Nvargus-daemon: InvalidState Status syncpoint signaled
I have the same problem with below topic on Jetson Orin Nano Dev Kit 4GB. And I used Camera IMX 296 on it.
So the pipeline of gstreamer I use for my application which is: (both camera on the two pipelines have only difference with sensor-id=0-1).
“nvarguscamerasrc sensor-id=0 wbmode=1 aeantibanding=1 ee-mode=1 tnr-mode=1 tnr-strength=-1 saturation=1.0 aelock=0 awblock=0 exposurecompensation=0.0 name=video_src ! nvvidconv ! videoflip name=video_flip method=0 ! nvvidconv ! video/x-raw, format=I420, width=1440, height=1080 ! tee name=t t. ! queue max-size-buffers=2 leaky=2 ! interpipesink name=camera_src1 forward-eos=true forward-events=true async=true sync=false t. ! queue max-size-buffers=30 leaky=2 ! appsink name=raw_app_sink emit-signals=true async=false drop=true max-buffers=30”
When the error occurred on nvargus-daemon service, so following that my application could not get frames from nvarguscamerasrc elements. So please help me resolve this problems.
I also tried to boost all the VI/CSI/ISP clocks. But It still got errors/
How long to hit the problem?
How about run single camera individually?
It ran about 7 hours and then hit the problem (two camera).
I have not tested with single camera. But it’ll take long time to do it.
It’s looks like stability issue. I would suggest to narrow down the root cause.
Like run single camera for each camera and verify two camera by v4l2-ctl by script simultaneously.
v4l2-ctl --stream-mmap -c bypass_mode=0 -d /dev/video0
v4l2-ctl --stream-mmap -c bypass_mode=0 -d /dev/video1
You mean that I should run the two commands simultaneously. And then check it get error or not?. I’ll do it.
But I think it could be issue about nvargus-daemon service. So that nvarguscamerasrc element can not get frames and then lead to break my app. You want to figure out the cause with v4l2-ctl if it also hit the problem, so the problem is on my camera, right?.
I mean run argus with single camera for each or them instead simultaneously.
And Yes v4l2-ctl to verify the sensor driver and HW.
I’ll do it. But if there is not any problems with these commands, what shoud i do?
Because I think it will take long time for checking it.
You also can try simple pipeline to clarify if any element cause the problem.
gst-launch-1.0 nvarguscamerasrc  ! nvvidconv ! fpsdisplaysink video-sink=fakesink --verbose
I ran “gst-launch-1.0 nvarguscamerasrc sensor-id=0-1 ! nvvidconv ! x264enc ! h264parse ! fpsdisplaysink video-sink=fakesink --verbose”. And then It got this error as below.
Please review it and give me your help. Thanks.
ERROR: from element /GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0: UNAVAILABLE
Additional debug info:
Argus Error Status
CONSUMER: ERROR OCCURRED
Execution ended after 0:43:19.217698840
Setting pipeline to NULL …
(Argus) Error Timeout: (propagating from src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 137)
(Argus) Error Timeout: (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch() , line 91)
GST_ARGUS: Cleaning up
Freeing pipeline …
(Argus) Error InvalidState: Argus client is exiting with 4 outstanding client threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 366).
And I had got error from nvargusdaemon-service before I hit the problem.
Module_id 30 Severity 2 : (fusa) Error: InvalidState Status syncpoint signaled but status value not updated in:/capt>
Module_id 30 Severity 2 : (fusa) Error: InvalidState propagating from:/capture/src/fusaViHandler.cpp 759
SCF: Error InvalidState: (propagating from src/services/capture/FusaCaptureViCsiHw.cpp, function waitCsiFrameEnd(),>
SCF: Error InvalidState: (propagating from src/common/Utils.cpp, function workerThread(), line 114)
SCF: Error InvalidState: Worker thread ViCsiHw frameComplete failed (in src/common/Utils.cpp, function workerThread(>
Module_id 30 Severity 2 : (fusa) Error: ResourceAlreadyInUse All captures are already pending, no idle captures avai>
SCF: Error ResourceAlreadyInUse: (propagating from src/services/capture/FusaCaptureViCsiHw.cpp, function startCaptu>
SCF: Error ResourceAlreadyInUse: (propagating from src/services/capture/CaptureRecord.cpp, function doCSItoMemCaptu>
SCF: Error ResourceAlreadyInUse: (propagating from src/services/capture/CaptureRecord.cpp, function issueCapture(),>
SCF: Error ResourceAlreadyInUse: (propagating from src/services/capture/CaptureServiceDevice.cpp, function issueCap>
SCF: Error ResourceAlreadyInUse: (propagating from src/common/Utils.cpp, function workerThread(), line 114)
SCF: Error ResourceAlreadyInUse: Worker thread CaptureScheduler frameStart failed (in src/common/Utils.cpp, function>
Module_id 30 Severity 2 : (fusa) Error: ResourceAlreadyInUse propagating from:/capture/src/fusaViHandler.cpp 475
SCF: Error Timeout: (propagating from src/api/Buffer.cpp, function waitForUnlock(), line 644)
SCF: Error Timeout: (propagating from src/components/CaptureContainerImpl.cpp, function returnBuffer(), line 426)
SCF: Error InvalidState: Capture Scheduler not running (in src/services/capture/CaptureServiceDevice.cpp, function a>
SCF: Error InvalidState: (propagating from src/services/capture/CaptureService.cpp, function addRequest(), line 411)
SCF: Error InvalidState: (propagating from src/components/stages/MemoryToISPCaptureStage.cpp, function doHandleRequ>
SCF: Error InvalidState: (propagating from src/components/stages/OrderedStage.cpp, function doExecute(), line 158)
SCF: Error InvalidState: Sending critical error event (in src/api/Session.cpp, function sendErrorEvent(), line 992)
SCF: Error InvalidState: (propagating from src/components/stages/SensorCaptureStage.cpp, function doHandleRequest()>
SCF: Error Timeout: (propagating from src/components/amr/Snapshot.cpp, function waitForNewerSample(), line 91)
SCF_AutocontrolACSync failed to wait for an earlier frame to complete.
SCF: Error Timeout: (propagating from src/components/ac_stages/ACSynchronizeStage.cpp, function doHandleRequest(), >
SCF: Error Timeout: (propagating from src/components/stages/OrderedStage.cpp, function doExecute(), line 137)
SCF: Error Timeout: Sending critical error event (in src/api/Session.cpp, function sendErrorEvent(), line 992)
SCF: Error Timeout: (propagating from src/services/capture/CaptureServiceEvent.cpp, function wait(), line 59)
Error: Camera HwEvents wait, this may indicate a hardware timeout occured,abort current/incoming cc
SCF: Error InvalidState: 3 buffers still pending during EGLStreamProducer destruction (propagating from src/services>
SCF: Error InvalidState: (propagating from src/services/gl/EGLStreamProducer.cpp, function ~EGLStreamProducer(), li>
SCF: Error InvalidState: 6 buffers still pending during EGLStreamProducer destruction (propagating from src/services>
waitForIdleLocked remaining request 77882
waitForIdleLocked remaining request 77881
waitForIdleLocked remaining request 77880
waitForIdleLocked remaining request 77879
waitForIdleLocked remaining request 77878
waitForIdleLocked remaining request 77877
waitForIdleLocked remaining request 77876
SCF: Error Timeout: waitForIdle() timed out (in src/api/Session.cpp, function waitForIdleLocked(), line 922)
(Argus) Error Timeout: (propagating from src/api/CaptureSessionImpl.cpp, function destroy(), line 216)
waitForIdleLocked remaining request 88200
waitForIdleLocked remaining request 88196
waitForIdleLocked remaining request 88197
waitForIdleLocked remaining request 88195
waitForIdleLocked remaining request 88194
waitForIdleLocked remaining request 88193
@ShaneCCC Can you help me this issue?
Those message tell unable get frame data from sensor.
Please make sure your the sensor output signal and driver stability.
The nvargus-daemon service was not get frame data from sensor. After that I restarted the nvargus-daemon service and then It got frame data from sensor normally.
So I think this issue is not on the sensor output signal.
So it’s stability issue instead of functionality problem?
What’s the fail rate?
Did you boost the clocks to try.
sudo su
echo 1 > /sys/kernel/debug/bpmp/debug/clk/vi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/isp/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/nvcsi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/emc/mrq_rate_locked
cat /sys/kernel/debug/bpmp/debug/clk/vi/max_rate |tee /sys/kernel/debug/bpmp/debug/clk/vi/rate
cat /sys/kernel/debug/bpmp/debug/clk/isp/max_rate | tee  /sys/kernel/debug/bpmp/debug/clk/isp/rate
cat /sys/kernel/debug/bpmp/debug/clk/nvcsi/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/nvcsi/rate
cat /sys/kernel/debug/bpmp/debug/clk/emc/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/emc/rate
I mentioned about boosting clocks
“I also tried to boost all the VI/CSI/ISP clocks. But It still got errors.”
I still suspect it’s sensor stability cause the problem.
How many time to reproduce the problem?
Did you verify the sensor HW driver by v4l2-ctl?
@ShaneCCC
Running with
"v4l2-ctl --stream-mmap -c bypass_mode=0 -d /dev/video0 "
"v4l2-ctl --stream-mmap -c bypass_mode=0 -d /dev/video1 "
I have run these command for a day. It seems not to occur the issue like nvargus.
The time to reproduce the problem is about 7-8 hours. (nvargus)
What’s the verison?
cat /etc/nv_tegra_release
@ShaneCCC Here is the version I’m using.
R35 (release), REVISION: 3.1, GCID: 32827747, BOARD: t186ref, EABI: aarch64, DATE: Sun Mar 19 15:19:21 UTC 2023
Did you try simple pipeline without “x264enc ! h264parse” to narrow down it?
