Multithreaded gstreamer pipeline crashing for onboard cameras TX1
I have 6 raspberry pi camera modules interfaced via mipi. I am able to capture all the cameras simultaneously by running gstreamer pipelines like the below
gst-launch-1.0 nvcamerasrc sensor-id=4 fpsRange=“30 30” ! “video/x-raw(memory:NVMM), width=(int)820, height=(int)616,format=(string)I420, framerate=(fraction)30/1” ! nvvidconv ! nveglglessink -v
However when i run the same pipeline as a code it throws the following error
Error received from element video-source: GStreamer error: state change failed and some element failed to post a proper error message with the reason for the failure.
Debugging information: gstbasesrc.c(3354): gst_base_src_start (): /GstPipeline:pipeline/GstNvCameraSrc:video-source:
Failed to start
NvCameraSrc: Trying To Set Default Camera Resolution. Selected 820x616 FrameRate = 30.000000 …
Socket read error. Camera Daemon stopped functioning…
gst_nvcamera_open() failed ret=0
Failed to start
for some cameras randomly . Below is my complete code
#include <gst/gst.h>
#include <gst/app/gstappsink.h>
#include <bits/stdc++.h>
#include <unistd.h>
#include <sys/time.h>
#include <opencv2/opencv.hpp>
#include <pthread.h>
using namespace cv;
using namespace std;
typedef struct CameraPipeline
	GstElement *pipeline;
	GstElement *camera_source;
	GstElement *input_caps_filter;
	GstElement *output_caps_filter;
	GstElement *conversion_element;
	GstElement *sink;
	GstCaps *input_caps;
	GstCaps *output_caps;
	GstBus *bus;
	GstMessage *msg;
	int camera_index;
	int width;
	int height;
	int fps;
	unsigned char *frame;
}CameraPipeline;
static void new_sample(GstElement *appsink, void *data)
CameraPipeline *ptr = (CameraPipeline *)data;
GstBuffer *buffer;
GstMapInfo info;
GstSample *sample;
/* Retrieve the buffer */
g_signal_emit_by_name (appsink, “pull-sample”, &sample);
if (sample)
/* The only thing we do in this example is print a * to indicate a received buffer */
	g_print("*");
	buffer = gst_sample_get_buffer(sample);
	gboolean success = gst_buffer_map(buffer, &info, (GstMapFlags)GST_MAP_READ);
    if (!success)
        printf("GStreamer: unable to map buffer");
        return ;
	void * decodedPtr = info.data;
	ptr->frame = (unsigned char *)decodedPtr;
	gst_buffer_unmap(buffer, &info);
	gst_buffer_unref (buffer);
	gst_sample_unref (sample);
void CameraPipelineInit(CameraPipeline *p, int cameraIndex, int dstWidth, int dstHeight, int dstFPS)
p->camera_index = cameraIndex;
p->width = dstWidth;
p->height = dstHeight;
p->fps = dstFPS;
p->frame = (unsigned char *)malloc(dstWidth * dstHeight * 1.5);
int cnt = 0;
void * CameraPipelineRun(void *p)
gst_init(NULL, NULL);
CameraPipeline *ptr = (CameraPipeline *)p;
ptr->pipeline = gst_pipeline_new("pipeline");
ptr->camera_source = gst_element_factory_make("nvcamerasrc", "video-source");
ptr->conversion_element = gst_element_factory_make("nvvidconv", "video-convert");
ptr->input_caps_filter = gst_element_factory_make("capsfilter", "input-caps-filter");
ptr->output_caps_filter = gst_element_factory_make("capsfilter", "output-caps-filter");
ptr->sink = gst_element_factory_make("nveglglessink", NULL);
ptr->input_caps =  gst_caps_from_string("video/x-raw(memory:NVMM), width=820, height=616, format=I420, framerate=(fraction)30/1");
ptr->output_caps = gst_caps_new_simple("video/x-raw",
							 "width", G_TYPE_INT, ptr->width,
							 "height", G_TYPE_INT, ptr->height,
							 "framerate", GST_TYPE_FRACTION, ptr->fps, 1,
							 "format", G_TYPE_STRING, "I420",
							 NULL);
g_object_set(G_OBJECT(ptr->camera_source), "sensor-id", ptr->camera_index, NULL);
g_object_set(G_OBJECT(ptr->input_caps_filter), "caps", ptr->input_caps, NULL);
g_object_set(G_OBJECT(ptr->output_caps_filter), "caps", ptr->output_caps, NULL);
gst_bin_add_many(GST_BIN(ptr->pipeline), ptr->camera_source, ptr->input_caps_filter, ptr->conversion_element, ptr->sink, NULL);
gst_element_link_many(ptr->camera_source, ptr->input_caps_filter, ptr->conversion_element,  ptr->sink, NULL);
//gst_app_sink_set_max_buffers (GST_APP_SINK(ptr->sink), 1);
//gst_app_sink_set_drop (GST_APP_SINK(ptr->sink), true);
//g_object_set(G_OBJECT(ptr->sink),"emit-signals",TRUE, NULL);
//g_object_set(G_OBJECT(ptr->sink),"enable-last-sample", FALSE, NULL);
//g_signal_connect (ptr->sink, "new-sample", G_CALLBACK (new_sample), (void *)ptr);
// gst_pipeline_set_clock((GstPipeline *)ptr->pipeline, NULL);
gst_element_set_state(ptr->pipeline, GST_STATE_PLAYING);
    ptr->bus = gst_element_get_bus (ptr->pipeline);
 ptr->msg = gst_bus_timed_pop_filtered (ptr->bus, GST_CLOCK_TIME_NONE, GST_MESSAGE_ERROR);
/* Parse message */
if (ptr->msg != NULL) {
GError *err;
gchar *debug_info;
switch (GST_MESSAGE_TYPE (ptr->msg)) {
  case GST_MESSAGE_ERROR:
    gst_message_parse_error (ptr->msg, &err, &debug_info);
    g_printerr ("Error received from element %s: %s\n", GST_OBJECT_NAME (ptr->msg->src), err->message);
    g_printerr ("Debugging information: %s\n", debug_info ? debug_info : "none");
    g_clear_error (&err);
    g_free (debug_info);
    break;
  case GST_MESSAGE_EOS:
    g_print ("End-Of-Stream reached.\n");
    break;
  default:
    /* We should not reach here because we only asked for ERRORs and EOS */
    g_printerr ("Unexpected message received.\n");
    break;
gst_message_unref (ptr->msg);
gst_object_unref (ptr->bus);
gst_element_set_state (ptr->pipeline, GST_STATE_NULL);
gst_object_unref (ptr->pipeline);
int main()
int num_cameras = 6;
int width = 1920;
int height = 1080;
int fps = 30;
unsigned char **img;
img = (unsigned char **)malloc(num_cameras * sizeof(unsigned char *));
CameraPipeline **cameras;
pthread_t camera_pipeline_thread[num_cameras];
cameras = (CameraPipeline **)malloc(num_cameras * sizeof(CameraPipeline *));
for(int i = 0 ; i < num_cameras ; i++)
	cameras[i] = (CameraPipeline *)malloc(sizeof(CameraPipeline));
	CameraPipelineInit(cameras[i], i, width, height, fps);
	img[i] = (unsigned char *)malloc(width * height * 1.5);
pthread_attr_t attr_;
cpu_set_t cpus_;
pthread_attr_init(&attr_);
CPU_ZERO(&cpus_);
CPU_SET(1, &cpus_);
pthread_attr_setaffinity_np(&attr_, sizeof(cpu_set_t), &cpus_);
pthread_create(&camera_pipeline_thread[0], NULL, CameraPipelineRun, (void *)cameras[0]);
CPU_ZERO(&cpus_);
CPU_SET(2, &cpus_);
pthread_create(&camera_pipeline_thread[1], NULL, CameraPipelineRun, (void *)cameras[1]);
CPU_ZERO(&cpus_);
CPU_SET(3, &cpus_);
pthread_create(&camera_pipeline_thread[2], NULL, CameraPipelineRun, (void *)cameras[2]);
CPU_ZERO(&cpus_);
CPU_SET(1, &cpus_);
pthread_create(&camera_pipeline_thread[3], NULL, CameraPipelineRun, (void *)cameras[3]);
CPU_ZERO(&cpus_);
CPU_SET(1, &cpus_);
pthread_create(&camera_pipeline_thread[4], NULL, CameraPipelineRun, (void *)cameras[4]);
    CPU_ZERO(&cpus_);
CPU_SET(1, &cpus_);
pthread_create(&camera_pipeline_thread[5], NULL, CameraPipelineRun, (void *)cameras[5]);
FILE *f;
int cnt = 0 ;
while(1)
	continue;
	/*cnt++;
			ostringstream str;
			str << i + 1;
			img[i] = cameras[i]->frame;
			Mat image(height * 1.5, width, CV_8UC1, img[i]);
			Mat imagedst(height, width, CV_8UC3);
			cvtColor(image, imagedst, CV_YUV2BGR_I420);
			imshow(str.str().c_str(), imagedst);
			waitKey(1);
return 0;
Any help would be appreciated.
Can you share the command to build the source?
Some OpenCV APIs are called in your code. Have you tried the case without OpenCV?
Hi , in the above code opencv part is commented out.
As i said gstreamer launched in 6 terminals separately works fine. However this code sometimes crashes with Socket read error. Camera Daemon stopped functioning… but works sometimes when i add a sleep function before and after every thread launch.
gst_init() should be called only once but in your code it seems to be called six times.
And please also try to launch 6 pipelines in one thread. In your implementation there are 6 threads. It may have race condition.
Hi, Yes regarding gst_init() i have written a new code with it pulled out of the thread handler. still it crashes sometimes.
Yeah i will try launching 6 pipelines in a thread.
Also i would like to know if there are any samples available that i can use to capture six cameras simultaneously.
Please refer to attachment.
$ g++ -Wall -std=c++11  multi.cpp -o multi $(pkg-config --cflags --libs gstreamer-1.0)
And also replace nvcamera-daemon of r28.1
https://devtalk.nvidia.com/default/topic/1023757/jetson-tx2/piecewiselinear-level-3-translation-fault-with-nvcamera-socket-read-error-and-daemon-stopped-functio-/post/5208774/#5208774
multi.cpp (1.81 KB)
Hi , thanks a lot for the help.
I have switched to argus api for multicamera capture which is eventually consumed by cuda buffers for processing.
Currently i have modified the denoise application which works fine but shows a very high increase in latency(observed visually) (of about 0.5 s ) when i increase the number of capture sessions. I would like to know if the current implementation as below is optimal.
Thank You. Below is the code.
 * Copyright (c) 2016, NVIDIA CORPORATION. All rights reserved.
 * Redistribution and use in source and binary forms, with or without
 * modification, are permitted provided that the following conditions
 * are met:
 *  * Redistributions of source code must retain the above copyright
 *    notice, this list of conditions and the following disclaimer.
 *  * Redistributions in binary form must reproduce the above copyright
 *    notice, this list of conditions and the following disclaimer in the
 *    documentation and/or other materials provided with the distribution.
 *  * Neither the name of NVIDIA CORPORATION nor the names of its
 *    contributors may be used to endorse or promote products derived
 *    from this software without specific prior written permission.
 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS ``AS IS'' AND ANY
 * EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
 * PURPOSE ARE DISCLAIMED.  IN NO EVENT SHALL THE COPYRIGHT OWNER OR
 * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
 * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
 * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
 * PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY
 * OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
 * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
 * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include "Error.h"
#include "EGLGlobal.h"
#include "GLContext.h"
#include "Window.h"
#include "Thread.h"
#include "PreviewConsumer.h"
#include <Argus/Argus.h>
#include <EGLStream/EGLStream.h>
#include <unistd.h>
#include <stdlib.h>
using namespace Argus;
 * This sample outputs capture requests to two streams, one of which has denoise algorithms
 * enabled while the other does not, and then renders them to a split-screen window.
namespace ArgusSamples
#define NUM_SESSIONS 6
// Constants.
static const uint32_t       CAPTURE_TIME    = 10; // In seconds.
static const Size           STREAM_SIZE      (1920, 1080);
static const NormalizedRect SOURCE_CLIP_RECT (0.4f, 0.4f, 0.6f, 0.6f);
// Globals.
UniqueObj<CameraProvider> g_cameraProvider;
EGLDisplayHolder g_display;
// Debug print macros.
#define PRODUCER_PRINT(...) printf("PRODUCER: " __VA_ARGS__)
static bool execute()
    // Initialize the window and EGL display.
    Window &window = Window::getInstance();
    window.setWindowRect(0, 0, STREAM_SIZE.width, STREAM_SIZE.height);
    PROPAGATE_ERROR(g_display.initialize(window.getEGLNativeDisplay()));
    // Initialize the Argus camera provider.
    UniqueObj<CameraProvider> cameraProvider(CameraProvider::create());
    ICameraProvider *iCameraProvider = interface_cast<ICameraProvider>(cameraProvider);
    if (!iCameraProvider)
        ORIGINATE_ERROR("Failed to get ICameraProvider interface");
    // Create a capture session using the first available device.
    std::vector<CameraDevice*> cameraDevices;
    if (iCameraProvider->getCameraDevices(&cameraDevices) != STATUS_OK)
        ORIGINATE_ERROR("Failed to get CameraDevices");
    if (cameraDevices.size() < NUM_SESSIONS)
        ORIGINATE_ERROR("Not enough CameraDevices available");
	UniqueObj<CaptureSession> captureSession[NUM_SESSIONS];
	ICaptureSession *iCaptureSession[NUM_SESSIONS];
    for(int i = 0 ; i < NUM_SESSIONS; i++)
		captureSession[i] = UniqueObj<CaptureSession>(iCameraProvider->createCaptureSession(cameraDevices[i]));
		iCaptureSession[i] = interface_cast<ICaptureSession>(captureSession[i]);
		if (!iCaptureSession[i])
			ORIGINATE_ERROR("Failed to create CaptureSession ");
    // Create six output streams for 4 previews .
    PRODUCER_PRINT("Creating 4 output streams\n");
    UniqueObj<OutputStreamSettings> streamSettings[NUM_SESSIONS];
    IOutputStreamSettings *iStreamSettings[NUM_SESSIONS];
    for(int i = 0 ; i < NUM_SESSIONS ; i++)
		streamSettings[i] = UniqueObj<OutputStreamSettings>(iCaptureSession[i]->createOutputStreamSettings());
        iStreamSettings[i] = interface_cast<IOutputStreamSettings>(streamSettings[i]);
		if (!iStreamSettings[i])
			ORIGINATE_ERROR("Failed to create OutputStreamSettings");
		iStreamSettings[i]->setPixelFormat(PIXEL_FMT_YCbCr_420_888);
		iStreamSettings[i]->setResolution(STREAM_SIZE);
		iStreamSettings[i]->setEGLDisplay(g_display.get());
    UniqueObj<OutputStream> previewStream[NUM_SESSIONS];
    IStream *iPreviewStream[NUM_SESSIONS];
		previewStream[i] = UniqueObj<OutputStream>(iCaptureSession[i]->createOutputStream(streamSettings[i].get()));
        iPreviewStream[i] = interface_cast<IStream>(previewStream[i]);
		if (!iPreviewStream[i])
			ORIGINATE_ERROR("Failed to create preview stream");
    // Connect a PreviewConsumer to the streams to render a split-screen, side-by-side rendering.
    PRODUCER_PRINT("Launching consumer thread\n");
    std::vector<EGLStreamKHR> eglStreams;
		eglStreams.push_back(iPreviewStream[i]->getEGLStream());
    PreviewConsumerThread consumerThread(g_display.get(), eglStreams,
                                         PreviewConsumerThread::LAYOUT_SPLIT_VERTICAL,
                                         false /* Sync stream frames */);
    PROPAGATE_ERROR(consumerThread.initialize());
    //consumerThread.setLineWidth(1);
    //consumerThread.setLineColor(1.0f, 0.0f, 0.0f);
    // Wait until the consumer is connected to the streams.
    PROPAGATE_ERROR(consumerThread.waitRunning());
	UniqueObj<Request> request[NUM_SESSIONS];
	IRequest *iRequest[NUM_SESSIONS];
    // Create capture request and enable output streams.
		request[i] = UniqueObj<Request>(iCaptureSession[i]->createRequest());
		iRequest[i] = interface_cast<IRequest>(request[i]);
		if (!iRequest[i])
			ORIGINATE_ERROR("Failed to create Request");
		iRequest[i]->enableOutputStream(previewStream[i].get());
    // Submit capture requests.
    PRODUCER_PRINT("Starting repeat capture requests.\n");
    for(int i = 0; i < NUM_SESSIONS ; i++)
    if (iCaptureSession[i]->repeat(request[i].get()) != STATUS_OK)
        ORIGINATE_ERROR("Failed to start repeat capture request");
    // Wait for CAPTURE_TIME seconds.
    PROPAGATE_ERROR(window.pollingSleep(CAPTURE_TIME));
    // Stop the repeating request and wait for idle.
		iCaptureSession[i]->stopRepeat();
		iCaptureSession[i]->waitForIdle();
    // Destroy the output streams and wait for the consumer thread to complete.
		previewStream[i].reset();
    PROPAGATE_ERROR(consumerThread.shutdown());
    // Shut down Argus.
    g_cameraProvider.reset();
    // Shut down the window (destroys window's EGLSurface).
    window.shutdown();
    // Cleanup the EGL display
    PROPAGATE_ERROR(g_display.cleanup());
    PRODUCER_PRINT("Done -- exiting.\n");
    return true;
}; // namespace ArgusSamples
int main(int argc, const char *argv[])
    if (!ArgusSamples::execute())
        return EXIT_FAILURE;
    return EXIT_SUCCESS;
Argus has shorter latency than gstreamer as we have test results at
[url]https://devtalk.nvidia.com/default/topic/1026587/jetson-tx2/csi-latency-is-over-80-milliseconds-/post/5222727/#5222727[/url]
For running multiple cameras, you have to configure ‘sudo ~/jetson_clocks.sh’ to get max performance.
