Yes it is when trying to capture and display from 6 IMX274 CSI cameras (“MultiSession” in the argus_camera GUI).
After rebooting + applying your instructions, displaying 6 cameras resulted in only 3 cameras being displayed and the following output:
<!-- Parameters -->
<export name="Quality" from="ltm" attribute="quality" default="3" min=
FNET: Error in /dvs/git/dirty/git-master_linux/camera/utils/nvfnet/src/common/node.cpp function create() line 339
(propagating)
FNET: Error in /dvs/git/dirty/git-master_linux/camera/utils/nvfnet/src/common/node.cpp function create() line 41
(propagating)
FNET: Error in /dvs/git/dirty/git-master_linux/camera/utils/nvfnet/storeHDFX/StoreHDFX.cpp function create() line 92
Out of memory
SCF: Error InsufficientMemory: (propagating from src/components/stages/HdfxStage.cpp, function doAsyncInitialize(), line 147)
SCF: Error InsufficientMemory: HdfxStage initialization failed (in src/components/stages/HdfxStage.cpp, function doAsyncInitialize(), line 252)
FNET: Error in /dvs/git/dirty/git-master_linux/camera/utils/nvfnet/src/common/value.cpp function set() line 115
Invalid default value of type 'vec4'
FNET: Error in /dvs/git/dirty/git-master_linux/camera/utils/nvfnet/src/common/attribute.h function setDefault() line 452
(propagating)
FNET: Error in /dvs/git/dirty/git-master_linux/camera/utils/nvfnet/src/common/node.cpp function handleElementAttribute() line 666
(propagating)
FNET: Error in /dvs/git/dirty/git-master_linux/camera/utils/nvfnet/src/filters/filterUser.cpp function handleElementFilter() line 73
(propagating)
FNET: Error in /dvs/git/dirty/git-master_linux/camera/utils/nvfnet/src/filters/filterUser.cpp function xmlHandleStartElementFilter() line 49
(propagating)
FNET: Error in /dvs/git/dirty/git-master_linux/camera/utils/nvfnet/src/common/xmlParse.cpp function parse() line 146
parsing aborted at line 13:96:
<!-- Flow -->
<flow operation="execute"/>
<flow operation="detach" operand0="inputImag
(propagating)
(propagating)
SCF: Error InsufficientMemory: (propagating from src/components/stages/SharpenStage.cpp, function doAsyncInitialize(), line 159)
SCF: Error InsufficientMemory: SharpenStage initialization failed (in src/components/stages/SharpenStage.cpp, function doAsyncInitialize(), line 182)
PowerServiceCore:handleRequests: timePassed = 707
(NvCamV4l2) Error IoctlFailed: (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function setControlValMultiple(), line 792)
(NvOdmDevice) Error IoctlFailed: (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function setDeviceControls(), line 1856)
updateOutputSettings: Set Control failed. Use cached values
(NvCamV4l2) Error IoctlFailed: (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function streamControl(), line 1661)
(NvOdmDevice) Error IoctlFailed: (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function apply(), line 205)
Error: waitCsiFrameEnd timeout guid 2
VI Stream Id = 3 Virtual Channel = 0
************VI Debug Registers**********
Error: waitCsiFrameStart timeout guid 2
VI_CSIMUX_STAT_FRAME_12 = 0x00000000
VI_CSIMUX_FRAME_STATUS_0 = 0x00000111
VI_CFG_INTERRUPT_STATUS_0 = 0x3f000000
VI_ISPBUFA_ERROR_0 = 0x00000000
VI_FMLITE_ERROR_0 = 0x00000000
VI_NOTIFY_ERROR_0 = 0x00000000
CSI Stream Id = 3 Brick Id = 1
************CSI Debug Registers**********
CILA_INTR_STATUS_CILA[0x20400] = 0x00000000
CILB_INTR_STATUS_CILB[0x20c00] = 0x00000089
INTR_STATUS[0x208a4] = 0x00000000
ERR_INTR_STATUS[0x208ac] = 0x00000000
ERROR_STATUS2VI_VC0[0x20894] = 0x00000000
ERROR_STATUS2VI_VC1[0x20898] = 0x00000000
ERROR_STATUS2VI_VC2[0x2089c] = 0x00000000
ERROR_STATUS2VI_VC3[0x208a0] = 0x00000000
SCF: Error BadValue: timestamp cannot be 0 (in src/services/capture/NvViCsiHw.cpp, function waitCsiFrameEnd(), line 711)
SCF: Error BadValue: (propagating from src/common/Utils.cpp, function workerThread(), line 116)
SCF: Error BadValue: Worker thread ViCsiHw frameComplete failed (in src/common/Utils.cpp, function workerThread(), line 133)
SCF: Error BadValue: timestamp cannot be 0 (in src/services/capture/NvViCsiHw.cpp, function waitCsiFrameStart(), line 624)
SCF: Error BadValue: Worker thread ViCsiHw frameStart failed (in src/common/Utils.cpp, function workerThread(), line 133)
SCF: Error Timeout: (propagating from src/services/capture/CaptureServiceEvent.cpp, function wait(), line 59)
Error: Camera HwEvents wait, this may indicate a hardware timeout occured,abort current/incoming cc
PowerServiceCore:handleRequests: timePassed = 10309
launchCC abort cc 107 session 4
launchCC abort cc 106 session 1
SCF: Error Timeout: (propagating from src/api/Session.cpp, function capture(), line 834)
(Argus) Error Timeout: (propagating from src/api/ScfCaptureThread.cpp, function run(), line 109)
(Argus) Error InvalidState: MetadataResult callback for unknown capture. (in src/api/CaptureSessionImpl.cpp, function metadataResult(), line 906)
launchCC abort cc 107 session 5
Error: waitCsiFrameEnd timeout guid 3
VI Stream Id = 4 Virtual Channel = 0
VI_CSIMUX_STAT_FRAME_16 = 0x00000000
CSI Stream Id = 4 Brick Id = 2
CILA_INTR_STATUS_CILA[0x30400] = 0x00000000
CILB_INTR_STATUS_CILB[0x30c00] = 0x00000000
INTR_STATUS[0x300a4] = 0x00000000
ERR_INTR_STATUS[0x300ac] = 0x00000000
ERROR_STATUS2VI_VC0[0x30094] = 0x00000000
ERROR_STATUS2VI_VC1[0x30098] = 0x00000000
ERROR_STATUS2VI_VC2[0x3009c] = 0x00000000
ERROR_STATUS2VI_VC3[0x300a0] = 0x00000000
Error: waitCsiFrameStart timeout guid 3
Error: waitCsiFrameStart timeout guid 0
VI Stream Id = 5 Virtual Channel = 0
Error: waitCsiFrameEnd timeout guid 0
VI_CSIMUX_STAT_FRAME_20 = 0x00000000
CSI Stream Id = 5 Brick Id = 2
INTR_STATUS[0x308a4] = 0x00000000
ERR_INTR_STATUS[0x308ac] = 0x00000000
ERROR_STATUS2VI_VC0[0x30894] = 0x00000000
ERROR_STATUS2VI_VC1[0x30898] = 0x00000000
ERROR_STATUS2VI_VC2[0x3089c] = 0x00000000
ERROR_STATUS2VI_VC3[0x308a0] = 0x00000000
Killed
