My board is Jetson Xavier NX, and the kernel version is R35.3.1. Based on this version, I have developed the driver for the camera imx556 and can get the data normally. Now I want to use argus api to get metadata. Two weeks ago I could get raw data and metadata using the two examples of rawBayerOutput and sensorPrivateMetadata. But suddenly all the examples related to argus no longer work. I suspected that I accidentally configured some wrong environments that caused this problem, so I reinstalled the system’s related SDK, but the result was still the same.
Below is my error log:
pcai@ubuntu:/usr/src/jetson_multimedia_api/argus/build/samples/rawBayerOutput$ sudo ./argus_rawBayerOutput
[sudo] password for pcai:
Executing Argus Sample: argus_rawBayerOutput
Argus Version: 0.99.3.3 (multi-process)
Capturing from Resolution (640x480)
PRODUCER: Creating the preview stream.
PRODUCER: Starting repeat capture requests.
Error generated. /usr/src/jetson_multimedia_api/argus/samples/rawBayerOutput/main.cpp, execute:264 Failed to get consumer
(Argus) Error Timeout: (propagating from src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 137)
(Argus) Error Timeout: (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 91)
(Argus) Error InvalidState: Argus client is exiting with 2 outstanding client threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 366)
The following is the log information of sudo /usr/sbin/nvargus-daemon:
pcai@ubuntu:/usr/src/jetson_multimedia_api/argus/build/samples/rawBayerOutput$ sudo /usr/sbin/nvargus-daemon
=== NVIDIA Libargus Camera Service (0.99.33)=== Listening for connections...=== argus_rawBayerOutput[4465]: Connection established (FFFF86003900)OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module1
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module10
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module11
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module2
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module3
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module4
OFParserEnumerateDriverNode: v4l2_sensor: failed to parse device-tree to driver node
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module5
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module6
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module7
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module8
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module9
NvPclHwGetModuleList: WARNING: Could not map module to ISP config string
NvPclHwGetModuleList: No module data found
OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
---- imager: No override file found. ----
(NvCamV4l2) Error ModuleNotPresent: V4L2Device not available (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function findDevice(), line 256)
(NvCamV4l2) Error ModuleNotPresent: (propagating from /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function initialize(), line 60)
(NvOdmDevice) Error ModuleNotPresent: (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function initialize(), line 107)
NvPclDriverInitializeData: Unable to initialize driver v4l2_sensor
NvPclInitializeDrivers: error: Failed to init camera sub module v4l2_sensor
NvPclStartPlatformDrivers: Failed to start module drivers
NvPclStateControllerOpen: Failed ImagerGUID 0. (error 0xA000E)
NvPclOpen: PCL Open Failed. Error: 0xf
SCF: Error BadParameter: Sensor could not be opened. (in src/services/capture/CaptureServiceDeviceSensor.cpp, function getSourceFromGuid(), line 689)
SCF: Error BadParameter: (propagating from src/services/capture/CaptureService.cpp, function addSourceByGuid(), line 453)
SCF: Error BadParameter: (propagating from src/api/CameraDriver.cpp, function addSourceByIndex(), line 333)
SCF: Error BadParameter: (propagating from src/api/CameraDriver.cpp, function getSource(), line 505)
NvPclStateControllerOpen: Failed ImagerGUID 1. (error 0xA000E)
NvPclStateControllerOpen: Failed ImagerGUID 2. (error 0xA000E)
LSC: LSC surface is not based on full res!
(Argus) Error BadParameter: Unidentified sensor placement (in src/common/ScfTranslate.cpp, function fromScfSensorPlacement(), line 595)
NvPclStateControllerOpen: Failed ImagerGUID 4. (error 0xA000E)
NvPclStateControllerOpen: Failed ImagerGUID 5. (error 0xA000E)
(NvOdmDevice) Error NotInitialized: hDev Table not initialized (in dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function initialize(), line 97)
NvPclStateControllerOpen: Failed ImagerGUID 6. (error 0x3)
NvPclStateControllerOpen: Failed ImagerGUID 7. (error 0x3)
NvPclStateControllerOpen: Failed ImagerGUID 8. (error 0x3)
NvPclStateControllerOpen: Failed ImagerGUID 9. (error 0x3)
NvPclStateControllerOpen: Failed ImagerGUID 10. (error 0xA000E)
NvPclStateControllerOpen: Failed ImagerGUID 11. (error 0xA000E)
=== argus_rawBayerOutput[4465]: CameraProvider initialized (0xffff80616dc0)SCF: Error BadValue: NvPHSSendThroughputHints (in src/common/CameraPowerHint.cpp, function sendCameraPowerHint(), line 56)
PowerServiceCore:handleRequests: timePassed = 549
SCF: Error InvalidState: 1 buffers still pending during EGLStreamProducer destruction (propagating from src/services/gl/EGLStreamProducer.cpp, function freeBuffers(), line 300)
SCF: Error InvalidState: (propagating from src/services/gl/EGLStreamProducer.cpp, function ~EGLStreamProducer(), line 49)
SCF: Error InvalidState: Timeout waiting on frame start sensor guid 3, capture sequence ID = 0 (in src/services/capture/FusaCaptureViCsiHw.cpp, function waitCsiFrameStart(), line 514)
SCF: Error InvalidState: (propagating from src/common/Utils.cpp, function workerThread(), line 114)
SCF: Error InvalidState: Worker thread ViCsiHw frameStart failed (in src/common/Utils.cpp, function workerThread(), line 133)
SCF: Error Timeout: (propagating from src/services/capture/FusaCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 600)
SCF: Error Timeout: (propagating from src/common/Utils.cpp, function workerThread(), line 114)
SCF: Error Timeout: Worker thread ViCsiHw frameComplete failed (in src/common/Utils.cpp, function workerThread(), line 133)
SCF: Error Timeout: (propagating from src/services/capture/CaptureServiceEvent.cpp, function wait(), line 59)
Error: Camera HwEvents wait, this may indicate a hardware timeout occured,abort current/incoming cc
waitForIdleLocked remaining request 101
SCF: Error Timeout: waitForIdle() timed out (in src/api/Session.cpp, function waitForIdleLocked(), line 922)
(Argus) Error Timeout: (propagating from src/api/CaptureSessionImpl.cpp, function destroy(), line 216)
SCF: Error Timeout: (propagating from src/services/capture/CaptureServiceDeviceViCsi.cpp, function waitCompletion(), line 368)
SCF: Error Timeout: (propagating from src/services/capture/CaptureServiceDevice.cpp, function pause(), line 936)
SCF: Error Timeout: During capture abort, syncpoint wait timeout waiting for current frame to finish (in src/services/capture/CaptureServiceDevice.cpp, function handleCancelSourceRequests(), line 1029)
SCF: Error Timeout: (propagating from src/api/Session.cpp, function abortCaptures(), line 888)
SCF: Error Timeout: (propagating from src/api/Session.cpp, function shutdown(), line 407)
Please help me, thank you very much! ! !
