if simultaneously started
A) argus stream:
“gst-launch-1.0 nvarguscamerasrc ! ‘video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)NV12, framerate=(fraction)30/1’ ! fakesink silent=false -v”
B) USB storage write
“dd if=/dev/zero of=/mnt/flash_mount/tmp.raw bs=1M count=10000”
Argus stream is stopped if USB disconnected (physically)
with argus log:
SCF: Error Timeout: FuSa Capture Status failed! (in src/services/capture/FusaCaptureIspHw.cpp, function waitIspFrameEnd(), line 365)
SCF: Error InvalidState: (propagating from src/services/capture/FusaCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 593)
SCF: Error InvalidState: (propagating from src/common/Utils.cpp, function workerThread(), line 114)
SCF: Error InvalidState: Worker thread ViCsiHw frameComplete failed (in src/common/Utils.cpp, function workerThread(), line 133)
SCF: Error ResourceAlreadyInUse: (propagating from src/services/capture/FusaCaptureViCsiHw.cpp, function startCaptureInternal(), line 809)
SCF: Error ResourceAlreadyInUse: (propagating from src/services/capture/CaptureRecord.cpp, function doCSItoMemCapture(), line 530)
SCF: Error ResourceAlreadyInUse: (propagating from src/services/capture/CaptureRecord.cpp, function issueCapture(), line 477)
SCF: Error ResourceAlreadyInUse: (propagating from src/services/capture/CaptureServiceDevice.cpp, function issueCaptures(), line 1291)
SCF: Error ResourceAlreadyInUse: (propagating from src/services/capture/CaptureServiceDevice.cpp, function issueCaptures(), line 1122)
SCF: Error ResourceAlreadyInUse: (propagating from src/common/Utils.cpp, function workerThread(), line 114)
SCF: Error ResourceAlreadyInUse: Worker thread CaptureScheduler frameStart failed (in src/common/Utils.cpp, function workerThread(), line 133)
SCF: Error Timeout: (propagating from src/api/Buffer.cpp, function waitForUnlock(), line 643)
SCF: Error Timeout: (propagating from src/components/CaptureContainerImpl.cpp, function returnBuffer(), line 373)
SCF: Error Timeout: (propagating from src/components/amr/Snapshot.cpp, function waitForNewerSample(), line 91)
SCF_AutocontrolACSync failed to wait for an earlier frame to complete.
SCF: Error Timeout: (propagating from src/components/ac_stages/ACSynchronizeStage.cpp, function doHandleRequest(), line 126)
SCF: Error Timeout: (propagating from src/components/stages/OrderedStage.cpp, function doExecute(), line 137)
SCF: Error Timeout: Sending critical error event (in src/api/Session.cpp, function sendErrorEvent(), line 979)
SCF: Error Timeout: (propagating from src/services/capture/CaptureServiceEvent.cpp, function wait(), line 59)
