• Network Type (Detectnet_v2/)
• TLT Version (3.0)
I trained a custom Detectnet model on TlT version 3.0. While eporting the tlt file to the etlt format I passed the --gen_ds_config as I need the deepstream labels and config files. However, TLT does not recognize the argument. The command I’m trying to run in the Jupyter notebook:
!mkdir -p $LOCAL_EXPERIMENT_DIR/experiment_dir_final
# Removing a pre-existing copy of the etlt if there has been any.
import os
output_file=os.path.join(os.environ['LOCAL_EXPERIMENT_DIR'],
"experiment_dir_final/resnet18_detector.etlt")
if os.path.exists(output_file):
os.system("rm {}".format(output_file))
!tlt detectnet_v2 export \
-m $USER_EXPERIMENT_DIR/experiment_dir_unpruned/weights/resnet18_detector.tlt \
-o $USER_EXPERIMENT_DIR/experiment_dir_final/resnet18_detector.etlt \
-k $KEY \
--gen_ds_config
The error I get:
Matplotlib created a temporary config/cache directory at /tmp/matplotlib-3k65viqr because the default path (/.config/matplotlib) is not a writable directory; it is highly recommended to set the MPLCONFIGDIR environment variable to a writable directory, in particular to speed up the import of Matplotlib and to better support multiprocessing.
Using TensorFlow backend.
usage: detectnet_v2 [-h] [--gpus GPUS] [--gpu_index GPU_INDEX [GPU_INDEX ...]]
[--use_amp] [--log_file LOG_FILE]
{calibration_tensorfile,dataset_convert,evaluate,export,inference,prune,train}
detectnet_v2: error: unrecognized arguments: --gen_ds_config
2021-07-14 11:22:13,414 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
Please note that if I do NOT pass the --gen_ds_config then the exports command works. Please advise as to how to fix this.
Can you run below command to check the tlt version?
$ tlt info --verbose
And also can you run following command and paste the result?
$ tlt detectnet_v2 export
On my side, I can run well with “–gen_ds_config”
$ tlt detectnet_v2 export -m /workspace/demo_2.0/peoplenet_retrain/resnet34_peoplenet.tlt -o /workspace/demo_2.0/peoplenet_retrain/resnet34_peoplenet_new.etlt -k tlt_encode --gen_ds_config -e /workspace/demo_2.0/peoplenet_retrain/detectnet_v2_train_resnet34_kitti.txt
2021-07-14 15:21:48,932 [INFO] root: Registry: [‘nvcr.io’]
2021-07-14 15:21:52,639 [WARNING] tlt.components.docker_handler.docker_handler:
Docker will run the commands as root. If you would like to retain your
local host permissions, please add the “user”:“UID:GID” in the
DockerOptions portion of the ~/.tlt_mounts.json file. You can obtain your
users UID and GID by using the “id -u” and “id -g” commands on the
terminal.
WARNING:tensorflow:Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
2021-07-14 07:22:00,415 [INFO] iva.detectnet_v2.spec_handler.spec_loader: Merging specification from /workspace/demo_2.0/peoplenet_retrain/detectnet_v2_train_resnet34_kitti.txt
2021-07-14 07:22:05,056 [INFO] iva.common.export.keras_exporter: Using input nodes: [‘input_1’]
2021-07-14 07:22:05,056 [INFO] iva.common.export.keras_exporter: Using output nodes: [‘output_cov/Sigmoid’, ‘output_bbox/BiasAdd’]
/usr/local/lib/python3.6/dist-packages/keras/engine/saving.py:292: UserWarning: No training configuration found in save file: the model was not compiled. Compile it manually.
warnings.warn('No training configuration found in save file: ’
NOTE: UFF has been tested with TensorFlow 1.14.0.
WARNING: The version of TensorFlow installed on this system is not guaranteed to work with UFF.
2021-07-14 07:22:22,750 [INFO] modulus.export._uff: Modulus patch identity layer in padding inputs.
2021-07-14 07:22:23,045 [INFO] modulus.export._uff: Modulus patch identity layer in padding inputs.
DEBUG [/usr/local/lib/python3.6/dist-packages/uff/converters/tensorflow/converter.py:96] Marking [‘output_cov/Sigmoid’, ‘output_bbox/BiasAdd’] as outputs
2021-07-14 15:23:08,122 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
(nvidia) vast@remote-subhankar:~/tlt$ tlt detectnet_v2 export
Matplotlib created a temporary config/cache directory at /tmp/matplotlib-ijwgyuvy because the default path (/.config/matplotlib) is not a writable directory; it is highly recommended to set the MPLCONFIGDIR environment variable to a writable directory, in particular to speed up the import of Matplotlib and to better support multiprocessing.
usage: detectnet_v2 export [-h] [--gpus GPUS]
[--gpu_index GPU_INDEX [GPU_INDEX ...]] [--use_amp]
[--log_file LOG_FILE] -m MODEL -k KEY
[-o OUTPUT_FILE] [--force_ptq]
[--cal_data_file CAL_DATA_FILE]
[--cal_image_dir CAL_IMAGE_DIR]
[--data_type {fp32,fp16,int8}] [-s]
[--cal_cache_file CAL_CACHE_FILE]
[--batches BATCHES]
[--max_workspace_size MAX_WORKSPACE_SIZE]
[--max_batch_size MAX_BATCH_SIZE]
[--batch_size BATCH_SIZE] [-e EXPERIMENT_SPEC]
[--engine_file ENGINE_FILE] [-v]
detectnet_v2 export: error: the following arguments are required: -m/--model, -k/--key
2021-07-14 13:05:10,179 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
