Hi all,
Ihave a system which acquires images from 2 cameras ~30fps. The image is acquired using libargus. After a few days of continuous running my application (without stressing the system) I get following error:
SCF: Error InvalidState: Corr Error Received for sensor 2 .. Continuing!
Mär 09 15:15:26 (in src/services/capture/FusaCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 643)
Mär 09 15:15:26 SCF: Error ResourceAlreadyInUse: (propagating from src/services/capture/FusaCaptureViCsiHw.cpp, function startCaptureInternal(), line 866)
Mär 09 15:15:26 SCF: Error ResourceAlreadyInUse: (propagating from src/services/capture/CaptureRecord.cpp, function doCSItoMemCapture(), line 536)
Mär 09 15:15:26 SCF: Error ResourceAlreadyInUse: (propagating from src/services/capture/CaptureRecord.cpp, function issueCapture(), line 483)
Mär 09 15:15:26 SCF: Error ResourceAlreadyInUse: (propagating from src/services/capture/CaptureServiceDevice.cpp, function issueCaptures(), line 1530)
Mär 09 15:15:26 SCF: Error ResourceAlreadyInUse: (propagating from src/services/capture/CaptureServiceDevice.cpp, function issueCaptures(), line 1359)
Mär 09 15:15:26 SCF: Error ResourceAlreadyInUse: (propagating from src/common/Utils.cpp, function workerThread(), line 114)
Mär 09 15:15:26 SCF: Error ResourceAlreadyInUse: Worker thread CaptureScheduler frameStart failed (in src/common/Utils.cpp, function workerThread(), line 133)
Mär 09 15:15:26 SCF: Error Timeout: (propagating from src/api/Buffer.cpp, function waitForUnlock(), line 644)
Mär 09 15:15:26 SCF: Error Timeout: (propagating from src/components/CaptureContainerImpl.cpp, function returnBuffer(), line 426)
Mär 09 15:15:26 SCF: Error InvalidState: Capture Scheduler not running (in src/services/capture/CaptureServiceDevice.cpp, function addNewItemToSchedule(), line 1004)
Mär 09 15:15:26 SCF: Error InvalidState: (propagating from src/services/capture/CaptureService.cpp, function addRequest(), line 411)
Mär 09 15:15:26 SCF: Error InvalidState: (propagating from src/components/stages/MemoryToISPCaptureStage.cpp, function doHandleRequest(), line 144)
Mär 09 15:15:26 SCF: Error InvalidState: (propagating from src/components/stages/OrderedStage.cpp, function doExecute(), line 158)
Mär 09 15:15:26 SCF: Error InvalidState: Sending critical error event for Session 0
Mär 09 15:15:26 (in src/api/Session.cpp, function sendErrorEvent(), line 1039)
Mär 09 15:15:26 SCF: Error InvalidState: (propagating from src/components/stages/SensorCaptureStage.cpp, function doHandleRequest(), line 87)
my application crashes because the iCaptureSession->isRepeating() fails, which is not recoverable for me.
Is this a known stability issue??
I use JetPack 5.1.2 and argus version is : 0.99.3.3 (multi-process)
I hope someone can help
Edit:
just checked the dmesg log and Im not 100% sure if this is related to this error but it seems like the gpu had some kind of dma error??
[ 7620.240160] __ga10b__
[ 7620.258802] __ga10b__ PBDMA Status - chip ga10b
[ 7620.261420] __ga10b__ -------------------------
[ 7620.265977] __ga10b__ pbdma 0:
[ 7620.270525] __ga10b__ id: -1 - [channel] next_id: - -1 [channel] | status: invalid
[ 7620.273678] __ga10b__ PBDMA_PUT 0000002004300050 PBDMA_GET 0000002004300050
[ 7620.281552] __ga10b__ GP_PUT 00000008 GP_GET 00000008 FETCH 00000008 HEADER 2140006c
[ 7620.288815] __ga10b__ HDR 2001001b SHADOW0 04300028 SHADOW1 00002820
[ 7620.297300] __ga10b__ pbdma 1:
[ 7620.304474] __ga10b__ id: 0 - [tsg] next_id: - -1 [channel] | status: valid
[ 7620.307454] __ga10b__ PBDMA_PUT 0000000200860308 PBDMA_GET 00000002008602f0
[ 7620.315067] __ga10b__ GP_PUT 00000002 GP_GET 00000002 FETCH 00000002 HEADER 20111b00
[ 7620.322415] __ga10b__ HDR 200426c0 SHADOW0 00860294 SHADOW1 00007602
[ 7620.330814] __ga10b__ pbdma 2:
[ 7620.337814] __ga10b__ id: 1 - [tsg] next_id: - -1 [channel] | status: valid
[ 7620.340877] __ga10b__ PBDMA_PUT 0000000200c60d04 PBDMA_GET 0000000200c60d04
[ 7620.348404] __ga10b__ GP_PUT 00000038 GP_GET 00000038 FETCH 00000038 HEADER 21540300
[ 7620.355579] __ga10b__ HDR 200180c0 SHADOW0 00c60cc8 SHADOW1 00003e02
[ 7620.364238] __ga10b__ pbdma 3:
[ 7620.371499] __ga10b__ id: -1 - [channel] next_id: - -1 [channel] | status: invalid
[ 7620.374553] __ga10b__ PBDMA_PUT 0000008410c05818 PBDMA_GET 000000a070a06f44
[ 7620.382353] __ga10b__ GP_PUT 00000000 GP_GET fe15a9a7 FETCH 00000000 HEADER a1c63f50
[ 7620.389526] __ga10b__ HDR 1f0910e2 SHADOW0 61a88841 SHADOW1 40027697
[ 7620.398188] __ga10b__ pbdma 4:
[ 7620.405451] __ga10b__ id: -1 - [channel] next_id: - -1 [channel] | status: invalid
[ 7620.408515] __ga10b__ PBDMA_PUT 0000005938981000 PBDMA_GET 0000007f620df3a0
[ 7620.416303] __ga10b__ GP_PUT 00000000 GP_GET 39d98750 FETCH 00000000 HEADER a102ae94
[ 7620.423477] __ga10b__ HDR 000153c2 SHADOW0 a8395844 SHADOW1 949ce29f
[ 7620.432138] __ga10b__ pbdma 5:
[ 7620.439401] __ga10b__ id: 2 - [tsg] next_id: - -1 [channel] | status: valid
[ 7620.442454] __ga10b__ PBDMA_PUT 0000000201260020 PBDMA_GET 0000000201260020
[ 7620.449990] __ga10b__ GP_PUT 00000001 GP_GET 00000001 FETCH 00000001 HEADER 21540300
[ 7620.457164] __ga10b__ HDR 200180c0 SHADOW0 01060188 SHADOW1 00003e02
[ 7620.465823] __ga10b__
[ 7620.473092] __ga10b__ ga10b eng 0:
[ 7620.475627] __ga10b__ id: 0 (tsg), next_id: -1 (channel), ctx status: valid
[ 7620.479298] __ga10b__ busy
[ 7620.486300] __ga10b__
[ 7620.489187] __ga10b__ ga10b eng 1:
[ 7620.491637] __ga10b__ id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[ 7620.495310] __ga10b__
[ 7620.503189] __ga10b__ ga10b eng 2:
[ 7620.505712] __ga10b__ id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[ 7620.509310] __ga10b__
[ 7620.517100] __ga10b__ ga10b eng 3:
[ 7620.519726] __ga10b__ id: 1 (tsg), next_id: -1 (channel), ctx status: valid
[ 7620.523223] __ga10b__
[ 7620.530313] __ga10b__ ga10b eng 4:
[ 7620.532938] __ga10b__ id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[ 7620.536610] __ga10b__
[ 7620.544225] __ga10b__ ga10b eng 5:
[ 7620.546673] __ga10b__ id: -1 (channel), next_id: -1 (channel), ctx status: invalid
[ 7620.550337] __ga10b__
[ 7620.557960] __ga10b__
[ 7620.576041] nvgpu: 17000000.ga10b nvgpu_cic_mon_report_err_safety_services:55 [ERR] Error reporting is not supported in this platform
[ 7620.576431] nvgpu: 17000000.ga10b gv11b_mm_mmu_fault_handle_buf_valid_entry:525 [ERR] page fault error: err_type = 0x8, fault_status = 0x200
[ 7620.587377] nvgpu: 17000000.ga10b gv11b_fb_mmu_fault_info_dump:294 [ERR] [MMU FAULT] mmu engine id: 65, ch id: 492, fault addr: 0x205a1c000, fault addr aperture: 0, fault type: invalid pde, access type: virt write,
[ 7620.607060] nvgpu: 17000000.ga10b gv11b_fb_mmu_fault_info_dump:307 [ERR] [MMU FAULT] protected mode: 0, client type: gpc, client id: t1_0, gpc id if client type is gpc: 0,
[ 7646.933258] nvgpu: 17000000.ga10b nvgpu_cic_mon_report_err_safety_services:55 [ERR] Error reporting is not supported in this platform
[ 7646.933626] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:365 [ERR] sm machine check err. gpc_id(0), tpc_id(0), offset(0)
[ 7646.934034] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:390 [ERR] could not pre-process sm error!
[ 7646.934343] nvgpu: 17000000.ga10b nvgpu_cic_mon_report_err_safety_services:55 [ERR] Error reporting is not supported in this platform
[ 7646.934714] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:365 [ERR] sm machine check err. gpc_id(0), tpc_id(0), offset(0)
[ 7646.935098] nvgpu: 17000000.ga10b nvgpu_cic_mon_report_err_safety_services:55 [ERR] Error reporting is not supported in this platform
[ 7646.935432] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:365 [ERR] sm machine check err. gpc_id(0), tpc_id(1), offset(2048)
[ 7646.936986] nvgpu: 17000000.ga10b nvgpu_cic_mon_report_err_safety_services:55 [ERR] Error reporting is not supported in this platform
[ 7646.938785] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:365 [ERR] sm machine check err. gpc_id(0), tpc_id(1), offset(2048)
[ 7646.949388] nvgpu: 17000000.ga10b nvgpu_cic_mon_report_err_safety_services:55 [ERR] Error reporting is not supported in this platform
[ 7646.961665] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:365 [ERR] sm machine check err. gpc_id(0), tpc_id(2), offset(4096)
[ 7646.974045] nvgpu: 17000000.ga10b nvgpu_cic_mon_report_err_safety_services:55 [ERR] Error reporting is not supported in this platform
[ 7646.986347] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:365 [ERR] sm machine check err. gpc_id(0), tpc_id(2), offset(4096)
[ 7646.998736] nvgpu: 17000000.ga10b nvgpu_cic_mon_report_err_safety_services:55 [ERR] Error reporting is not supported in this platform
[ 7647.011019] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:365 [ERR] sm machine check err. gpc_id(0), tpc_id(3), offset(6144)
[ 7647.023393] nvgpu: 17000000.ga10b nvgpu_cic_mon_report_err_safety_services:55 [ERR] Error reporting is not supported in this platform
[ 7647.035693] nvgpu: 17000000.ga10b nvgpu_gr_intr_handle_sm_exception:365 [ERR] sm machine check err. gpc_id(0), tpc_id(3), offset(6144)
[ 7647.048094] nvgpu: 17000000.ga10b gr_intr_handle_exception_interrupts:759 [ERR] set gr exception notifier
[ 7647.058023] nvgpu: 17000000.ga10b nvgpu_set_err_notifier_locked:149 [ERR] error notifier set to 13 for ch 492
[ 7647.068615] __ga10b__ Channel Status - chip ga10b
