF1 Receive val=1
aplay-7630 [000] … 150.845976: snd_soc_dapm_widget_power: widget=ADMAIF1 RX val=1
aplay-7630 [000] … 150.845982: snd_soc_dapm_widget_power: widget=MVC1 Mux val=1
aplay-7630 [000] … 150.845986: snd_soc_dapm_widget_power: widget=I2S1 Mux val=1
aplay-7630 [000] … 150.845988: snd_soc_dapm_widget_power: widget=MVC1 TX val=1
aplay-7630 [000] … 150.845989: snd_soc_dapm_widget_power: widget=I2S1 TX val=1
aplay-7630 [000] … 150.845990: snd_soc_dapm_widget_power: widget=MVC1 Transmit val=1
aplay-7630 [000] … 150.845991: snd_soc_dapm_widget_power: widget=I2S1 Transmit val=1
aplay-7630 [000] … 150.845992: snd_soc_dapm_widget_power: widget=MVC1 Transmit-MVC1 MVC Receive val=1
aplay-7630 [000] … 150.845993: snd_soc_dapm_widget_power: widget=I2S1 Transmit-I2S1 CIF Receive val=1
aplay-7630 [000] … 150.845994: snd_soc_dapm_widget_power: widget=MVC1 MVC Receive val=1
aplay-7630 [000] … 150.845995: snd_soc_dapm_widget_power: widget=I2S1 CIF Receive val=1
aplay-7630 [000] … 150.845996: snd_soc_dapm_widget_power: widget=MVC1 MVC RX val=1
aplay-7630 [000] … 150.845997: snd_soc_dapm_widget_power: widget=I2S1 CIF RX val=1
aplay-7630 [000] … 150.845998: snd_soc_dapm_widget_power: widget=MVC1 MVC TX val=1
aplay-7630 [000] … 150.845999: snd_soc_dapm_widget_power: widget=I2S1 DAP TX val=1
aplay-7630 [000] … 150.846001: snd_soc_dapm_widget_power: widget=MVC1 MVC Transmit val=1
aplay-7630 [000] … 150.846002: snd_soc_dapm_widget_power: widget=I2S1 DAP Transmit val=1
aplay-7630 [000] … 150.846003: snd_soc_dapm_widget_power: widget=MVC1 MVC Transmit-MVC1 Receive val=1
aplay-7630 [000] … 150.846004: snd_soc_dapm_widget_power: widget=I2S1 DAP Transmit-x Playback val=1
aplay-7630 [000] … 150.846005: snd_soc_dapm_widget_power: widget=MVC1 Receive val=1
aplay-7630 [000] … 150.846006: snd_soc_dapm_widget_power: widget=x Playback val=1
aplay-7630 [000] … 150.846008: snd_soc_dapm_widget_power: widget=MVC1 RX val=1
aplay-7630 [000] … 150.846011: snd_soc_dapm_widget_power: widget=x OUT val=1
aplay-7630 [000] … 150.846015: snd_soc_dapm_widget_power: widget=DSPK2 Mux val=1
aplay-7630 [000] … 150.846019: snd_soc_dapm_widget_power: widget=x Headphone val=1
aplay-7630 [000] … 150.846021: snd_soc_dapm_widget_power: widget=DSPK2 TX val=1
aplay-7630 [000] … 150.846023: snd_soc_dapm_widget_power: widget=DSPK2 Transmit val=1
aplay-7630 [000] … 150.846024: snd_soc_dapm_widget_power: widget=DSPK2 Transmit-DSPK2 CIF Receive val=1
aplay-7630 [000] … 150.846026: snd_soc_dapm_widget_power: widget=DSPK2 CIF Receive val=1
aplay-7630 [000] … 150.846028: snd_soc_dapm_widget_power: widget=DSPK2 DAP TX val=1
aplay-7630 [000] … 150.846029: snd_soc_dapm_widget_power: widget=DSPK2 DAP Transmit val=1
aplay-7630 [000] … 150.846031: snd_soc_dapm_widget_power: widget=DSPK2 DAP Transmit-d1 Playback val=1
aplay-7630 [000] … 150.846033: snd_soc_dapm_widget_power: widget=d1 Playback val=1
aplay-7630 [000] … 150.846034: snd_soc_dapm_widget_power: widget=d1 OUT val=1
aplay-7630 [000] … 150.846035: snd_soc_dapm_widget_power: widget=d1 Headphone val=1
aplay-7630 [000] … 150.893125: snd_soc_dapm_widget_power: widget=Playback 1 val=0
aplay-7630 [000] … 150.893134: snd_soc_dapm_widget_power: widget=ADMAIF1 Receive val=0
aplay-7630 [000] … 150.893139: snd_soc_dapm_widget_power: widget=ADMAIF1 RX val=0
aplay-7630 [000] … 150.893161: snd_soc_dapm_widget_power: widget=MVC1 Mux val=0
aplay-7630 [000] … 150.893175: snd_soc_dapm_widget_power: widget=I2S1 Mux val=0
aplay-7630 [000] … 150.893180: snd_soc_dapm_widget_power: widget=MVC1 TX val=0
aplay-7630 [000] … 150.893184: snd_soc_dapm_widget_power: widget=I2S1 TX val=0
aplay-7630 [000] … 150.893188: snd_soc_dapm_widget_power: widget=MVC1 Transmit val=0
aplay-7630 [000] … 150.893191: snd_soc_dapm_widget_power: widget=I2S1 Transmit val=0
aplay-7630 [000] … 150.893195: snd_soc_dapm_widget_power: widget=MVC1 Transmit-MVC1 MVC Receive val=0
aplay-7630 [000] … 150.893199: snd_soc_dapm_widget_power: widget=I2S1 Transmit-I2S1 CIF Receive val=0
aplay-7630 [000] … 150.893203: snd_soc_dapm_widget_power: widget=MVC1 MVC Receive val=0
aplay-7630 [000] … 150.893206: snd_soc_dapm_widget_power: widget=I2S1 CIF Receive val=0
aplay-7630 [000] … 150.893209: snd_soc_dapm_widget_power: widget=MVC1 MVC RX val=0
aplay-7630 [000] … 150.893212: snd_soc_dapm_widget_power: widget=I2S1 CIF RX val=0
aplay-7630 [000] … 150.893216: snd_soc_dapm_widget_power: widget=MVC1 MVC TX val=0
aplay-7630 [000] … 150.893219: snd_soc_dapm_widget_power: widget=I2S1 DAP TX val=0
aplay-7630 [000] … 150.893223: snd_soc_dapm_widget_power: widget=MVC1 MVC Transmit val=0
aplay-7630 [000] … 150.893226: snd_soc_dapm_widget_power: widget=I2S1 DAP Transmit val=0
aplay-7630 [000] … 150.893230: snd_soc_dapm_widget_power: widget=MVC1 MVC Transmit-MVC1 Receive val=0
aplay-7630 [000] … 150.893234: snd_soc_dapm_widget_power: widget=I2S1 DAP Transmit-x Playback val=0
aplay-7630 [000] … 150.893238: snd_soc_dapm_widget_power: widget=MVC1 Receive val=0
aplay-7630 [000] … 150.893241: snd_soc_dapm_widget_power: widget=x Playback val=0
aplay-7630 [000] … 150.893244: snd_soc_dapm_widget_power: widget=MVC1 RX val=0
aplay-7630 [000] … 150.893256: snd_soc_dapm_widget_power: widget=x OUT val=0
aplay-7630 [000] … 150.893270: snd_soc_dapm_widget_power: widget=DSPK2 Mux val=0
aplay-7630 [000] … 150.893276: snd_soc_dapm_widget_power: widget=x Headphone val=0
aplay-7630 [000] … 150.893283: snd_soc_dapm_widget_power: widget=DSPK2 TX val=0
aplay-7630 [000] … 150.893288: snd_soc_dapm_widget_power: widget=DSPK2 Transmit val=0
aplay-7630 [000] … 150.893293: snd_soc_dapm_widget_power: widget=DSPK2 Transmit-DSPK2 CIF Receive val=0
aplay-7630 [000] … 150.893297: snd_soc_dapm_widget_power: widget=DSPK2 CIF Receive val=0
aplay-7630 [000] … 150.893301: snd_soc_dapm_widget_power: widget=DSPK2 DAP TX val=0
aplay-7630 [000] … 150.893305: snd_soc_dapm_widget_power: widget=DSPK2 DAP Transmit val=0
aplay-7630 [000] … 150.893308: snd_soc_dapm_widget_power: widget=DSPK2 DAP Transmit-d1 Playback val=0
aplay-7630 [000] … 150.893312: snd_soc_dapm_widget_power: widget=d1 Playback val=0
aplay-7630 [000] … 150.893315: snd_soc_dapm_widget_power: widget=d1 OUT val=0
aplay-7630 [000] … 150.893319: snd_soc_dapm_widget_power: widget=d1 Headphone val=0
