hello:
i I modified the sample-oneShot,when i didn’t add the modified program to my company’s program,the modifyed sample(oneShot) can work,but when i add to my company’s program ,it did’t work.
here is the modified sample(oneShot)
head file
#pragma once
#include <unistd.h>
#include <stdio.h>
#include <stdlib.h>
#include <Argus/Argus.h>
#include <EGLStream/EGLStream.h>
#include <EGLStream/NV/ImageNativeBuffer.h>
#include <sys/mman.h>
#include <sys/time.h>
#include <iostream>
#define PRODUCER_PRINT(...) printf("PRODUCER: " __VA_ARGS__)
#define EXIT_IF_NULL(val,msg) \
{if (!val) {printf("%s\n",msg); return EXIT_FAILURE;}}
#define EXIT_IF_NOT_OK(val,msg) \
{if (val!=Argus::STATUS_OK) {printf("%s\n",msg); return EXIT_FAILURE;}}
const uint64_t FIVE_SECONDS_IN_NANOSECONDS = 5000000000;
using namespace Argus;
using namespace EGLStream;
class ArGusCamera
private:
bool m_isInit;
ICameraProvider *iCameraProvider;
Argus::ICameraProperties *iCameraProperties;
Argus::ISensorMode *iSensorMode;
Argus::ICaptureSession *iCaptureSession;
Argus::ICaptureSession *iSession;
Argus::IEGLOutputStreamSettings *iEGLStreamSettings;
IEGLOutputStream *iStream;
EGLStream::IFrameConsumer *iFrameConsumer;
Argus::IRequest *iRequest;
OutputStream *m_stream;
Argus::ISourceSettings *iSourceSettings;
UniqueObj<FrameConsumer> consumer;
UniqueObj<CameraProvider>cameraProvider;
UniqueObj<CaptureSession> captureSession;
Argus::UniqueObj<Argus::OutputStreamSettings> streamSettings;
Argus::UniqueObj<Argus::OutputStream> stream;
Argus::UniqueObj<Argus::Request> request;
private:
std::vector<Argus::SensorMode*> sensorModes;
std::vector<Argus::CameraDevice*> cameraDevices;
public:
ArGusCamera();
~ArGusCamera();
bool initCamera(int);
bool AcquireData(uint8_t *,int);
cpp file:
#include "ArgusCamera.hpp"
ArGusCamera::ArGusCamera():m_isInit(false)
iCameraProvider = NULL;
iCameraProperties = NULL;
iSensorMode = NULL;
iCaptureSession = NULL;
iSession = NULL;
iEGLStreamSettings = NULL;
iStream = NULL;
iFrameConsumer = NULL;
iRequest = NULL;
m_stream = NULL;
iSourceSettings = NULL;
ArGusCamera::~ArGusCamera
bool ArGusCamera::initCamera(int device)
if(m_isInit == false)
Argus::Status CameraProviderstatus;
cameraProvider = UniqueObj<CameraProvider>(CameraProvider::create(&CameraProviderstatus));
printf("CameraProviderstatus = %d\n",CameraProviderstatus);
iCameraProvider = Argus::interface_cast<Argus::ICameraProvider>(cameraProvider);
iCameraProvider->getCameraDevices(&cameraDevices);
if (cameraDevices.size() == 0)
printf("No cameras available\n");
iCameraProperties = Argus::interface_cast<Argus::ICameraProperties>(cameraDevices[0]);
if (!iCameraProperties)
printf("Failed to get ICameraProperties interface\n");
iCameraProperties->getAllSensorModes(&sensorModes);
if (sensorModes.size() == 0)
printf("Failed to get sensor modes\n");
PRODUCER_PRINT("Available Sensor modes :\n");
for (uint32_t i = 0; i < sensorModes.size(); i++) {
iSensorMode = Argus::interface_cast<Argus::ISensorMode>(sensorModes[i]);
Argus::Size2D<uint32_t> resolution = iSensorMode->getResolution();
PRODUCER_PRINT("[%u] W=%u H=%u\n", i, resolution.width(), resolution.height());
iSensorMode = Argus::interface_cast<Argus::ISensorMode>(sensorModes[0]);
Argus::Status status;
captureSession = UniqueObj<Argus::CaptureSession> (iCameraProvider->createCaptureSession(cameraDevices[0], &status));
EXIT_IF_NOT_OK(status, "Failed to create capture session");
iCaptureSession = Argus::interface_cast<Argus::ICaptureSession>(captureSession);
if (!iCaptureSession)
printf("\nFailed to get ICaptureSession interface \n");
iSession = Argus::interface_cast<Argus::ICaptureSession>(captureSession);
EXIT_IF_NULL(iSession, "Cannot get Capture Session Interface");
streamSettings = UniqueObj<Argus::OutputStreamSettings>(iSession->createOutputStreamSettings(Argus::STREAM_TYPE_EGL));
iEGLStreamSettings =Argus::interface_cast<Argus::IEGLOutputStreamSettings>(streamSettings);
EXIT_IF_NULL(iEGLStreamSettings, "Cannot get IEGLOutputStreamSettings Interface\n");
iEGLStreamSettings->setPixelFormat(Argus::PIXEL_FMT_YCbCr_420_888);
iEGLStreamSettings->setResolution(iSensorMode->getResolution());
iEGLStreamSettings->setMetadataEnable(true);
stream = Argus::UniqueObj<Argus::OutputStream>(iSession->createOutputStream(streamSettings.get()));
m_stream = stream.get();
EXIT_IF_NULL(stream, "Failed to create EGLOutputStream");
iStream = interface_cast<IEGLOutputStream>(stream.get());
consumer = UniqueObj<FrameConsumer>(FrameConsumer::create(stream.get()));
iFrameConsumer = Argus::interface_cast<EGLStream::IFrameConsumer>(consumer);
EXIT_IF_NULL(iFrameConsumer, "Failed to initialize Consumer");
request = Argus::UniqueObj<Argus::Request> (iSession->createRequest(Argus::CAPTURE_INTENT_STILL_CAPTURE));
iRequest = Argus::interface_cast<Argus::IRequest>(request);
EXIT_IF_NULL(iRequest, "Failed to get capture request interface");
Argus::Status status1 = iRequest->enableOutputStream(m_stream);
EXIT_IF_NOT_OK(status1, "Failed to enable stream in capture request");
iSourceSettings = Argus::interface_cast<Argus::ISourceSettings>(request);
EXIT_IF_NULL(iSourceSettings, "Failed to get source settings request interface");
iSourceSettings->setSensorMode(sensorModes[0]);
m_isInit = true;
printf("init sucess\n");
return true;
printf("has inited\n");
return true;
bool ArGusCamera::AcquireData(uint8_t *DstData,int device)
printf("start acquire data\n");
uint8_t *rawdata = (uint8_t*)malloc(3840*2160*3/2);
printf("Starting repeat capture requests.\n");
if(!iCaptureSession->isRepeating())
if (iCaptureSession->repeat(request.get()) != STATUS_OK)
printf("Failed to start repeat capture request");
uint32_t requestId = iSession->capture(request.get());
EXIT_IF_NULL(requestId, "Failed to submit capture request");
Argus::Status m_status;
Argus::UniqueObj<EGLStream::Frame> frame(iFrameConsumer->acquireFrame(FIVE_SECONDS_IN_NANOSECONDS,&m_status));
printf("acquireFrame status=%d\n",m_status);
// if (iStream->waitUntilConnected() != STATUS_OK)
// printf("Stream failed to connect.");
EGLStream::IFrame *iFrame = Argus::interface_cast<EGLStream::IFrame>(frame);
EXIT_IF_NULL(iFrame, "Failed to get IFrame interface\n");
printf("Acquired Frame: %llu, time %llu\n",
static_cast<unsigned long long>(iFrame->getNumber()),
static_cast<unsigned long long>(iFrame->getTime()));
// Print out some capture metadata from the frame.
IArgusCaptureMetadata *iArgusCaptureMetadata = interface_cast<IArgusCaptureMetadata>(frame);
if (!iArgusCaptureMetadata)
printf("Failed to get IArgusCaptureMetadata interface.\n");
CaptureMetadata *metadata = iArgusCaptureMetadata->getMetadata();
ICaptureMetadata *iMetadata = interface_cast<ICaptureMetadata>(metadata);
if (!iMetadata)
printf("Failed to get ICaptureMetadata interface.\n");
printf("\tSensor Timestamp: %llu, LUX: %f\n",static_cast<unsigned long long>(iMetadata->getSensorTimestamp()),iMetadata->getSceneLux());
// Print out image details, and map the buffers to read out some data.
Image *image = iFrame->getImage();
EGLStream::IImage2D *iImageYUV = Argus::interface_cast<EGLStream::IImage2D>(image);
EXIT_IF_NULL(iImageYUV, "Failed to get ImageJPEG Interface");
int v_dmabuf = -1;
NV::IImageNativeBuffer *iNativeBuffer =interface_cast<NV::IImageNativeBuffer>(iFrame->getImage());
if (!iNativeBuffer)
printf("IImageNativeBuffer not supported by Image.");
printf("stream size=========================%d\n",iStream->getResolution());
v_dmabuf = iNativeBuffer->createNvBuffer(iStream->getResolution(),NvBufferColorFormat_NV12,NvBufferLayout_Pitch);
NvBufferParams params;
int ret = NvBufferGetParams(v_dmabuf, ¶ms);
size_t total_size = 0;
for(int i = 0 ; i<params.num_planes ; i++)
int32_t width = params.width[i];
int32_t height = params.height[i];
int32_t pitch = params.pitch[i];
printf("width:%d--height:%d--pitch:%d\n", width, height, pitch);
size_t fsize = pitch*height;
uint8_t* data_mem = (uint8_t*)mmap(0, fsize, PROT_READ | PROT_WRITE, MAP_SHARED, v_dmabuf, params.offset[i]);
uint8_t* vptr = rawdata;
memcpy(vptr,data_mem,fsize);
vptr += fsize;
total_size += fsize;
printf("fsize= %d paramsoffset = %d\n", fsize, params.offset[i]);
printf("total size = %d\n",total_size);
memcpy(DstData,rawdata,total_size);
return true;
then i add it to company’s program,it didn’t work,the error is:
[2022-11-25 14:44:30.480][libcamera][ERROR]../src/camera_imx585yuv.cpp(862) initCamera cameraDevice[0] info=imx585_bottomleft_liimx585
PRODUCER: Available Sensor modes :
PRODUCER: [0] W=3840 H=2160
PRODUCER: [1] W=1928 H=1090
[2022-11-25 14:44:32.154][libcamera][ERROR]../src/camera_imx585yuv.cpp(923) initCamera init sucess
[2022-11-25 14:44:32.154][libcamera][ERROR]../src/camera_imx585yuv.cpp(933) AcquireData AcquireData--------------------------
[2022-11-25 14:44:32.154][libcamera][ERROR]../src/camera_imx585yuv.cpp(936) AcquireData FFFFFFFFFFFFFFFFFFFFFFFFFFFF--------------------------
[2022-11-25 14:44:32.621][libcamera][ERROR]../src/camera_imx585yuv.cpp(971) AcquireData 44444444444444444444444444444--------------------------
(Argus) Error NotSupported: (propagating from src/eglstream/ImageImpl.cpp, function copyToNvBuffer(), line 470)
(Argus) Error InvalidState: Failed to copy to NvBuffer (in src/eglstream/ImageImpl.cpp, function createNvBuffer(), line 374)
[2022-11-25 14:44:32.624][libcamera][ERROR]../src/camera_imx585yuv.cpp(990) AcquireData iNativeBuffer->createNvBuffer() failed,status = 2,size=3840
int v_dmabuf = -1;
if (!iNativeBuffer)
LIBCAMERA_ERROR("IImageNativeBuffer not supported by Image.");
v_dmabuf = iNativeBuffer->createNvBuffer(iStream->getResolution(),NvBufferColorFormat_NV12,NvBufferLayout_Pitch,EGLStream::NV::ROTATION_0,&status);
if(v_dmabuf == -1)
LIBCAMERA_ERROR("iNativeBuffer->createNvBuffer() failed,status = %d,size=%d\n",status,iStream->getResolution());
return false;
createNvBuffer() always throw error (Argus) Error NotSupported: (propagating from src/eglstream/ImageImpl.cpp, function copyToNvBuffer(), line 470) (Argus) Error InvalidState: Failed to copy to NvBuffer (in src/eglstream/ImageImpl.cpp, function createNvBuffer(), line 374) and the Argus::status =2;I don’t no why i cant create nvbuffer?
Hope to get your answer as soon as possible!
