HI, all:
I have a problem about tx2 camera.
I write a camera driver, and the v4l2-ctrl is ok. I can get picture through command v4l2-ctrl. But argus_camera is error.
The app log as blow:
nvidia@tegra-ubuntu:~$ argus_camera
Executing Argus Sample Application (argus_camera)
Argus Version: UNKNOWN
Error generated. /home/nvidia/tegra_multimedia_api/argus/apps/camera/modules/Dispatcher.cpp, initialize:850 No cameras available
Error generated. /home/nvidia/tegra_multimedia_api/argus/apps/camera/modules/Dispatcher.cpp, Dispatcher:803 (propagating)
(NvCameraUtils) Error InvalidState: Mutex already initialized (in Mutex.cpp, function initialize(), line 41)
(Argus) Error InvalidState: (propagating from src/rpc/socket/client/ClientSocketManager.cpp, function open(), line 54)
(Argus) Error InvalidState: (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function openSocketConnection(), line 205)
(Argus) Error InvalidState: Cannot create camera provider (in src/rpc/socket/client/SocketClientDispatch.cpp, function createCameraProvider(), line 129)
(Argus) Error EndOfFile: Unexpected error in reading socket (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 214)
(Argus) Error EndOfFile: Receive worker failure, notifying 1 waiting threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 289)
(Argus) Error InvalidState: Argus client is exiting with 1 outstanding client threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 306)
(Argus) Error EndOfFile: Receiving thread terminated with error (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadWrapper(), line 317)
(Argus) Error EndOfFile: Client thread received an error from socket (in src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 149)
(Argus) Error EndOfFile: (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 101)
Error generated. /home/nvidia/tegra_multimedia_api/argus/apps/camera/modules/Dispatcher.cpp, initialize:842 Failed to create CameraProvider
Error generated. /home/nvidia/tegra_multimedia_api/argus/apps/camera/modules/Dispatcher.cpp, getInstance:826 Initalization failed
(Argus) Error FileOperationFailed: Connecting to argus_daemon failed: Connection refused (in src/rpc/socket/client/SocketClientDispatch.cpp, function openSocketConnection(), line 190)
(Argus) Error FileOperationFailed: Cannot create camera provider (in src/rpc/socket/client/SocketClientDispatch.cpp, function createCameraProvider(), line 129)
terminate called after throwing an instance of 'std::logic_error'
what(): basic_string::_M_construct null not valid
Aborted (core dumped)
the other log as blow:
== Listening for connections... ===
=== Connection 7F97F041E0 established ===
Thread 1 getting next capture
Thread 1 is waiting
Thread 2 getting next capture
Thread 2 is waiting
Thread 3 getting next capture
Thread 3 is waiting
Thread 4 getting next capture
Thread 4 is waiting
Thread 5 getting next capture
Thread 5 is waiting
Thread 6 getting next capture
Thread 6 is waiting
Thread 7 getting next capture
Thread 7 is waiting
Thread 8 getting next capture
Thread 8 is waiting
Thread 9 getting next capture
Thread 9 is waiting
Thread 10 getting next capture
Thread 10 is waiting
Thread 11 getting next capture
Thread 11 is waiting
Thread 12 getting next capture
Thread 12 is waiting
Starting services...
Worker thread IspHw statsComplete start
Worker thread IspHw frameComplete start
Worker thread CaptureScheduler checkFramePending start
Worker thread CaptureScheduler frameStart start
Worker thread V4L2CaptureScheduler checkCaptureComplete start
Worker thread V4L2CaptureScheduler issueCaptures start
Worker thread PS handleRequests start
getInstance: s_instance(0x7f90acf850)
subscribe: create SensorType(gyroscope) sensor(0x7f90ad0a00)
subscribe: create SensorType(accelerometer) sensor(0x7f90b310f0)
AC plugin not present: dlopen "acplugin.so", acplugin.so: cannot open shared object file: No such file or directory
Services are started
NvPclSetHotplugCallback: ++++++++++++++++++++++
---- Imager: Calibration blob file handling supported in this build ----
NvPclHwGetModuleList: OFParserListModules Succeeded
CheckProcDTExists: INFO: accessing /proc/device-tree/i2c@c240000/ar0231_a@10; No such file or directory
OFDriverNodeToDict: NVIDIA Camera modules claimed undefined node in proc device-tree: /proc/device-tree/i2c@c240000/ar0231_a@10
OFParserEnumerateDriverNode: v4l2_sensor: failed to parse device-tree to driver node
NvPclHwGetModuleList: WARNING: Could not map module to ISP config string
NvPclHwGetModuleList: No module data found
NvPclHwPrintModuleDefinition -- Name: ar0231_center_liar0231
NvPclHwPrintModuleDefinition -- Position: 2
NvPclHwPrintModuleDefinition -- CalibrationData Found: 1
NvPclHwPrintCameraSubModule -- HwCamSubModule[0].Name: v4l2_sensor
NvPclHwPrintCameraSubModule -- HwCamSubModule[0].DevName: ar0231 30-0010
NvPclModuleListInitialize: NvPclModule list[0]: ar0231_center_liar0231 position2
NvPclHwScanExternalCameras -- adding video0 to discover list
initialize: /dev/video0
queryControls: 10100736 control Frame Length
queryControls: 10100737 control Coarse Time
queryControls: 10100738 control Coarse Time Short
queryControls: 10100739 control Group Hold
queryControls: 10100740 control HDR enable
queryControls: 10100745 control Gain
queryControls: 10100836 control Bypass Mode
queryControls: 10100837 control Override Enable
queryControls: 10100838 control Height Align
queryControls: 10100839 control Size Align
queryControls: 10100840 control Write ISP format
queryControls: 10100841 control Sensor Signal Properties
queryControls: 10100842 control Sensor Image Properties
queryControls: 10100843 control Sensor Control Properties
queryControls: 10100844 control Sensor DV Timings
queryControls: 10100866 control Sensor Modes
Ioctl failed: Invalid argument
getHotplugMonitor: Getting hotplug monitor instance
initializeHotplug++
hotPlugfunc ++
addWatch: Watch added wd='1'
CheckProcDTExists: INFO: accessing /proc/device-tree/tegra-virtual-camera-platform/modules; No such file or directory
OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
setHotplugCallback: Registered new callback client
NvPclSetHotplugCallback: ----------------------
hotPlugfunc: reading from inotify FD, Thread waiting
NvPclOpen: ++++++++++++++++++++++
NvPclStateControllerOpen: Found GUID 2 match at index[0]
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f90b4b260
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f90b4b2f0
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f90b4b380
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f90b4b410
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f90b4b4a0
NvPclHwInitializeModule: allocate overrides pathname @ 0x7f90b4b530
LoadOverridesFile: looking for override file [/Calib/camera_override.isp] 1/16CheckOverridesPermissions: cannot stat file [/Calib/camera_override.isp]
LoadOverridesFile: looking for override file [/data/nvcam/settings/camera_overrides.isp] 2/16CheckOverridesPermissions: cannot stat file [/data/nvcam/settings/camera_overrides.isp]
LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/camera_overrides.isp] 3/16CheckOverridesPermissions: cannot stat file [/opt/nvidia/nvcam/settings/camera_overrides.isp]
LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/camera_overrides.isp] 4/16CheckOverridesPermissions: cannot stat file [/var/nvidia/nvcam/settings/camera_overrides.isp]
LoadOverridesFile: looking for override file [/data/nvcam/camera_overrides.isp] 5/16CheckOverridesPermissions: cannot stat file [/data/nvcam/camera_overrides.isp]
LoadOverridesFile: looking for override file [/data/nvcam/settings/ar0231_center_liar0231.isp] 6/16CheckOverridesPermissions: cannot stat file [/data/nvcam/settings/ar0231_center_liar0231.isp]
LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/ar0231_center_liar0231.isp] 7/16CheckOverridesPermissions: cannot stat file [/opt/nvidia/nvcam/settings/ar0231_center_liar0231.isp]
LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/ar0231_center_liar0231.isp] 8/16CheckOverridesPermissions: cannot stat file [/var/nvidia/nvcam/settings/ar0231_center_liar0231.isp]
---- imager: No override file found. ----
Imager: looking for override file [/mnt/factory/camera/factory.bin] 1/16
Imager: looking for override file [/Calib/factory.bin] 2/16
Imager: looking for override file [/Calib/calibration.bin] 3/16
Imager: looking for override file [(null)] 4/16
Imager: looking for override file [(null)] 5/16
Imager: looking for override file [(null)] 6/16
Imager: looking for override file [(null)] 7/16
Imager: looking for override file [(null)] 8/16
Imager: looking for override file [(null)] 9/16
Imager: looking for override file [(null)] 10/16
Imager: looking for override file [(null)] 11/16
Imager: looking for override file [(null)] 12/16
Imager: looking for override file [(null)] 13/16
Imager: looking for override file [(null)] 14/16
Imager: looking for override file [(null)] 15/16
Imager: looking for override file [(null)] 16/16
Imager: looking for override file [/data/nvcam/settings/factory.bin] 1/16
Imager: looking for override file [/data/nvcam/settings/ar0231_center_liar0231.bin] 2/16
Imager: looking for override file [/opt/nvidia/nvcam/settings/ar0231_center_liar0231.bin] 3/16
Imager: looking for override file [/var/nvidia/nvcam/settings/ar0231_center_liar0231.bin] 4/16
NvPclCreateDriver: Found NvPcl Driver Hal dev_name match (v4l2_sensor)
NvPclCreateDriver: Found a Driver name match (v4l2_sensor)
NvPclConnectDrivers: hImager was NULL, creating new imager
NvPclInitializeDrivers: v4l2_sensor ++++++++++++++++++
(NvOdmDevice) Error NotInitialized: hDev Table not initialized (in dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function initialize(), line 93)
NvPclDriverInitializeData: Unable to initialize driver v4l2_sensor
NvPclInitializeDrivers: error: Failed to init camera sub module v4l2_sensor
NvPclStartPlatformDrivers: Failed to start module drivers
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0x7f90b4b410
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0x7f90b4b4a0
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0x7f90b4b530
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0x7f90b4b260
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0x7f90b4b2f0
NvPclCloseModuleDrivers: deallocate/free overrides pathname @ 0x7f90b4b380
NvPclStateControllerOpen: Failed ImagerGUID 2. (error 0x3)
NvPclStateControllerClose: Module ar0231_center_liar0231 closed
NvPclOpen: PCL Open Failed. Error: 0xf
NvPclClose: ++++++++++++++++++++++
NvPclClose: ----------------------
NvPclOpen: ----------------------
SCF: Error BadParameter: Sensor could not be opened. (in src/services/capture/CaptureServiceDeviceSensor.cpp, function getSourceFromGuid(), line 598)
SCF: Error BadParameter: (propagating from src/services/capture/CaptureService.cpp, function addSourceByGuid(), line 781)
SCF: Error BadParameter: (propagating from src/api/CameraDriver.cpp, function addSourceByIndex(), line 276)
SCF: Error BadParameter: (propagating from src/api/CameraDriver.cpp, function getSource(), line 439)
(Argus) Error BadParameter: (propagating from src/api/CameraProviderImpl.cpp, function initialize(), line 92)
(Argus) Error BadParameter: (propagating from src/api/GlobalProcessState.cpp, function createCameraProvider(), line 214)
Stopping services...
Worker thread CaptureScheduler frameStart stop
Worker thread CaptureScheduler checkFramePending stop
Worker thread IspHw statsComplete stop
Worker thread IspHw frameComplete stop
Worker thread V4L2CaptureScheduler issueCaptures stop
Worker thread V4L2CaptureScheduler checkCaptureComplete stop
NvPclShutdown: ++++++++++++++++++++++
NvPclModuleListShutdown: Client still conntected, skipping shutdown
NvPclShutdown: ----------------------
Worker thread PS handleRequests stop
unsubscribe: gyroscope sensor(0x7f90ad0a00)
unsubscribe: accelerometer sensor(0x7f90b310f0)
Services are stopped
closeInstance: ms_instance((nil))
NvPclRemoveHotplugCallback: ++++++++++++++++++++++
shutdownHotplug: Requesting thread exit
hotPlugfunc: Read 16 bytes from inotify FD
hotPlugfunc: A File was Modified 00008000 NAME : CREATE : 00000100, DELETE : 00000200 IGNORED : 00008000 CLOSE_WRITE : 00000008
hotPlugfunc: Exit thread
hotPlugfunc: close failure error: 'Bad file descriptor' (9)
hotPlugfunc --
shutdownHotplug -- : shutdown of hotplug is complete
Removed callback client
NvPclRemoveHotplugCallback: ----------------------
FiberScheduler: shutting down; 0 fibers still in map
FiberScheduler: thread 1 exiting
FiberScheduler: thread 3 exiting
FiberScheduler: thread 5 exiting
FiberScheduler: thread 7 exiting
FiberScheduler: thread 9 exiting
FiberScheduler: thread 11 exiting
FiberScheduler: thread 2 exitingFiberScheduler: thread 11 has been joined
FiberScheduler: thread 6 exiting
FiberScheduler: thread 10 exiting
FiberScheduler: thread 4 exiting
FiberScheduler: thread 12 exiting
FiberScheduler: thread 10 has been joined
FiberScheduler: thread 8 exiting
FiberScheduler: thread 8 has been joined
FiberScheduler: thread 12 has been joined
FiberScheduler: thread 7 has been joined
FiberScheduler: thread 6 has been joined
FiberScheduler: thread 5 has been joined
FiberScheduler: thread 4 has been joined
FiberScheduler: thread 9 has been joined
FiberScheduler: thread 3 has been joined
FiberScheduler: thread 2 has been joined
FiberScheduler: thread 1 has been joined
CameraProvider result: provider=(nil), shim=0x7f906cc4c0, status=1, rpc status=2, size=9
=== Connection 7F977041E0 established ===
(Argus) Error EndOfFile: (propagating from libs/rpc_socket_server/ServerSocketManager.cpp, function recvThreadCore(), line 138)
(Argus) Error EndOfFile: (propagating from libs/rpc_socket_server/ServerSocketManager.cpp, function run(), line 56)
=== Connection 7F977041E0 closed ===
=== Connection 7F977041E0 cleaned up ===
/== CLEANUP 0x7f906cc4c0 ==\
Destroying real provider (nil)
