Failed to get capture session interface
Kernal Version: R35.4.1 (JetPack5.1.2)
Platform: Xavier Nx
Device: 1 x max9296 + 2 x max9295 + 2 different camera
Question:
arugs_api with each sensor singlely works well and with 2 same sensor works well also. But failed with 2 kind of different sensor. Error log of sample rawBayerOutput shows below:
pcai@pcai-desktop:~/jetson_multimedia_api/argus/build/samples/rawBayerOutput$ sudo ./argus_rawBayerOutput
Executing Argus Sample: argus_rawBayerOutput
Argus Version: 0.99.3.3 (multi-process)
PRODUCER: Creating the JPEG stream.
Capturing from Resolution (1600x1300)
Error generated. /home/pcai/jetson_multimedia_api/argus/samples/rawBayerOutput/main.cpp, execute:218 Failed to create preview session with camera index 0.
(Argus) Error InvalidState:  (propagating from src/eglstream/FrameConsumerImpl.cpp, function streamEventThread(), line 134)
(Argus) Error InvalidState:  (propagating from src/eglstream/FrameConsumerImpl.cpp, function streamEventThreadStatic(), line 176)
And error log of sample argus_syncsensor shows below:
pcai@pcai-desktop:~/jetson_multimedia_api/argus/build/samples/syncSensor$ sudo ./argus_syncsensor
Executing Argus Sample: argus_syncsensor
Error generated. /home/pcai/jetson_multimedia_api/argus/samples/syncSensor/main.cpp, execute:357 Failed to get capture session interface
Error generated. /home/pcai/jetson_multimedia_api/argus/samples/utils/EGLGlobal.cpp, cleanup:150 eglTerminate failed (error 0x3008)
Debug log of nvargus-daemon :
pcai@pcai-desktop:~$ sudo /usr/sbin/nvargus-daemon
=== NVIDIA Libargus Camera Service (0.99.33)=== Listening for connections...=== argus_rawBayerOutput[21270]: Connection established (FFFFA71FD900)OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module1
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module10
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module11
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module2
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module3
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module4
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module5
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module6
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module7
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module8
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module9
NvPclHwGetModuleList: WARNING: Could not map module to ISP config string
NvPclHwGetModuleList: No module data found
OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
---- imager: No override file found. ----
(NvCamV4l2) Error ModuleNotPresent: V4L2Device not available (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function findDevice(), line 256)
(NvCamV4l2) Error ModuleNotPresent:  (propagating from /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function initialize(), line 60)
(NvOdmDevice) Error ModuleNotPresent:  (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function initialize(), line 111)
NvPclDriverInitializeData: Unable to initialize driver v4l2_sensor
NvPclInitializeDrivers: error: Failed to init camera sub module v4l2_sensor
NvPclStartPlatformDrivers: Failed to start module drivers
NvPclStateControllerOpen: Failed ImagerGUID 0. (error 0xA000E)
NvPclOpen: PCL Open Failed. Error: 0xf
SCF: Error BadParameter: Sensor could not be opened. (in src/services/capture/CaptureServiceDeviceSensor.cpp, function getSourceFromGuid(), line 726)
SCF: Error BadParameter:  (propagating from src/services/capture/CaptureService.cpp, function addSourceByGuid(), line 453)
SCF: Error BadParameter:  (propagating from src/api/CameraDriver.cpp, function addSourceByIndex(), line 347)
SCF: Error BadParameter:  (propagating from src/api/CameraDriver.cpp, function getSource(), line 519)
NvPclStateControllerOpen: Failed ImagerGUID 1. (error 0xA000E)
NvPclStateControllerOpen: Failed ImagerGUID 2. (error 0xA000E)
NvPclStateControllerOpen: Failed ImagerGUID 3. (error 0xA000E)
NvPclStateControllerOpen: Failed ImagerGUID 4. (error 0xA000E)
NvPclStateControllerOpen: Failed ImagerGUID 5. (error 0xA000E)
NvPclStateControllerOpen: Failed ImagerGUID 6. (error 0xA000E)
LSC: LSC surface is not based on full res!
NvPclStateControllerOpen: Failed ImagerGUID 8. (error 0xA000E)
NvPclStateControllerOpen: Failed ImagerGUID 9. (error 0xA000E)
NvPclStateControllerOpen: Failed ImagerGUID 11. (error 0xA000E)
=== argus_rawBayerOutput[21270]: CameraProvider initialized (0xffffa0727f90)SCF: Error BadValue: NvPHSSendThroughputHints (in src/common/CameraPowerHint.cpp, function sendCameraPowerHint(), line 56)
SCF: Error InvalidState:  (propagating from src/services/capture/FusaCaptureViCsiHw.cpp, function openViCsi(), line 390)
SCF: Error InvalidState:  (propagating from src/services/capture/CaptureServiceDeviceViCsi.cpp, function open(), line 336)
SCF: Error InvalidState:  (propagating from src/services/capture/CaptureServiceDevice.cpp, function openSource(), line 398)
SCF: Error InvalidState:  (propagating from src/services/capture/CaptureService.cpp, function openSource(), line 501)
SCF: Error InvalidState:  (propagating from src/api/Session.cpp, function initialize(), line 294)
SCF: Error InvalidState:  (propagating from src/api/CameraDriver.cpp, function createSession(), line 645)
(Argus) Error InvalidState:  (propagating from src/api/CaptureSessionImpl.cpp, function initialize(), line 177)
(Argus) Error InvalidState:  (propagating from src/api/CameraProviderImpl.cpp, function createCaptureSessionInternal(), line 305)
(Argus) Error InvalidState: Element not found (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamerautils/inc/Vector.h, function remove(), line 172)
=== argus_rawBayerOutput[21270]: CameraProvider destroyed (0xffffa0727f90)=== argus_rawBayerOutput[21270]: Connection closed (FFFFA71FD900)=== argus_rawBayerOutput[21270]: Connection cleaned up (FFFFA71FD900)
Can someone help point out what could go wrong? Any advice and guidance would begreatly appreciated.
Suppose it could be the device tree configuration cause the problem.
Thanks for your reply.
Could you please tell me if argus support 2 camera on 1 csi port by using deserdes?
And which propertites of device tree I need to check?
For that need to add virtual channel ID in the device tree. You can reference to imx390’s device tree configuration.
With my current device tree configuration, I can get raw data from 4 different camera at the same time through v4l2, and I don’t konw if its misconfiguration v4l2 will work properly.
But I checked “vc-id” and “vc_id”, the two properties of device tree, and compare them to those in imx390.
Unable to find the error. Argus could not run with 2 different camera on 1 csi port at the same time.
I dump the dts file below, please help me check if the error comes from dts.
Thanks a lot!
extracted_proc.dts.txt (395.5 KB)
Do you mean v4l2-ctl working but argus don’t?
Do you boost clocks to try.
sudo su
echo 1 > /sys/kernel/debug/bpmp/debug/clk/vi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/isp/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/nvcsi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/emc/mrq_rate_locked
cat /sys/kernel/debug/bpmp/debug/clk/vi/max_rate |tee /sys/kernel/debug/bpmp/debug/clk/vi/rate
cat /sys/kernel/debug/bpmp/debug/clk/isp/max_rate | tee  /sys/kernel/debug/bpmp/debug/clk/isp/rate
cat /sys/kernel/debug/bpmp/debug/clk/nvcsi/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/nvcsi/rate
cat /sys/kernel/debug/bpmp/debug/clk/emc/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/emc/rate
Yes, v4l2-ctl work but argus don’t.
Why to boost clocks to try? Most of time I rise up a question, the first suggestion is to do that.Just Curious.
I tried boost and argus failed too.
Maybe have device configure as two different sensor and HW connect only one sensor to check if working or not.
Thanks for your quick reply.
Maybe it’s a bug in Argus Version: 0.99.3.3 (multi-process) or in Jetpack5.1.2.
Now I can avoid this question in my practical application.
