Hello everyone,
I am trying to convert a camera frame (NvBufSurface) to OpenCV Mat. I have read many similar questions in this forum, but I sadly have not found a way to fix my issue. I have an IMX477 camera connected to an Jetson Orin NX and want to read the camera frames to use them in OpenCV without wasting much performance and adding latency (which I read about gstreamer).
I found out that the buffer I get from the camera is not contiguous, I have 1 filled buffer of type NvBufSurfaceMemType::NVBUF_MEM_SURFACE_ARRAY and NvBufSurfaceColorFormat::NVBUF_COLOR_FORMAT_NV12
I started with example 10_argus_camera_recording
, which I tried to modify to get my OpenCV Mat out:
#include "Error.h"
#include "Thread.h"
#include "nvmmapi/NvNativeBuffer.h"
#include <Argus/Argus.h>
#include <NvVideoEncoder.h>
#include "NvBufSurface.h"
#include <unistd.h>
#include <stdio.h>
#include <stdlib.h>
#include <iostream>
#include <fstream>
#include <thread>
#include <opencv2/opencv.hpp>
#include <chrono>
#include <iostream>
#include <thread>
using namespace Argus;
/* Constant configuration */
static const int MAX_ENCODER_FRAMES = 5;
static const int DEFAULT_FPS = 30;
static const int Y_INDEX = 0;
static const int START_POS = 32;
static const int FONT_SIZE = 64;
static const int SHIFT_BITS = 3;
static const int array_n[8][8] = {
{ 1, 1, 0, 0, 0, 0, 1, 1 },
{ 1, 1, 1, 0, 0, 0, 1, 1 },
{ 1, 1, 1, 1, 0, 0, 1, 1 },
{ 1, 1, 1, 1, 1, 0, 1, 1 },
{ 1, 1, 0, 1, 1, 1, 1, 1 },
{ 1, 1, 0, 0, 1, 1, 1, 1 },
{ 1, 1, 0, 0, 0, 1, 1, 1 },
/* This value is tricky.
Too small value will impact the FPS */
static const int NUM_BUFFERS = 10;
/* Configurations which can be overrided by cmdline */
static int CAPTURE_TIME = 5; // In seconds.
static uint32_t CAMERA_INDEX = 0;
static Size2D<uint32_t> STREAM_SIZE (1920, 1080);
static std::string OUTPUT_FILENAME ("output.h264");
static uint32_t ENCODER_PIXFMT = V4L2_PIX_FMT_H264;
static bool VERBOSE_ENABLE = true;
static bool DO_CPU_PROCESS = false;
/* Debug print macros */
#define PRODUCER_PRINT(...) printf("PRODUCER: " __VA_ARGS__)
#define CONSUMER_PRINT(...) printf("CONSUMER: " __VA_ARGS__)
#define CHECK_ERROR(expr) \
do { \
if ((expr) < 0) { \
abort(); \
ORIGINATE_ERROR(#expr " failed"); \
} while (0);
namespace ArgusSamples {
Helper class to map NvNativeBuffer to Argus::Buffer and vice versa.
A reference to DmaBuffer will be saved as client data in each Argus::Buffer.
Also DmaBuffer will keep a reference to corresponding Argus::Buffer.
This class also extends NvBuffer to act as a share buffer between Argus and V4L2 encoder.
class DmaBuffer : public NvNativeBuffer, public NvBuffer
public:
/* Always use this static method to create DmaBuffer */
static DmaBuffer* create(const Argus::Size2D<uint32_t>& size,
NvBufSurfaceColorFormat colorFormat,
NvBufSurfaceLayout layout = NVBUF_LAYOUT_PITCH)
DmaBuffer* buffer = new DmaBuffer(size);
if (!buffer)
return NULL;
NvBufSurf::NvCommonAllocateParams cParams;
cParams.memtag = NvBufSurfaceTag_CAMERA;
cParams.width = size.width();
cParams.height = size.height();
cParams.colorFormat = colorFormat;
cParams.layout = layout;
cParams.memType = NVBUF_MEM_SURFACE_ARRAY;
if (NvBufSurf::NvAllocate(&cParams, 1, &buffer->m_fd))
delete buffer;
return NULL;
/* save the DMABUF fd in NvBuffer structure */
buffer->planes[0].fd = buffer->m_fd;
/* byteused must be non-zero for a valid buffer */
buffer->planes[0].bytesused = 1;
return buffer;
/* Help function to convert Argus Buffer to DmaBuffer */
static DmaBuffer* fromArgusBuffer(Buffer *buffer)
IBuffer* iBuffer = interface_cast<IBuffer>(buffer);
const DmaBuffer *dmabuf = static_cast<const DmaBuffer*>(iBuffer->getClientData());
return const_cast<DmaBuffer*>(dmabuf);
/* Return DMA buffer handle */
int getFd() const { return m_fd; }
/* Get and set reference to Argus buffer */
void setArgusBuffer(Buffer *buffer) { m_buffer = buffer; }
Buffer *getArgusBuffer() const { return m_buffer; }
private:
DmaBuffer(const Argus::Size2D<uint32_t>& size)
: NvNativeBuffer(size),
NvBuffer(0, 0),
m_buffer(NULL)
Buffer *m_buffer; /* Reference to Argus::Buffer */
void nv12ToMat(NvBufSurface *nvBuf, cv::Mat &outMat) {
// Ensure the buffer is mapped
if (NvBufSurfaceMap(nvBuf, 0, 0, NVBUF_MAP_READ) != 0) {
std::cerr << "Failed to map NvBufSurface." << std::endl;
return;
// Sync for CPU read
if (NvBufSurfaceSyncForCpu(nvBuf, 0, 0) != 0) {
std::cerr << "Failed to sync NvBufSurface for CPU." << std::endl;
return;
// Pointer to Y data
unsigned char *y_ptr = (unsigned char *)nvBuf->surfaceList[0].mappedAddr.addr[0];
int y_pitch = nvBuf->surfaceList[0].pitch;
// Pointer to UV data
unsigned char *uv_ptr = (unsigned char *)nvBuf->surfaceList[0].mappedAddr.addr[1];
int uv_pitch = nvBuf->surfaceList[0].pitch;
int width = nvBuf->surfaceList[0].width;
int height = nvBuf->surfaceList[0].height;
// Create a Mat containing the Y plane
cv::Mat y_mat(height, width, CV_8UC1, y_ptr, y_pitch);
// Create a Mat containing the UV plane
cv::Mat uv_mat(height / 2, width / 2, CV_8UC2, uv_ptr, uv_pitch);
// Output Mat
outMat.create(height, width, CV_8UC3);
// Convert NV12 to BGR
cv::cvtColorTwoPlane(y_mat, uv_mat, outMat, cv::COLOR_YUV2BGR_NV12);
// Unmap the buffer
NvBufSurfaceUnMap(nvBuf, 0, 0);
cv::Mat NvBufSurfaceToMat(NvBufSurface* surface) {
// Map the buffer so that it can be accessed by CPU
if (NvBufSurfaceMap (surface, 0, 0, NVBUF_MAP_READ) != 0){
std::cout << "NvBufSurfaceMap did not work" << std::endl;
// Cache the mapped data for CPU access
NvBufSurfaceSyncForCpu (surface, 0, 0);
// Use openCV to remove padding and convert RGBA to BGR. Can be skipped if
// algorithm can handle padded RGBA data.
return cv::Mat (1920, 1080,
CV_8UC4, surface->surfaceList[0].mappedAddr.addr[0],
surface->surfaceList[0].pitch);
* Argus Producer thread:
* Opens the Argus camera driver, creates an BufferOutputStream to output
* frames, then performs repeating capture requests for CAPTURE_TIME
* seconds before closing the producer and Argus driver.
static bool execute(){
NvBufSurface *surf[NUM_BUFFERS] = {0};
/* Create the CameraProvider object and get the core interface */
UniqueObj<CameraProvider> cameraProvider = UniqueObj<CameraProvider>(CameraProvider::create());
ICameraProvider *iCameraProvider = interface_cast<ICameraProvider>(cameraProvider);
if (!iCameraProvider)
ORIGINATE_ERROR("Failed to create CameraProvider");
/* Get the camera devices */
std::vector<CameraDevice*> cameraDevices;
iCameraProvider->getCameraDevices(&cameraDevices);
if (cameraDevices.size() == 0)
ORIGINATE_ERROR("No cameras available");
if (CAMERA_INDEX >= cameraDevices.size())
PRODUCER_PRINT("CAMERA_INDEX out of range. Fall back to 0\n");
CAMERA_INDEX = 0;
/* Create the capture session using the first device and get the core interface */
UniqueObj<CaptureSession> captureSession(
iCameraProvider->createCaptureSession(cameraDevices[CAMERA_INDEX]));
ICaptureSession *iCaptureSession = interface_cast<ICaptureSession>(captureSession);
if (!iCaptureSession)
ORIGINATE_ERROR("Failed to get ICaptureSession interface");
/* Create the OutputStream */
PRODUCER_PRINT("Creating output stream\n");
UniqueObj<OutputStreamSettings> streamSettings(
iCaptureSession->createOutputStreamSettings(STREAM_TYPE_BUFFER));
IBufferOutputStreamSettings *iStreamSettings =
interface_cast<IBufferOutputStreamSettings>(streamSettings);
if (!iStreamSettings)
ORIGINATE_ERROR("Failed to get IBufferOutputStreamSettings interface");
/* Configure the OutputStream to use the EGLImage BufferType */
iStreamSettings->setBufferType(BUFFER_TYPE_EGL_IMAGE);
UniqueObj<OutputStream> outputStream(iCaptureSession->createOutputStream(streamSettings.get()));
IBufferOutputStream *iBufferOutputStream = interface_cast<IBufferOutputStream>(outputStream);
/* Allocate native buffers */
DmaBuffer* nativeBuffers[NUM_BUFFERS];
for (uint32_t i = 0; i < NUM_BUFFERS; i++)
nativeBuffers[i] = DmaBuffer::create(STREAM_SIZE, NVBUF_COLOR_FORMAT_NV12,
DO_CPU_PROCESS ? NVBUF_LAYOUT_PITCH : NVBUF_LAYOUT_BLOCK_LINEAR);
if (!nativeBuffers[i])
ORIGINATE_ERROR("Failed to allocate NativeBuffer");
/* Create EGLImages from the native buffers */
EGLImageKHR eglImages[NUM_BUFFERS];
int ret = 0;
ret = NvBufSurfaceFromFd(nativeBuffers[i]->getFd(), (void**)(&surf[i]));
if (ret)
ORIGINATE_ERROR("%s: NvBufSurfaceFromFd failed\n", __func__);
ret = NvBufSurfaceMapEglImage (surf[i], 0);
if (ret)
ORIGINATE_ERROR("%s: NvBufSurfaceMapEglImage failed\n", __func__);
eglImages[i] = surf[i]->surfaceList[0].mappedAddr.eglImage;
if (eglImages[i] == EGL_NO_IMAGE_KHR)
ORIGINATE_ERROR("Failed to create EGLImage");
/* Create the BufferSettings object to configure Buffer creation */
UniqueObj<BufferSettings> bufferSettings(iBufferOutputStream->createBufferSettings());
IEGLImageBufferSettings *iBufferSettings =
interface_cast<IEGLImageBufferSettings>(bufferSettings);
if (!iBufferSettings)
ORIGINATE_ERROR("Failed to create BufferSettings");
/* Create the Buffers for each EGLImage (and release to
stream for initial capture use) */
UniqueObj<Buffer> buffers[NUM_BUFFERS];
iBufferSettings->setEGLImage(eglImages[i]);
buffers[i].reset(iBufferOutputStream->createBuffer(bufferSettings.get()));
IBuffer *iBuffer = interface_cast<IBuffer>(buffers[i]);
/* Reference Argus::Buffer and DmaBuffer each other */
iBuffer->setClientData(nativeBuffers[i]);
nativeBuffers[i]->setArgusBuffer(buffers[i].get());
if (!interface_cast<IEGLImageBuffer>(buffers[i]))
ORIGINATE_ERROR("Failed to create Buffer");
if (iBufferOutputStream->releaseBuffer(buffers[i].get()) != STATUS_OK)
ORIGINATE_ERROR("Failed to release Buffer for capture use");
/* Create capture request and enable output stream */
UniqueObj<Request> request(iCaptureSession->createRequest());
IRequest *iRequest = interface_cast<IRequest>(request);
if (!iRequest)
ORIGINATE_ERROR("Failed to create Request");
iRequest->enableOutputStream(outputStream.get());
ISourceSettings *iSourceSettings = interface_cast<ISourceSettings>(iRequest->getSourceSettings());
if (!iSourceSettings)
ORIGINATE_ERROR("Failed to get ISourceSettings interface");
iSourceSettings->setFrameDurationRange(Range<uint64_t>(1e9/DEFAULT_FPS));
/* Submit capture requests */
PRODUCER_PRINT("Starting repeat capture requests.\n");
if (iCaptureSession->repeat(request.get()) != STATUS_OK)
ORIGINATE_ERROR("Failed to start repeat capture request");
PRODUCER_PRINT("Created repeat capture requests.\n");
/* Capture and process frames */
while (true) { // TODO Change
Argus::Status status = STATUS_OK;
PRODUCER_PRINT("START of loop\n");
Buffer* buffer = iBufferOutputStream->acquireBuffer(TIMEOUT_INFINITE, &status);
if (status == STATUS_END_OF_STREAM) {
break;
PRODUCER_PRINT("Acquired buffer\n");
// Get the DmaBuffer and raw frame data
DmaBuffer *dmabuf = DmaBuffer::fromArgusBuffer(buffer);
int dmabuf_fd = dmabuf->getFd();
NvBufSurface *surf;
if (NvBufSurfaceFromFd(dmabuf_fd, (void**)(&surf))) {
ORIGINATE_ERROR("Failed to get NvBufSurface from dmabuf_fd");
break;
// NvBufSurfaceSyncForCpu(surf, 0, 0);
// int width = surf->surfaceList[0].width;
// int height = surf->surfaceList[0].height;
// int pitch = surf->surfaceList[0].pitch; // Get the pitch
// unsigned char* y_plane = (unsigned char*)surf->surfaceList[0].mappedAddr.addr;
// unsigned char* uv_plane = (unsigned char*)surf->surfaceList[1].mappedAddr.addr;
// std::cout << "Width: " << width << ", Height: " << height << std::endl;
// std::cout << "Y Plane Address: " << (void*)y_plane << std::endl;
// // Correct memory allocation for YUV420 (NV12)
// cv::Mat yuv_mat(100*height, 100*width, CV_8UC1);
// // Copy Y plane data with size check
// // Calculate Y plane size with pitch
// size_t y_plane_size = pitch * height;
// std::cout << "Copying Y plane data: " << y_plane_size << " bytes" << std::endl;
// memcpy(yuv_mat.data, y_plane, width * height);
// PRODUCER_PRINT("Memcopy\n");
// // Copy UV plane data (consider subsampling)
// for (int i = 0; i < height / 2; ++i) {
// memcpy(yuv_mat.data + width * height + i * width,
// uv_plane + i * width,
// width);
// cv::Mat bgr_mat;
// cv::cvtColor(yuv_mat, bgr_mat, cv::COLOR_YUV2BGR_NV12);
// cv::Mat bgr_mat;
// nv12ToMat(surf, bgr_mat);
cv::Mat bgr_mat = NvBufSurfaceToMat(surf);
cv::imshow("Frame", bgr_mat);
cv::waitKey(1);
iBufferOutputStream->releaseBuffer(dmabuf->getArgusBuffer());
/* Stop the repeating request and wait for idle */
iCaptureSession->stopRepeat();
iBufferOutputStream->endOfStream();
iCaptureSession->waitForIdle();
/* Destroy the output stream to end the consumer thread */
outputStream.reset();
/* Destroy the EGLImages */
NvBufSurfaceUnMapEglImage (surf[i], 0);
/* Destroy the native buffers */
delete nativeBuffers[i];
PRODUCER_PRINT("Done -- exiting.\n");
return true;
}; // namespace ArgusSamples
int main(int argc, char *argv[])
if (!ArgusSamples::execute())
return EXIT_FAILURE;
return EXIT_SUCCESS;
The issue with NvBufSurfaceToMat
is:
terminate called after throwing an instance of ‘cv::Exception’
what(): OpenCV(4.5.4) /home/ubuntu/build_opencv/opencv/modules/core/src/matrix.cpp:438: error: (-215:Assertion failed) _step >= minstep in function ‘Mat’
And the issue with nv12ToMat
is the following because there is no second buffer from which I could read:
what(): OpenCV(4.5.4) /home/ubuntu/build_opencv/opencv/modules/core/src/matrix.cpp:428: error: (-215:Assertion failed) total() == 0 || data != NULL in function ‘Mat’
I also tried countless other methods and am struggling a lot as I always think it could not be that hard to get a cv::Mat from libargus and all the solutions I read on here didn’t help me.
Thank you very much for your help.
