I’m currently facing a memory leak on Jetson Orin when using the Argus API to extract image data.
I’ve based my implementation in the code found in /usr/src/jetson_multimedia_api/ :
argus/apps/camera/modules/Dispatcher
samples/13_argus_multi_camera/main.cpp
The code successfully retrieves and displays NV12 data.
However, the memory consumption steadily increases over time (initially confirmed with htop over night, with a >10Gb increase in memory consumption).
Using Valgrind, I confirmed the memory leak is present and coming from:
- The creation of the OutputStream (Producer side);
- The creation of the NvBuffer (Consumer side).
Producer side ( threadInitialize() )
bool UpdatedProducer::initEGLOutputStreamSettings()
// Sanity check
if (!m_iSensorMode)
m_lastError = "Producer -> ISensorMode not initialized";
return false;
if (!m_iEglOutputStreamSettings)
m_lastError = "Producer -> IEGLOutputStreamSettings not initialized";
return false;
m_iEglOutputStreamSettings->setPixelFormat(Argus::PIXEL_FMT_YCbCr_420_888);
m_iEglOutputStreamSettings->setMode(Argus::EGL_STREAM_MODE_MAILBOX);
m_iEglOutputStreamSettings->setResolution(m_iSensorMode->getResolution());
m_iEglOutputStreamSettings->setMetadataEnable(true);
return true;
bool UpdatedProducer::initOutputStreamWithEGLOutputStreamSettings()
// Sanity check
if (!m_iCaptureSession)
m_lastError = "Producer -> ICaptureSession not initialized";
return false;
if (!m_outputStreamSettings)
m_lastError = "Producer -> OutputStreamSettings not initialized";
return false;
// Create the output stream
m_outputStream = Argus::UniqueObj<Argus::OutputStream>(m_iCaptureSession->createOutputStream(m_outputStreamSettings.get()));
if (!m_outputStream)
m_lastError = "Producer -> Failed to create OutputStream";
return false;
// Extract the EGL output stream interface
m_iEGLOutputStream = Argus::interface_cast<Argus::IEGLOutputStream>(m_outputStream);
if (!m_iEGLOutputStream)
m_lastError = "Producer -> Failed to create EGLOutputStream interface";
return false;
return true;
Consumer side ( threadExecute() )
bool UpdatedConsumer::getNvBuffer()
// Sanity check
std::cerr << "Consumer -> EGL output stream interface not initialized" << std::endl;
return false;
if (!m_iImageNativeBuffer)
std::cerr << "Consumer -> Image Native Buffer interface not initialized" << std::endl;
return false;
Argus::Status status;
// Get NvBuffer from native buffer
m_dmabuf_fd = m_iImageNativeBuffer->createNvBuffer(m_iEGLOutputStream->getResolution(), NVBUF_COLOR_FORMAT_YUV420, NVBUF_LAYOUT_PITCH, EGLStream::NV::ROTATION_0, &status);
if (Argus::STATUS_OK != status)
std::cerr << "Consumer -> Failed to create NvBuffer" << std::endl;
return false;
return true;
bool UpdatedConsumer::copyBuffer()
// Sanity check
if (m_dmabuf_fd == -1)
std::cerr << "Consumer -> NvBuffer not initialized" << std::endl;
return false;
// Create and extract NvBuffer parameters
NvBufferParams params;
NvBufferGetParams(m_dmabuf_fd, ¶ms);
#ifndef NDEBUG
std::cout << "Consumer -> NvBuffer Params:\n";
std::cout << "Consumer -> dmabuf_fd : " << params.dmabuf_fd << " (Holds the DMABUF FD of the hardware buffer)" << std::endl;
std::cout << "Consumer -> memsize : " << params.memsize << " (size of the memory)" << std::endl;
std::cout << "Consumer -> nv_buffer_size : " << params.nv_buffer_size << " (size of hardware buffer)" << std::endl;
std::cout << "Consumer -> pixel_format : " << params.pixel_format << " (0 = NvBufferColorFormat_YUV420 -> BT.601 colorspace - YUV420 multi-planar)" << std::endl;
std::cout << "Consumer -> num_planes : " << params.num_planes << " (number of planes of hardware buffer)" << std::endl;
for(unsigned int i=0; i < params.num_planes; i++)
std::cout << "Consumer -> Plane " << i << " : " << std::endl;
std::cout << "Consumer -> width : " << params.width[i] << " (width of each plane of hardware buffer)" << std::endl;
std::cout << "Consumer -> height : " << params.height[i] << " (height of each plane of hardware buffer)" << std::endl;
std::cout << "Consumer -> pitch : " << params.pitch[i] << " (pitch of each plane of hardware buffer)" << std::endl;
std::cout << "Consumer -> offset : " << params.offset[i] << " (memory offset values of each video plane of hardware buffer)" << std::endl;
std::cout << "Consumer -> psize : " << params.psize[i] << " (size of each video plane of hardware buffer)" << std::endl;
std::cout << "Consumer -> layout : " << params.layout[i] << " (layout type of each plane of hardware buffer)" << std::endl;
#endif
// Map pointers to the NvBuffer
unsigned char* pointer_y = NULL;
NvBufferMemMap(m_dmabuf_fd, 0, NvBufferMem_Read, (void**)&pointer_y);
unsigned char* pointer_u = NULL;
NvBufferMemMap(m_dmabuf_fd, 1, NvBufferMem_Read, (void**)&pointer_u);
unsigned char* pointer_v = NULL;
NvBufferMemMap(m_dmabuf_fd, 2, NvBufferMem_Read, (void**)&pointer_v);
char* buffer;
buffer = new char[params.width[0] * params.height[0] * 3 / 2];
// std::cout << "----> copyBuffer() -> ##### created -> " << static_cast<void*>(buffer) << std::endl;
// Fill buffer with NV12 format data
// | Y |
// | U / V |
int count = params.width[0] * params.height[0];
for(unsigned int i=0; i<params.height[0]; i++) // for each row
memcpy(buffer + (i*params.width[0]),(char*)(pointer_y + (i*params.pitch[0])), params.width[0]); // copy width portion of pitch (width + padding = total row size)
// UV Interleaved Portion (U0 V0 U1 V1 ...)
if(i < params.height[0]/2)
for (unsigned int j=0; j < params.width[1]; j++)
buffer[count++] = (char)(pointer_u[i * params.pitch[1] + j]);
buffer[count++] = (char)(pointer_v[i * params.pitch[1] + j]);
// Fill the timestamp with the capture informations
int64_t ts = m_timestamp * 1e-6;
// Send the Data and Timestamp
sigCopyBuffer(buffer, ts);
// Destroy the created NvBuffer
NvBufferMemUnMap(m_dmabuf_fd, 0, (void**)&pointer_y);
NvBufferMemUnMap(m_dmabuf_fd, 1, (void**)&pointer_u);
NvBufferMemUnMap(m_dmabuf_fd, 2, (void**)&pointer_v);
NvBufferDestroy(m_dmabuf_fd);
return true;
All Argus::UniqueObj are being destructed with .reset(), upon shutdown.
My Argus version is the following → “Argus Version: 0.98.3 (multi-process)”.
Thank you in advance.
