I’m encountering an issue when using libargus to grab multiple cameras and encode the grabbed frames.
After running for approximately an hour with 4 cameras I receive this warning:
Argus: 0x5556b1eb00 ClientObject::m_interfaceProviders grew unreasonably long (8628 items).
This warning then keeps being repeated every couple of seconds with an ever increasing amount of items mentioned.
I am assuming this indicates some sort of issue in the implementation of the library itself or the usage thereof, but I can not find what to do to prevent this from happening.
I’ve modified on of the sample applications in the jetson framework libary - 10_camera_recording specifically - to replicate this behaviour. The main differences between this code and the original sample are:
- this code opens multiple capture sessions instead of one
- the metadata is read for each frame and logged at intervals
- the sample keeps running until killed
After running this for about an hour with 4 cameras I start getting the messages.
The platform I’m running this on is a Jetson AGX Xavier with jetpack 4.6 installed. It does not seem to be different for different camera vendors indicating it would be an issue in the SDK.
I can not yet use a newer version of jetpack since the drivers for our cameras are not yet released.
The code to reproduce this is below.
* Copyright (c) 2016-2018, NVIDIA CORPORATION. All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* * Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* * Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* * Neither the name of NVIDIA CORPORATION nor the names of its
* contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS ``AS IS'' AND ANY
* EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
* PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY
* OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include "Error.h"
#include "Thread.h"
#include "nvmmapi/NvNativeBuffer.h"
#include <chrono>
#include <Argus/Argus.h>
#include <NvVideoEncoder.h>
#include <NvApplicationProfiler.h>
#include <unistd.h>
#include <stdio.h>
#include <stdlib.h>
#include <iostream>
#include <fstream>
#include <chrono>
#include <future>
using namespace Argus;
/* Constant configuration */
static const int MAX_ENCODER_FRAMES = 5;
static const int DEFAULT_FPS = 60;
static const int Y_INDEX = 0;
static const int START_POS = 32;
static const int FONT_SIZE = 64;
static const int SHIFT_BITS = 3;
static const int array_n[8][8] = {
{ 1, 1, 0, 0, 0, 0, 1, 1 },
{ 1, 1, 1, 0, 0, 0, 1, 1 },
{ 1, 1, 1, 1, 0, 0, 1, 1 },
{ 1, 1, 1, 1, 1, 0, 1, 1 },
{ 1, 1, 0, 1, 1, 1, 1, 1 },
{ 1, 1, 0, 0, 1, 1, 1, 1 },
{ 1, 1, 0, 0, 0, 1, 1, 1 },
/* This value is tricky.
Too small value will impact the FPS */
static const int NUM_BUFFERS = 10;
/* Configurations which can be overrided by cmdline */
static int CAPTURE_TIME = 5; // In seconds.
static uint32_t CAMERA_INDEX = 0;
//static Size2D<uint32_t> STREAM_SIZE (640, 480);
static Size2D<uint32_t> STREAM_SIZE (3840,2160);
static std::string OUTPUT_FILENAME ("output.h264");
static uint32_t ENCODER_PIXFMT = V4L2_PIX_FMT_H265;
static bool DO_STAT = false;
static bool VERBOSE_ENABLE = false;
static bool DO_CPU_PROCESS = false;
/* Debug print macros */
#define PRODUCER_PRINT(...) printf("PRODUCER: " __VA_ARGS__)
#define CONSUMER_PRINT(...) printf("CONSUMER: " __VA_ARGS__)
#define CHECK_ERROR(expr) \
do { \
if ((expr) < 0) { \
abort(); \
ORIGINATE_ERROR(#expr " failed"); \
} while (0);
static EGLDisplay eglDisplay = EGL_NO_DISPLAY;
namespace ArgusSamples
Helper class to map NvNativeBuffer to Argus::Buffer and vice versa.
A reference to DmaBuffer will be saved as client data in each Argus::Buffer.
Also DmaBuffer will keep a reference to corresponding Argus::Buffer.
This class also extends NvBuffer to act as a share buffer between Argus and V4L2 encoder.
class DmaBuffer : public NvNativeBuffer, public NvBuffer
public:
/* Always use this static method to create DmaBuffer */
static DmaBuffer* create(const Argus::Size2D<uint32_t>& size,
NvBufferColorFormat colorFormat,
NvBufferLayout layout = NvBufferLayout_Pitch)
DmaBuffer* buffer = new DmaBuffer(size);
if (!buffer)
return NULL;
if (NvBufferCreate(&buffer->m_fd, size.width(), size.height(), layout, colorFormat))
delete buffer;
return NULL;
/* save the DMABUF fd in NvBuffer structure */
buffer->planes[0].fd = buffer->m_fd;
/* byteused must be non-zero for a valid buffer */
buffer->planes[0].bytesused = 1;
return buffer;
/* Help function to convert Argus Buffer to DmaBuffer */
static DmaBuffer* fromArgusBuffer(Buffer *buffer)
IBuffer* iBuffer = interface_cast<IBuffer>(buffer);
const DmaBuffer *dmabuf = static_cast<const DmaBuffer*>(iBuffer->getClientData());
return const_cast<DmaBuffer*>(dmabuf);
/* Return DMA buffer handle */
int getFd() const { return m_fd; }
/* Get and set reference to Argus buffer */
void setArgusBuffer(Buffer *buffer) { m_buffer = buffer; }
Buffer *getArgusBuffer() const { return m_buffer; }
private:
DmaBuffer(const Argus::Size2D<uint32_t>& size)
: NvNativeBuffer(size),
NvBuffer(0, 0),
m_buffer(NULL)
Buffer *m_buffer; /* Reference to Argus::Buffer */
* Consumer thread:
* Acquire frames from BufferOutputStream and extract the DMABUF fd from it.
* Provide DMABUF to V4L2 for video encoding. The encoder will save the encoded
* stream to disk.
class ConsumerThread : public Thread
public:
explicit ConsumerThread(OutputStream* stream);
~ConsumerThread();
bool isInError()
return m_gotError;
private:
/** @name Thread methods */
virtual bool threadInitialize();
virtual bool threadExecute();
virtual bool threadShutdown();
bool createVideoEncoder();
void abort();
static bool encoderCapturePlaneDqCallback(
struct v4l2_buffer *v4l2_buf,
NvBuffer *buffer,
NvBuffer *shared_buffer,
void *arg);
OutputStream* m_stream;
NvVideoEncoder *m_VideoEncoder;
uint64_t m_frameCount;
uint64_t m_lastFrameCount;
std::chrono::time_point<std::chrono::high_resolution_clock> m_last_update;
std::ofstream *m_outputFile;
bool m_gotError;
ConsumerThread::ConsumerThread(OutputStream* stream) :
m_stream(stream),
m_VideoEncoder(NULL),
m_frameCount(0),
m_lastFrameCount(0),
m_outputFile(NULL),
m_gotError(false)
ConsumerThread::~ConsumerThread()
if (m_VideoEncoder)
delete m_VideoEncoder;
if (m_outputFile)
delete m_outputFile;
bool ConsumerThread::threadInitialize()
/* Create Video Encoder */
if (!createVideoEncoder())
ORIGINATE_ERROR("Failed to create video m_VideoEncoderoder");
/* Create output file */
m_outputFile = new std::ofstream(OUTPUT_FILENAME.c_str());
if (!m_outputFile)
ORIGINATE_ERROR("Failed to open output file.");
/* Stream on */
int e = m_VideoEncoder->output_plane.setStreamStatus(true);
if (e < 0)
ORIGINATE_ERROR("Failed to stream on output plane");
e = m_VideoEncoder->capture_plane.setStreamStatus(true);
if (e < 0)
ORIGINATE_ERROR("Failed to stream on capture plane");
/* Set video encoder callback */
m_VideoEncoder->capture_plane.setDQThreadCallback(encoderCapturePlaneDqCallback);
/* startDQThread starts a thread internally which calls the
encoderCapturePlaneDqCallback whenever a buffer is dequeued
on the plane */
m_VideoEncoder->capture_plane.startDQThread(this);
/* Enqueue all the empty capture plane buffers */
for (uint32_t i = 0; i < m_VideoEncoder->capture_plane.getNumBuffers(); i++)
struct v4l2_buffer v4l2_buf;
struct v4l2_plane planes[MAX_PLANES];
memset(&v4l2_buf, 0, sizeof(v4l2_buf));
memset(planes, 0, MAX_PLANES * sizeof(struct v4l2_plane));
v4l2_buf.index = i;
v4l2_buf.m.planes = planes;
CHECK_ERROR(m_VideoEncoder->capture_plane.qBuffer(v4l2_buf, NULL));
return true;
void read_buffer_metadata( Argus::Buffer *buffer )
using namespace std::chrono;
if( const auto *iBuffer = Argus::interface_cast< IBuffer >( buffer ) )
if( auto *metadata = iBuffer->getMetadata() )
if( const auto *iMetadata = Argus::interface_cast< const ICaptureMetadata >( metadata ) )
const float analog_gain = iMetadata->getSensorAnalogGain();
const float digital_gain = iMetadata->getIspDigitalGain();
const nanoseconds timestamp( iMetadata->getSensorTimestamp() );
const nanoseconds exposure( iMetadata->getSensorExposureTime() );
const int sensitivity = iMetadata->getSensorSensitivity();
const auto now = std::chrono::steady_clock::now();
static auto last_print = now;
if( now - last_print >= seconds(10) )
printf(
R"(----
timestamp: %0.09lf
gain: [ analog: %0.03f, digital: %0.03f ]
exposure: %lins,
sensitivity: %i
duration_cast< duration< double > >( timestamp ).count(),
analog_gain, digital_gain,
exposure.count(),
sensitivity
last_print = now;
else
printf( "%s: %i\n", __FUNCTION__, __LINE__ );
else
else
bool ConsumerThread::threadExecute()
IBufferOutputStream* stream = interface_cast<IBufferOutputStream>(m_stream);
if (!stream)
ORIGINATE_ERROR("Failed to get IBufferOutputStream interface");
for (int bufferIndex = 0; bufferIndex < MAX_ENCODER_FRAMES; bufferIndex++)
v4l2_buf.index = bufferIndex;
Buffer* buffer = stream->acquireBuffer();
/* Convert Argus::Buffer to DmaBuffer and queue into v4l2 encoder */
DmaBuffer *dmabuf = DmaBuffer::fromArgusBuffer(buffer);
CHECK_ERROR(m_VideoEncoder->output_plane.qBuffer(v4l2_buf, dmabuf));
/* Keep acquire frames and queue into encoder */
while (!m_gotError)
NvBuffer *share_buffer;
/* Dequeue from encoder first */
CHECK_ERROR(m_VideoEncoder->output_plane.dqBuffer(v4l2_buf, NULL,
&share_buffer, 10/*retry*/));
/* Release the frame */
DmaBuffer *dmabuf = static_cast<DmaBuffer*>(share_buffer);
stream->releaseBuffer(dmabuf->getArgusBuffer());
assert(dmabuf->getFd() == v4l2_buf.m.planes[0].m.fd);
if (VERBOSE_ENABLE)
CONSUMER_PRINT("Released frame. %d\n", dmabuf->getFd());
/* Acquire a Buffer from a completed capture request */
Argus::Status status = STATUS_OK;
Buffer* buffer = stream->acquireBuffer(TIMEOUT_INFINITE, &status);
if (status == STATUS_END_OF_STREAM)
/* Timeout or error happen, exit */
break;
/* DIVERGENCE FROM SAMPLE */
read_buffer_metadata( buffer );
/* END OF DIVERGENCE */
/* Convert Argus::Buffer to DmaBuffer and get FD */
int dmabuf_fd = dmabuf->getFd();
if (VERBOSE_ENABLE)
CONSUMER_PRINT("Acquired Frame. %d\n", dmabuf_fd);
if (DO_CPU_PROCESS) {
NvBufferParams par;
NvBufferGetParams (dmabuf_fd, &par);
void *ptr_y;
uint8_t *ptr_cur;
int i, j, a, b;
NvBufferMemMap(dmabuf_fd, Y_INDEX, NvBufferMem_Write, &ptr_y);
NvBufferMemSyncForCpu(dmabuf_fd, Y_INDEX, &ptr_y);
ptr_cur = (uint8_t *)ptr_y + par.pitch[Y_INDEX]*START_POS + START_POS;
/* overwrite some pixels to put an 'N' on each Y plane
scan array_n to decide which pixel should be overwritten */
for (i=0; i < FONT_SIZE; i++) {
for (j=0; j < FONT_SIZE; j++) {
a = i>>SHIFT_BITS;
b = j>>SHIFT_BITS;
if (array_n[a][b])
(*ptr_cur) = 0xff; /* white color */
ptr_cur++;
ptr_cur = (uint8_t *)ptr_y + par.pitch[Y_INDEX]*(START_POS + i) + START_POS;
NvBufferMemSyncForDevice (dmabuf_fd, Y_INDEX, &ptr_y);
NvBufferMemUnMap(dmabuf_fd, Y_INDEX, &ptr_y);
/* Push the frame into V4L2. */
m_frameCount++;
auto now = std::chrono::high_resolution_clock::now();
auto duration = now - m_last_update;
auto dt = std::chrono::duration_cast<std::chrono::duration<float>>(duration).count();
if (dt > 5) {
CONSUMER_PRINT("fps: %f\n", (m_frameCount - m_lastFrameCount) / dt);
m_lastFrameCount = m_frameCount;
m_last_update = now;
/* Print profile result before EOS to make FPS more accurate
Otherwise, the total duration will include timeout period
which makes the FPS a bit lower */
if (DO_STAT)
m_VideoEncoder->printProfilingStats(std::cout);
/* Send EOS */
v4l2_buf.m.planes[0].m.fd = -1;
v4l2_buf.m.planes[0].bytesused = 0;
CHECK_ERROR(m_VideoEncoder->output_plane.qBuffer(v4l2_buf, NULL));
/* Wait till capture plane DQ Thread finishes
i.e. all the capture plane buffers are dequeued */
m_VideoEncoder->capture_plane.waitForDQThread(2000);
CONSUMER_PRINT("Done.\n");
requestShutdown();
return true;
bool ConsumerThread::threadShutdown()
return true;
bool ConsumerThread::createVideoEncoder()
int ret = 0;
m_VideoEncoder = NvVideoEncoder::createVideoEncoder("enc0");
if (!m_VideoEncoder)
ORIGINATE_ERROR("Could not create m_VideoEncoderoder");
if (DO_STAT)
m_VideoEncoder->enableProfiling();
ret = m_VideoEncoder->setCapturePlaneFormat(ENCODER_PIXFMT, STREAM_SIZE.width(),
STREAM_SIZE.height(), 2 * 1024 * 1024);
if (ret < 0)
ORIGINATE_ERROR("Could not set capture plane format");
ret = m_VideoEncoder->setOutputPlaneFormat(V4L2_PIX_FMT_YUV420M, STREAM_SIZE.width(),
STREAM_SIZE.height());
if (ret < 0)
ORIGINATE_ERROR("Could not set output plane format");
ret = m_VideoEncoder->setBitrate(4 * 1024 * 1024);
if (ret < 0)
ORIGINATE_ERROR("Could not set bitrate");
if (ENCODER_PIXFMT == V4L2_PIX_FMT_H264)
ret = m_VideoEncoder->setProfile(V4L2_MPEG_VIDEO_H264_PROFILE_HIGH);
else
ret = m_VideoEncoder->setProfile(V4L2_MPEG_VIDEO_H265_PROFILE_MAIN);
if (ret < 0)
ORIGINATE_ERROR("Could not set m_VideoEncoderoder profile");
ret = m_VideoEncoder->setLevel(V4L2_MPEG_VIDEO_H264_LEVEL_5_0);
if (ret < 0)
ORIGINATE_ERROR("Could not set m_VideoEncoderoder level");
ret = m_VideoEncoder->setRateControlMode(V4L2_MPEG_VIDEO_BITRATE_MODE_CBR);
if (ret < 0)
ORIGINATE_ERROR("Could not set rate control mode");
ret = m_VideoEncoder->setIFrameInterval(30);
if (ret < 0)
ORIGINATE_ERROR("Could not set I-frame interval");
ret = m_VideoEncoder->setFrameRate(60, 1);
if (ret < 0)
ORIGINATE_ERROR("Could not set m_VideoEncoderoder framerate");
ret = m_VideoEncoder->setHWPresetType(V4L2_ENC_HW_PRESET_ULTRAFAST);
if (ret < 0)
ORIGINATE_ERROR("Could not set m_VideoEncoderoder HW Preset");
/* Query, Export and Map the output plane buffers so that we can read
raw data into the buffers */
ret = m_VideoEncoder->output_plane.setupPlane(V4L2_MEMORY_DMABUF, 10, true, false);
if (ret < 0)
ORIGINATE_ERROR("Could not setup output plane");
/* Query, Export and Map the output plane buffers so that we can write
m_VideoEncoderoded data from the buffers */
ret = m_VideoEncoder->capture_plane.setupPlane(V4L2_MEMORY_MMAP, 6, true, false);
if (ret < 0)
ORIGINATE_ERROR("Could not setup capture plane");
printf("create video encoder return true\n");
return true;
void ConsumerThread::abort()
m_VideoEncoder->abort();
m_gotError = true;
bool ConsumerThread::encoderCapturePlaneDqCallback(struct v4l2_buffer *v4l2_buf,
NvBuffer * buffer,
NvBuffer * shared_buffer,
void *arg)
ConsumerThread *thiz = (ConsumerThread*)arg;
if (!v4l2_buf)
thiz->abort();
ORIGINATE_ERROR("Failed to dequeue buffer from encoder capture plane");
//thiz->m_outputFile->write((char *) buffer->planes[0].data,
// buffer->planes[0].bytesused);
if (thiz->m_VideoEncoder->capture_plane.qBuffer(*v4l2_buf, NULL) < 0)
thiz->abort();
ORIGINATE_ERROR("Failed to enqueue buffer to encoder capture plane");
return false;
/* GOT EOS from m_VideoEncoderoder. Stop dqthread */
if (buffer->planes[0].bytesused == 0)
CONSUMER_PRINT("Got EOS, exiting...\n");
return false;
return true;
* Argus Producer thread:
* Opens the Argus camera driver, creates an BufferOutputStream to output
* frames, then performs repeating capture requests for CAPTURE_TIME
* seconds before closing the producer and Argus driver.
bool run_camera( ICameraProvider *iCameraProvider, CameraDevice *device )
/* Create the capture session using the first device and get the core interface */
UniqueObj<CaptureSession> captureSession(
iCameraProvider->createCaptureSession( device ) );
ICaptureSession *iCaptureSession = interface_cast<ICaptureSession>(captureSession);
if (!iCaptureSession)
ORIGINATE_ERROR("Failed to get ICaptureSession interface");
/* Create the OutputStream */
PRODUCER_PRINT("Creating output stream\n");
UniqueObj<OutputStreamSettings> streamSettings(
iCaptureSession->createOutputStreamSettings(STREAM_TYPE_BUFFER));
IBufferOutputStreamSettings *iStreamSettings =
interface_cast<IBufferOutputStreamSettings>(streamSettings);
if (!iStreamSettings)
ORIGINATE_ERROR("Failed to get IBufferOutputStreamSettings interface");
/* Configure the OutputStream to use the EGLImage BufferType */
iStreamSettings->setBufferType(BUFFER_TYPE_EGL_IMAGE);
iStreamSettings->setMetadataEnable( true );
UniqueObj<OutputStream> outputStream(iCaptureSession->createOutputStream(streamSettings.get()));
IBufferOutputStream *iBufferOutputStream = interface_cast<IBufferOutputStream>(outputStream);
/* Allocate native buffers */
DmaBuffer* nativeBuffers[NUM_BUFFERS];
for (uint32_t i = 0; i < NUM_BUFFERS; i++)
nativeBuffers[i] = DmaBuffer::create(STREAM_SIZE, NvBufferColorFormat_NV12,
DO_CPU_PROCESS ? NvBufferLayout_Pitch : NvBufferLayout_BlockLinear);
if (!nativeBuffers[i])
ORIGINATE_ERROR("Failed to allocate NativeBuffer");
/* Create EGLImages from the native buffers */
EGLImageKHR eglImages[NUM_BUFFERS];
eglImages[i] = nativeBuffers[i]->createEGLImage(eglDisplay);
if (eglImages[i] == EGL_NO_IMAGE_KHR)
ORIGINATE_ERROR("Failed to create EGLImage");
/* Create the BufferSettings object to configure Buffer creation */
UniqueObj<BufferSettings> bufferSettings(iBufferOutputStream->createBufferSettings());
IEGLImageBufferSettings *iBufferSettings =
interface_cast<IEGLImageBufferSettings>(bufferSettings);
if (!iBufferSettings)
ORIGINATE_ERROR("Failed to create BufferSettings");
/* Create the Buffers for each EGLImage (and release to
stream for initial capture use) */
UniqueObj<Buffer> buffers[NUM_BUFFERS];
iBufferSettings->setEGLImage(eglImages[i]);
iBufferSettings->setEGLDisplay(eglDisplay);
buffers[i].reset(iBufferOutputStream->createBuffer(bufferSettings.get()));
IBuffer *iBuffer = interface_cast<IBuffer>(buffers[i]);
/* Reference Argus::Buffer and DmaBuffer each other */
iBuffer->setClientData(nativeBuffers[i]);
nativeBuffers[i]->setArgusBuffer(buffers[i].get());
if (!interface_cast<IEGLImageBuffer>(buffers[i]))
ORIGINATE_ERROR("Failed to create Buffer");
if (iBufferOutputStream->releaseBuffer(buffers[i].get()) != STATUS_OK)
ORIGINATE_ERROR("Failed to release Buffer for capture use");
/* Launch the FrameConsumer thread to consume frames from the OutputStream */
PRODUCER_PRINT("Launching consumer thread\n");
ConsumerThread frameConsumerThread(outputStream.get());
PROPAGATE_ERROR(frameConsumerThread.initialize());
/* Wait until the consumer is connected to the stream */
PROPAGATE_ERROR(frameConsumerThread.waitRunning());
/* Create capture request and enable output stream */
UniqueObj<Request> request(iCaptureSession->createRequest());
IRequest *iRequest = interface_cast<IRequest>(request);
if (!iRequest)
ORIGINATE_ERROR("Failed to create Request");
iRequest->enableOutputStream(outputStream.get());
ISourceSettings *iSourceSettings = interface_cast<ISourceSettings>(iRequest->getSourceSettings());
if (!iSourceSettings)
ORIGINATE_ERROR("Failed to get ISourceSettings interface");
iSourceSettings->setFrameDurationRange(Range<uint64_t>(1e9/DEFAULT_FPS));
/* Submit capture requests */
PRODUCER_PRINT("Starting repeat capture requests.\n");
if (iCaptureSession->repeat(request.get()) != STATUS_OK)
ORIGINATE_ERROR("Failed to start repeat capture request");
/* Wait for CAPTURE_TIME seconds */
while( true ) { sleep(1); }
/* Stop the repeating request and wait for idle */
iCaptureSession->stopRepeat();
iBufferOutputStream->endOfStream();
iCaptureSession->waitForIdle();
/* Wait for the consumer thread to complete */
PROPAGATE_ERROR(frameConsumerThread.shutdown());
/* Destroy the output stream to end the consumer thread */
outputStream.reset();
/* Destroy the EGLImages */
NvDestroyEGLImage(NULL, eglImages[i]);
/* Destroy the native buffers */
delete nativeBuffers[i];
PRODUCER_PRINT("Done -- exiting.\n");
return true;
static bool execute()
/* Create the CameraProvider object and get the core interface */
UniqueObj<CameraProvider> cameraProvider = UniqueObj<CameraProvider>(CameraProvider::create());
ICameraProvider *iCameraProvider = interface_cast<ICameraProvider>(cameraProvider);
if (!iCameraProvider)
ORIGINATE_ERROR("Failed to create CameraProvider");
/* Get the camera devices */
std::vector<CameraDevice*> cameraDevices;
iCameraProvider->getCameraDevices(&cameraDevices);
if (cameraDevices.size() == 0)
ORIGINATE_ERROR("No cameras available");
std::vector< std::future< bool > > jobs;
for( size_t index = 0; index < cameraDevices.size(); ++index )
jobs.push_back( std::async( std::launch::async, run_camera, iCameraProvider, cameraDevices[ index ] ) );
return true;
}; /* namespace ArgusSamples */
static void printHelp()
printf("Usage: camera_recording [OPTIONS]\n"
"Options:\n"
" -r Set output resolution WxH [Default 640x480]\n"
" -f Set output filename [Default output.h264]\n"
" -t Set encoder type H264 or H265 [Default H264]\n"
" -d Set capture duration [Default 5 seconds]\n"
" -i Set camera index [Default 0]\n"
" -s Enable profiling\n"
" -v Enable verbose message\n"
" -c Enable demonstration of CPU processing\n"
" -h Print this help\n");
static bool parseCmdline(int argc, char **argv)
int c, w, h;
bool haveFilename = false;
while ((c = getopt(argc, argv, "r:f:t:d:i:s::v::c::h")) != -1)
switch (c)
case 'r':
if (sscanf(optarg, "%dx%d", &w, &h) != 2)
return false;
STREAM_SIZE.width() = w;
STREAM_SIZE.height() = h;
break;
case 'f':
OUTPUT_FILENAME = optarg;
haveFilename = true;
break;
case 't':
if (strcmp(optarg, "H264") == 0)
ENCODER_PIXFMT = V4L2_PIX_FMT_H264;
else if (strcmp(optarg, "H265") == 0)
if (!haveFilename)
OUTPUT_FILENAME = "output.h265";
else
return false;
break;
case 'd':
CAPTURE_TIME = atoi(optarg);
break;
case 'i':
CAMERA_INDEX = atoi(optarg);
break;
case 's':
DO_STAT = true;
break;
case 'v':
VERBOSE_ENABLE = true;
break;
case 'c':
DO_CPU_PROCESS = true;
break;
default:
return false;
return true;
int main(int argc, char *argv[])
NvApplicationProfiler &profiler = NvApplicationProfiler::getProfilerInstance();
/* Get default EGL display */
eglDisplay = eglGetDisplay(EGL_DEFAULT_DISPLAY);
if (eglDisplay == EGL_NO_DISPLAY)
printf("Cannot get EGL display.\n");
return EXIT_FAILURE;
if (!ArgusSamples::execute())
/* Terminate EGL display */
eglTerminate(eglDisplay);
profiler.stop();
profiler.printProfilerData(std::cout);
return EXIT_SUCCESS;
