Thanks ben.lemond. Using stress --cpu 5 while running our application makes it trigger very easily. It also happens with stress --cpu 4, but not as often. Thus far it’s always the following error (with different frame numbers):
Failed to fetch stats for frame 6763
SCF: Error BadParameter: (propagating from src/services/autocontrol/isp_stats/IspLegacyStatsDecoder.cpp, function decodeIspStats(), line 58)
SCF: Error BadParameter: (propagating from src/services/autocontrol/NvCameraIspDriver.cpp, function updateStats(), line 323)
SCF: Error BadParameter: (propagating from src/components/stages/StatsUpdateStage.cpp, function doHandleRequest(), line 170)
SCF: Error BadParameter: (propagating from src/components/stages/OrderedStage.cpp, function doExecute(), line 158)
SCF: Error BadParameter: Sending critical error event (in src/api/Session.cpp, function sendErrorEvent(), line 990)
Failed to fetch stats for frame 6764
Error 0x00000004 occurred at /dvs/git/dirty/git-master_linux/camera/core_v3/camera_isp/isp/state_update/blocks/stats/LAC.cpp:664
Before getting the quick repeating of:
SCF: Error InvalidState: Session has suffered a critical failure (in src/api/Session.cpp, function capture(), line 667)
(Argus) Error InvalidState: (propagating from src/api/ScfCaptureThread.cpp, function run(), line 109)
Edit: also hit this once (before the repeating error messages started):
SCF: Error NotSupported: AMR Sample data type is error, requested type is IspRawStats* (in src/components/amr/Sample.cpp, function typeError(), line 65)
SCF: Error NotSupported: (in src/components/amr/Sample.cpp, function get(), line 101)
SCF: Error NotSupported: (propagating from src/common/Amr.h, function getSampleObject(), line 488)
SCF: Error NotSupported: (propagating from src/components/ac_stages/AeAfApplyStage.cpp, function translateIspOutStatsToFrd(), line 281)
SCF: Error NotSupported: (propagating from src/components/ac_stages/AeAfApplyStage.cpp, function doHandleRequest(), line 618)
SCF: Error NotSupported: (propagating from src/components/stages/OrderedStage.cpp, function doExecute(), line 137)
SCF: Error NotSupported: Sending critical error event (in src/api/Session.cpp, function sendErrorEvent(), line 990)
